扫一扫,分享给好友
stop_mode:
#if DEBUG printf("MCU Enter Stop Mode!n"); #endif //set the all GPIO as general GPIO 、remap IRDA in EXIT0 and disable tiM4 interrupt lowLevelGPIOCfg(); //将一些GPIO打到低电平,避免休眠耗电 ADC_Cmd(ADC1, DISABLE);//关闭ADC DMA_Cmd(DMA1_Channel1, DISABLE);//关闭DMA WireControl_EXTI_Enable(); //配置一个外部中断 GPIO_ResetBits(Led_Power, Led_Power_Pin);//关闭电源灯 //GPIO_SetBits(Led_Power, Led_Power_Pin); BKP_WriteBackupRegister(BKP_DR3, 0xFFFF); //设置一个备份寄存器,作为复位之后的判断标志 //Enter a stop mode //Request to enter STOP mode with regulator in low power mode, wake by any exit interrupt IWDG_WriteAccessCmd(IWDG_WriteAccess_Enable);//看门狗计数器访问使能 IWDG_SetReload(0xfff);//设置看门狗重载值,由原来的3秒,改为26秒 IWDG_ReloadCounter();//装载看门狗计数器 PWR_EnterSTOPMode(PWR_Regulator_LowPower, PWR_STOPEntry_WFI);//进入停止模式 //以下是唤醒之后的配置操作 reconfigSysClkConfig(); //重新配置系统时钟 NVIC_InitStructure.NVIC_IRQChannel = EXTI0_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 5; NVIC_InitStructure.NVIC_IRQChannelCmd = DISABLE; NVIC_Init(&NVIC_InitStructure);// //Configure EXTI0 line EXTI_InitStructure.EXTI_Line = EXTI_Line0; EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt; EXTI_InitStructure.EXTI_Trigger = ACC_EXTI_Trigger ; EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising ; EXTI_InitStructure.EXTI_LineCmd = DISABLE; EXTI_Init(&EXTI_InitStructure); WireControl_EXTI_Disable(); //restore the GPIO configurate GPIO_Configuration(0); GPIO_SetBits(Led_Power, Led_Power_Pin); USART_Configuration(); NVIC_Configuration(); TIM_Configuration(); TIM_ITConfig(TIM2, TIM_IT_Update , DISABLE);//开启计数中断 DMA_Configuration(); ADC_Configuration(); BKP_WriteBackupRegister(BKP_DR3, 0x0000);//修改备份寄存器的值 IWDG_Config(); SysTick_Config(SystemCoreClock / 5); } 本人解释一下大体代码思路,进入休眠之后,会拉低相关的GPIO,确保省电;配置一些外部中断,用来唤醒停止模式;休眠前写入一个值到备份寄存器。 然后休眠,休眠26秒后,看门狗复位,程序重启,判断是否由看门够引起的复位(第一次肯定是由看门够引起的复位,因为备份寄存器里面有休眠之前写入的值),若是由看门狗引起的复位,则不会开启看门狗功能,直接再次进入到这段代码,再次进入休眠,这次休眠,因为没有看门狗,所以可以一直休眠下去(只要没有外部中断触发),当外部中断触发以后,程序就唤醒,之后修改备份寄存器里面的值。 以下是问题: 个人倒是觉得代码和思路都没问题。但是测试的时候发现一个问题。而且是概率性的。 偶尔进入停止模式的时候,我的所有外部中断都无法将其唤醒。非要等复位过后,再次进入停止模式,才能由 外部中断唤醒。这真的是让我蛋碎了一地。。 看各位有啥高见。 |
2个回答
不懂,,帮顶。。。。
其实,代码单独抠出来,测试应该是没有问题的。
可能跟我的工程有关。 业务上是这样的, 在程序正常运行的时候,红外接收头的GPIO被定义为定时器捕获的输入,红外POWER键长按5秒之后关机, 在关机之前,将红外接收头的GPIO配置为外部中断(因为停止模式只能由外部中断唤醒或者RTC、USB等唤醒) 然后休眠后,就可以由红外信号唤醒MCU,唤醒后再把红外接收头的GPIO被定义为定时器捕获的输入。 为什么有时候唤不醒,个人推测原因: 在红外POWER键长按的时候,定时器捕获中断一直在触发,当确定收到POWER键长按5秒信号之后关机。 但是手不一定会立刻放开POWER键,所以定时器捕获中断一直在触发,但是在这个时候,我们又在重新配置 红外接收头的GPIO,EXTI,NVIC。所以我推测这里出现了问题。说简单一点就是,在中断函数不断触发的同时 我们在配置它的中断模式,NVIC,这样导致了矛盾。 这只是我的推测,不知大家有何看法。 另外加一条,在我实验的时候发现,虽然在休眠,但是可以响应外部中断(会执行中断服务函数),但就是唤不醒 其实个人也做了规避措施,做法是这样的。 红外POWER键长按5秒关机之后,我会关闭定时器不再捕获红外信号,然后延时300ms, 然后再来配置红红外接收头的GPIO,EXTI,NVIC,这样就没有出现那个现象了。 但是这只是一个规避措施,还是不知道为什么会发生那样的现象。真是如鲠在喉啊 看大家有无想法。 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
328 浏览 1 评论
868 浏览 1 评论
1841 浏览 1 评论
1573 浏览 1 评论
MCU友好过渡MPU,米尔基于STM32MP135开发板裸机开发应用笔记
689 浏览 0 评论
GMT+8, 2024-5-12 09:52 , Processed in 0.535888 second(s), Total 73, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
