.text
.global _start _start: b reset ldr pc,_undefine_instructions ldr pc,_software_interrupt ldr pc,_prefetch_abort ldr pc,_data_abort ldr pc,_not_use ldr pc,_interrput ldr pc,_fast_interrput _undefine_instructions: .word undefine_instructions _software_interrupt: .word software_interrupt _prefetch_abort: .word prefetch_abort _data_abort: .word data_abort _not_use: .word not_use _interrput: .word interrput _fast_interrput: .word fast_interrput reset: bl set_svc bl disable_watchdog bl disable_interrupt bl disable_mmu bl clock_init bl memory_init bl code_remove bl stack_init bl bss_init ldr pc,=gboot_main @从这跳到c部分,并开启2,4led undefine_instructions: nop software_interrupt: nop prefetch_abort: nop data_abort: nop not_use: nop interrput: nop fast_interrput: nop set_svc: mrs r0,cpsr bic r0,r0,#0b11111 orr r0,r0,#0b11010011 msr cpsr,r0 mov pc,lr disable_watchdog: ldr r0,=0x53000000 bic r1,r1,#0b101 str r1,[r0] mov pc,lr disable_interrupt: ldr r0,=0x4A000008 bic r1,r1,#0xffffffff str r1,[r0] mov pc,lr disable_mmu: mcr p15,0,r0,c7,c7,0 mrc p15,0,r0,c1,c0,0 bic r0,r0,#0b0101 mcr p15,0,r0,c1,c0,0 mov pc,lr #define PLLCON_405MHZ ((127<<12)|(2<<4)|(1<<0)) clock_init: ldr r0,=0x4c000014 mov r1,#0x5 str r1,[r0] mrc p15,0,r0,c1,c0,0 orr r0,r0,#0xc0000000 mcr p15,0,r0,c1,c0,0 ldr r0,=0x4c000004 ldr r1,=PLLCON_405MHZ str r1,[r0] mov pc,lr #define BWSCON_ADDR 0x48000000 memory_init: ldr r0,=BWSCON_ADDR add r1,r0,#13*4 adrl r2,memory_init_data b cycle cycle: ldr r3,[r2],#4 str r3,[r0],#4 cmp r0,r1 ble cycle mov pc,lr memory_init_data: .long 0x22000000 .long 0x00000700 .long 0x00000700 .long 0x00000700 .long 0x00000700 .long 0x00000700 .long 0x00000700 .long 0x00018001 .long 0x00018001 .long 0x008c04f5 .long 0x000000b1 .long 0x00000030 .long 0x00000030 code_remove: ldr r0,=0x0 ldr r1,=0x30000000 add r2,r1,#1024*4 remove_cycle: ldr r3,[r0],#4 str r3,[r1],#4 cmp r1,r2 ble remove_cycle mov pc,lr stack_init: ldr sp,=0x34000000 mov pc,lr bss_init: ldr r0,=bss_start ldr r1,=bss_end cmp r0,r1 moveq pc,lr bss_init_cycle: mov r2,#0x0 str r2,[r0],#4 cmp r0,r1 ble bss_init_cycle mov pc,lr .global light_led light_led: ldr r0,=0x56000010 ldr r1,=0x15400 str r1,[r0] ldr r0,=0X56000014 ldr r1,=0x15f str r1,[r0] ldr pc,=into_assembly @这里应该是101011111开启1,3led,而且应该关闭led2,4啊可是并没有关闭 //c语言部分 #define GPBCON (volatile unsigned long *)0x56000010 #define GPBDAT (volatile unsigned long *)0X56000014 #define GPBCON_A 0x56000010 #define GPBDAT_D 0X56000014 int gboot_main() { //汇编调用部分 *(GPBCON)=0x15400; *(GPBDAT)=0xbf;010111111;//开启2,4led //调用汇编 light_led(); return 0; } int into_assembly() { //嵌套 __asm__ volatile( "ldr r1,=0x15400n" "str r1,[%0]n" "ldr r1,=0x1bfn" "str r1,[%1]n" : :"r"(GPBCON_A),"r"(GPBDAT_D) :"r1" ); return 0; //为什么所有的led都被点亮了。我最后一次2440不是将其余的都设置为高电平了吗 } |
6个回答
代码没有用,给出原理图,看看电路如何,引脚分配如何才能说清除
应该对应电路是使用高电平还是低电平做为关闭状态吧
led未必电平为高才电亮,得看具体电路
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
762 浏览 0 评论
739 浏览 0 评论
飞凌嵌入式ElfBoard-文件I/O的了解探究之复制文件描述符
668 浏览 0 评论
飞凌嵌入式ElfBoard-文件I/O的了解探究之返回错误处理与相关函数
1448 浏览 0 评论
飞凌嵌入式ElfBoard-文件I/O的了解探究之文件描述符和FILE指针转换
1058 浏览 0 评论
/9
GMT+8, 2025-12-2 01:37 , Processed in 0.722969 second(s), Total 53, Slave 45 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3957
