#include
#include #include typedef unsigned char u_int8; typedef unsigned int u_int16; typedef unsigned long u_int32; #define UART_PARITY_NONE 0 #define UART_PARITY_ODD 1 #define UART_PARITY_ENEV 2 u_int8 rdata; volatile u_int16 flag=0; //晶振频率 12M #define SYSTEM_CLOCK 12000000 //I/O口,位设置为发送模式/值置1,例: ***i(PORTA,0);***i(DDRA,0); #define ***i(io,bit) ( io |= (1< #define cbi(io,bit) ( io &= ~(1< #define gbi(pin ,bit) ( pin & (1< /*485置位,发送状态有效*/ #define EN_SEND delay_nus(20); ***i(PORTC, 1); delay_nus(20); /*485置位,接收状态有效*/ #define EN_RECV delay_nus(20); cbi(PORTC, 1); delay_nus(20); #define EN_RXISR UCSRB |= (1< { ***i(DDRD,PD1); cbi(DDRD,PD0); } void delay_nus( unsigned int n ) //N us延时函数 实际延时时长是输入的n值的两倍 { u_int16 i = 0; for ( i = 1; i < n; i++ ) { asm("nop"); asm("nop"); asm("nop"); asm("nop"); asm("nop"); asm("nop"); asm("nop"); asm("nop"); asm("nop"); asm("nop"); } } void uart_init(u_int32 baudrate, u_int8 databits, u_int8 sttopbits, u_int8 parity) { u_int8 ucsrc_value = 0; u_int8 ucsrb_value = 0; UCSRB = 0x00; //disable while setting baud rate UCSRA = 0x00; //en rxc /U2X1 = 0,不加倍数率 //set parity UCSRC = 0x80; switch(parity) { case 0://UART_PARITY_NONE ucsrc_value |= (0<<4);break;//"dp_None" case 1://UART_PARITY_ODD ucsrc_value |= (3<<4);break;//"dp_ODD" case 2://UART_PARITY_ENEV ucsrc_value |= (2<<4);break;//"dp_EVEN" default: ucsrc_value |= (1<<4);break;//"dp_None" } //set databites switch(databits) { case 5: ucsrc_value |= (0<<1);break;//5 case 6: ucsrc_value |= (1<<1);break;//6 case 7: ucsrc_value |= (2<<1);break;//7 case 8: ucsrc_value |= (3<<1);break;//8 case 9: ucsrc_value |= (3<<1); //9 ucsrb_value = UCSRB | (1<<2);break; default: ucsrc_value |= (3<<1);break;//8 } //set stopbies switch(sttopbits) { case 1: ucsrc_value |= (0<<3);break;//"STP1" case 2: ucsrc_value |= (1<<3);break;//"STP2" default: ucsrc_value |= (0<<3);break;//"STP1" } UCSRB|=(1< UCSRC = ucsrc_value|(1<<7); UCSRB |= ucsrb_value; //set baudrate UBRRL = ((SYSTEM_CLOCK / 16 / baudrate) - 1) % 256; //设置波特率低位 UBRRH = ((SYSTEM_CLOCK / 16 / baudrate) - 1) / 256; //设置波特率高位 } void send_data( u_int8 data ) { //UN_TXISR //EN_SEND UDR = data; //发送数据,数据为变量counter while ( !(UCSRA & 0x40) ); //等待发送结束 { UCSRA|=0x40; //清除发送结束标志位 } //EN_RECV //EN_TXISR } void send_puts(u_int8 *Str) { EN_SEND while (*Str) //字符串未结束则继续发送 { send_data(*Str++); } EN_RECV } #pragma interrupt_handler uart_rx_isr:14 void uart_rx_isr( void ) { UN_RXISR rdata=UDR; flag=1; EN_RXISR } void main() { port_init(); uart_init(2400, 8, 1, 0); send_puts("adasfdaff"); delay_nus(100); SEI(); while(1){ delay_nus(200); if(flag) { EN_SEND; delay_nus(20); send_data(rdata); delay_nus(20); EN_RECV; flag = 0; } } } |
2个回答
发送函数显示正常是什么意思?
程序看起来似乎没问题,但你主程序中对flag的处理似乎不太妥当,检测到flag后应立即取出接收到的数据,并清除flag,然后再做发送处理。当然也可以在接受中断函数里直接将接收到的数据发送出去。 建议你在接受中断函数里增加点灯语句,然后再逐步在主程序中点灯,这样便于你快速找到问题根源。。
最佳答案
哦 谢谢 我再试试!
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-shell脚本编写之传参
352 浏览 0 评论
【xG24 Matter开发套件试用体验】点灯之后的UART测试
400 浏览 0 评论
【xG24 Matter开发套件试用体验】第一个LED测试工程
351 浏览 0 评论
【xG24 Matter开发套件试用体验】蓝牙mesh基本功能开发调试
294 浏览 0 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-shell脚本编写之变量
593 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
10988 浏览 31 评论
GMT+8, 2024-9-5 05:24 , Processed in 0.723268 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
