#include #include #include #include #define uchar unsigned char #define uint unsigned int /*flash引脚*/ ***it CPU_LE1=P4^1;//定义锁存器使能 ***it CPU_LE2=P4^5; ***it CPU_LE3=P4^4; ***it uP_RDn=P3^4; ***it up_BLWEn_BLEn=P3^5; uint first; uchar idata buf4[1]; //存储所读取数据 /*1. Load Data AA (hex) into Address 05555 (hex) 2. Load Data 55 into Address 02AAA 3. Load Data A0 into Address 05555 4. Load desired sector with data 5. Pause tWC (device write cycle time) 6. Continue with next operation.*/ void init(void) { TMOD=0x20; TH1=0xfd; TL1=0xfd; PCON=0x00; TR1=1; SCON=0xd0; } void send(uchar addr) { TB8=1; SBUF=addr; while(TI==0) { ; } TI=0; } /************延时程序************/ void delay(uchar k) { uchar j; while((k--)!=0) { for(j=0;j<125;j++) {;} } } void delay1(unsigned int l_time) { unsigned int data lp; for(lp=0;lp } //数据保护模块 void protect() { uP_RDn=1; up_BLWEn_BLEn=1; CPU_LE1=1; P2=0x55; CPU_LE1=0; CPU_LE2=1; P2=0x55; CPU_LE2=0; CPU_LE3=1; P2=0x00; CPU_LE3=0; up_BLWEn_BLEn=0; P2=0xaa; up_BLWEn_BLEn=1; CPU_LE1=1; P2=0xaa; CPU_LE1=0; CPU_LE2=1; P2=0x2a; CPU_LE2=0; CPU_LE3=1; P2=0x00; CPU_LE3=0; up_BLWEn_BLEn=0; P2=0x55; up_BLWEn_BLEn=1; CPU_LE1=1; P2=0x55; CPU_LE1=0; CPU_LE2=1; P2=0x55; CPU_LE2=0; CPU_LE3=1; P2=0x00; CPU_LE3=0; up_BLWEn_BLEn=0; P2=0xa0; up_BLWEn_BLEn=1; } //块选择 bit SectorChoose(uint suba) { suba=suba/256; CPU_LE2=1; P2=suba&0xff; CPU_LE2=0; suba=suba/256; CPU_LE3=1; P2=suba&0xff; CPU_LE3=0; return 0; } //后续数据写入 bit WriteData(uint addr,uint s) { addr=addr&0xff; CPU_LE1=1; P2=addr; CPU_LE1=0; up_BLWEn_BLEn=0; P2=s; up_BLWEn_BLEn=1; return 0; } //读出数据,暂时不知道是否需要连续读出。 bit ReadData(uint suba) { CPU_LE1=1; P2=suba&0xff; CPU_LE1=0; suba=suba/256; CPU_LE2=1; P2=suba&0xff; CPU_LE2=0; suba=suba/256; CPU_LE3=1; P2=suba&0xff; CPU_LE3=0; uP_RDn=0; delay1(1); buf4[0]=P2; //这里可能有问题 uP_RDn=1; return 0; } void main() { int i; uint addr=0x00200; first=0x04; init(); P4M1=0x00; //P4.4,P4.5作为IO口 P4M0=0x72; P4SW=0x70; uP_RDn=1; //读使能关闭 up_BLWEn_BLEn=1; delay1(200); protect(); SectorChoose(addr); for(i=0;i<255;i++) { WriteData(addr,first); addr++; } up_BLWEn_BLEn=0; delay1(1000); while(1) { buf4[0]=0x04; send(buf4[0]); delay(200); ReadData(0x00200); send(buf4[0]); delay(200); ReadData(0x00222); send(buf4[0]); delay(200); ReadData(0x002ff); send(buf4[0]); delay(200); } } 原理图如下
1个回答
顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶顶
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1445 浏览 1 评论
1115 浏览 0 评论
976 浏览 0 评论
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
5355 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
4148 浏览 1 评论
/9
GMT+8, 2025-12-14 11:50 , Processed in 0.657794 second(s), Total 74, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2583
