电子发烧友论坛扫一扫,分享给好友
大神:帮我看看我的程序是什么问题, /**超声波测距离HC-SR04模块,在1602上显示出来,误差为5cm以内********/ #include "msp430.h" #include "Delayms.H" #include "lcd.H" #define uchar unsigned char #define uint unsigned int #define ulong unsigned long #define CLK_Trig P5OUT &= ~BIT0 //P3.0产生脉冲引脚 #define SET_Trig P5OUT |= BIT0 //P3.0产生脉冲引脚 #define Echo (P5IN & BIT1) //回波引脚 unsigned char tt[]=" hc-sr04 "; uchar distance[]="distance: CM"; unsigned long int distance_data, M; uchar succeed_bit; //uint count=0; //函数的声明// /*20us延时函数*/ void Delay20us() { uchar i; for(i=0; i<20; i++); } /***测量获取数据**/ void Measure() { succeed_bit=0; CCTL0 &= ~CCIE; //关闭中断使能; 测量前关闭中断,减少误差 // TACTL |= TACLR;//定时器的清零,清除基数的内容,不过TACTL resgiters设置也清除了 SET_Trig;//P3.0产生脉冲引脚 Delay20us();//延时20us,把Trig的引脚的电位拉高20us//之后,超声波内部自动发送8个40KHz的脉冲 CLK_Trig;//再输出低电平 while(Echo == 0);//判断echo是否变为高电平 CCTL0 |= CCIE;//中断使能,打开中断 while(Echo == 1); //等待echo变回低电平 distance_data = TAR;//TA0R是所需时间 while(!succeed_bit);//等待succeed为 1 M =(distance_data * 17)/1000;//测量结果为CM succeed_bit = 0; } //显示函数 void display() { distance[12] = M%10+0x30; //取个位 distance[11] = M/10%10+0x30; //取十位 distance[10] = M/100+0x30; //取百位 Write_intruction(0xc0); LCD1602_Print(distance); Delayms(60); } void main(void) { uchar i; //Stop watchdog timer to prevent time out reset WDTCTL = WDTPW + WDTHOLD; BCSCTL1 &= ~XT2OFF;//XT2OFF=0,XT2OFF is on do { IFG1 &= ~OFIFG; //对OFIFG的值取反 for(i=0; i<0xff; i++); } while(IFG1 & OFIFG);//判断OFIFG标志位失效 BCSCTL2 |= SELM_2 + SELS +DIVS_3;//使MCLK和SMCLK都为高频振荡器,8分频 CCR0 =61000; //定时61MS TACTL |= TASSEL_2 + ID_3 + MC_1 ;//选择SMLK时钟频率,8分频,1M P5DIR &= ~BIT1;//设置P5.1为输入端 P5DIR |= BIT0;//设置P5.1为输出端 P2DIR = 0xff;//LCD的数据端口 P6DIR = 0x38;//控制端口 Delayms(600); LCD1602_Inter();//1602的初始化 _EINT(); //进入全局中断 Write_intruction(0xc0);//第二行的列地址 LCD1602_Print(distance); Write_intruction(0x80);//第二行的列地址 LCD1602_Print(tt); while(1) { Measure(); display(); } } #pragma vector = TIMERA0_VECTOR __interrupt void vectot_TimeA(void) { succeed_bit =1; CCTL0 &= ~CCIE; //关闭中断使能; } /*************************** 系统在默认情况下,输出为0 ***************************/ #include "msp430.h" #include "Delayms.h" #define uchar unsigned char #define uint unsigned int #define DataDir P2DIR #define CtrlDir P6DIR #define CLR_RS P6OUT &= ~BIT3 #define SET_RS P6OUT|=BIT3 #define CLR_RW P6OUT&=~BIT4 #define SET_RW P6OUT|=BIT4 #define CLR_EN P6OUT&=~BIT5 #define SET_EN P6OUT|=BIT5 /*******LCD1602写指令函数***********/ void Write_intruction(uint intruction) { CLR_RS; CLR_RW; CLR_EN; SET_EN; P2OUT = intruction; CLR_EN; SET_RS; SET_RW; Delayms(30); } /*******LCD1602写数据*******/ void Write_Data(uchar *DATA) { SET_RS; CLR_RW; CLR_EN;//上升沿 SET_EN; P2OUT = *DATA; CLR_EN; SET_RS; SET_RW; Delayms(30); } /***********初始化LCD*************/ void LCD1602_Inter() { Write_intruction(0x38); Write_intruction(0x38); Write_intruction(0x38); Write_intruction(0x0C); Write_intruction(0x01); Write_intruction(0x06); } void LCD1602_Print(uchar *str) { while( *str!=' |
