扫一扫,分享给好友
#include
#define uchar unsigned char //无符号字符型 宏定义 变量范围0~255 #define uint unsigned int //无符号整型 宏定义 变量范围0~65535 #include "eeprom52.h" //数码管段选定义 0 1 2 3 4 5 6 7 8 9 uchar code smg_du[]={0x28,0xee,0x32,0xa2,0xe4,0xa1,0x21,0xea,0x20,0xa0, 0x60,0x25,0x39,0x26,0x31,0x71,0xff}; //断码 //数码管位选定义 uchar code smg_we[]={0xef,0xdf,0xbf,0x7f}; uchar dis_smg[8] = {0x28,0xee,0x32,0xa2,0xe4,0x92,0x82,0xf8}; uchar smg_i = 3; //显示数码管的个位数 ***it dq = P2^4; //18b20 IO口的定义 bit flag_lj_en; //按键连加使能 bit flag_lj_3_en; //按键连3次连加后使能 加的数就越大了 uchar key_time,key_value;//用做连加的中间变量 bit key_500ms ; ***it moc30 = P2^5; uint temperature ; // bit flag_300ms ; uchar menu_1; //菜单设计的变量 uint t_high = 300,t_low = 100; //温度上下限报警值 /***********************1ms延时函数*****************************/ void delay_1ms(uint q) { uint i,j; for(i=0;i for(j=0;j<120;j++); } /***********************小延时函数*****************************/ void delay_uint(uint q) { while(q--); } /***********************数码显示函数*****************************/ void display() { static uchar i; i++; if(i >= smg_i) i = 0; P1 = 0xff; //消隐 P3 = smg_we[i]; //位选 P1 = dis_smg[i]; //段选 } /******************把数据保存到单片机内部eepom中******************/ void write_eeprom() { SectorErase(0x2000); byte_write(0x2000, t_high % 256); byte_write(0x2001, t_high / 256); byte_write(0x2002, t_low % 256); byte_write(0x2003, t_low / 256); byte_write(0x2055, a_a); } /******************把数据从单片机内部eepom中读出来*****************/ void read_eeprom() { t_high = byte_read(0x2001); t_high <<= 8; t_high |= byte_read(0x2000); t_low = byte_read(0x2003); t_low <<= 8; t_low |= byte_read(0x2002); a_a = byte_read(0x2055); } /**************开机初始化保存的数据*****************/ void init_eeprom() { read_eeprom(); //先读 if(a_a != 22) //新的单片机初始单片机内问eeprom { t_high = 250; t_low = 200; a_a = 22; write_eeprom(); //保存数据 } } /***********************18b20初始化函数*****************************/ void init_18b20() { bit q; dq = 1; //把总线拿高 delay_uint(1); //15us dq = 0; //给复位脉冲 delay_uint(80); //750us dq = 1; //把总线拿高 等待 delay_uint(10); //110us q = dq; //读取18b20初始化信号 delay_uint(20); //200us dq = 1; //把总线拿高 释放总线 } /*************写18b20内的数据***************/ void write_18b20(uchar dat) { uchar i; for(i=0;i<8;i++) { //写数据是低位开始 dq = 0; //把总线拿低写时间隙开始 dq = dat & 0x01; //向18b20总线写数据了 delay_uint(5); // 60us dq = 1; //释放总线 dat >>= 1; } } /*************读取18b20内的数据***************/ uchar read_18b20() { uchar i,value; for(i=0;i<8;i++) { dq = 0; //把总线拿低读时间隙开始 value >>= 1; //读数据是低位开始 dq = 1; //释放总线 if(dq == 1) //开始读写数据 value |= 0x80; delay_uint(5); //60us 读一个时间隙最少要保持60us的时间 } return value; //返回数据 } /*************读取温度的值读出来的是小数***************/ uint read_temp() { uint value; uchar low; //在读取温度的时候如果中断的太频繁了,就应该把中断给关了,否则会影响到18b20的时序 init_18b20(); //初始化18b20 write_18b20(0xcc); //跳过64位ROM write_18b20(0x44); //启动一次温度转换命令 delay_uint(50); //500us init_18b20(); //初始化18b20 write_18b20(0xcc); //跳过64位ROM write_18b20(0xbe); //发出读取暂存器命令 low = read_18b20(); //读温度低字节 value = read_18b20(); //读温度高字节 value <<= 8; //把温度的高位左移8位 value |= low; //把读出的温度低位放到value的低八位中 value *= 0.625; //转换到温度值 小数 return value; //返回读出的温度 带小数 } /*************定时器初始化程序***************/ void time_init() { EA=1; //开总中断 TMOD =0x11; //定时器0、定时器1工作方式1 ET0 =1; //开定时器0中断 TR0 =1; //允许定时器0定时 EX0=1; //开外中断0 IT0=1; //下降沿触发 ET1=1; } /********************独立按键程序*****************/ uchar key_can; //按键值 void key() //独立按键程序 { static uchar key_new; key_can = 20; //按键值还原 P2 |= 0x07; if((P2 & 0x07) != 0x07) //按键按下 { if(key_500ms == 1) //连加 { key_500ms = 0; key_new = 1; } delay_1ms(1); //按键消抖动 if(((P2 & 0x07) != 0x07) && (key_new == 1)) { //确认是按键按下 key_new = 0; switch(P2 & 0x07) { case 0x06: key_can = 3; break; //得到k2键值 case 0x05: key_can = 2; break; //得到k3键值 case 0x03: key_can = 1; break; //得到k4键值 } flag_lj_en = 1; //连加使能 } } else { if(key_new == 0) { key_new = 1; write_eeprom(); //保存数据 flag_lj_en = 0; //关闭连加使能 flag_lj_3_en = 0; //关闭3秒后使能 key_value = 0; //清零 key_time = 0; key_500ms = 0; } } } /****************按键处理数码管显示函数***************/ void key_with() { if(key_can == 1) //设置键 { menu_1 ++; if(menu_1 >= 3) //按设置键3次 { menu_1 = 0; smg_i = 3; //数码管显示3位 } } if(menu_1 == 1) //设置高温报警 { smg_i = 4; //数码管显示4位 if(key_can == 2) { if(flag_lj_3_en == 0) t_high ++ ; //按键按下未松开自动加三次 else t_high += 10; //按键按下未松开自动加三次之后每次自动加10 if(t_high > 990) t_high = 990; } if(key_can == 3) { if(flag_lj_3_en == 0) t_high -- ; //按键按下未松开自动减三次 else t_high -= 10; //按键按下未松开自动减三次之后每次自动减10 if(t_high <= t_low) t_high = t_low + 1; } dis_smg[0] = smg_du[t_high % 10]; //取小数显示 dis_smg[1] = smg_du[t_high / 10 % 10] & 0xdf; //取个位显示 dis_smg[2] = smg_du[t_high / 100 % 10] ; //取十位显示 dis_smg[3] = 0x64; //H } if(menu_1 == 2) //设置低温报警 { smg_i = 4; //数码管显示4位 if(key_can == 2) { if(flag_lj_3_en == 0) t_low ++ ; //按键按下未松开自动加三次 else t_low += 10; //按键按下未松开自动加三次之后每次自动加10 if(t_low >= t_high) t_low = t_high - 1; } if(key_can == 3) { if(flag_lj_3_en == 0) t_low -- ; //按键按下未松开自动减三次 else t_low -= 10; //按键按下未松开自动加三次之后每次自动加10 if(t_low <= 10) t_low = 10; } dis_smg[0] = smg_du[t_low % 10]; //取小数显示 dis_smg[1] = smg_du[t_low / 10 % 10] & 0xdf; //取个位显示 dis_smg[2] = smg_du[t_low / 100 % 10] ; //取十位显示 dis_smg[3] = 0x3D; //L } } /****************风扇控制函数***************/ /****************主函数***************/ void main() { P0 = P1 = P2 = 0xff; //初始化单片机IO口为高电平 ? time_init(); //初始化定时器 temperature = read_temp(); //先读出温度的值 init_eeprom(); //开始初始化保存的数据 delay_1ms(650); temperature = read_temp(); //先读出温度的值 dis_smg[0] = smg_du[temperature % 10]; //取温度的小数显示 dis_smg[1] = smg_du[temperature / 10 % 10] & 0xdf; //取温度的个位显示 dis_smg[2] = smg_du[temperature / 100 % 10] ; //取温度的十位显示 TH1=(65536-50000)/256; TL1=(65536-50000)%256; ET1=1; TR1=1; EA=1; while(1) { key(); //按键程序 if(key_can < 10) { key_with(); //设置报警温度 } if(flag_300ms == 1) //300ms 处理一次温度程序 { flag_300ms = 0; temperature = read_temp(); //先读出温度的值 if(menu_1 == 0) { smg_i = 3; dis_smg[0] = smg_du[temperature % 10]; //取温度的小数显示 dis_smg[1] = smg_du[temperature / 10 % 10] & 0xdf; //取温度的个位显示 dis_smg[2] = smg_du[temperature / 100 % 10] ; //取温度的十位显示 } } } } /*************定时器0中断服务程序***************/ void time0_int() interrupt 1 { static uchar value; //定时2ms中断一次 TH0 = 0xf8; TL0 = 0x30; //2ms display(); //数码管显示函数 value++; if(value >= 150) { value = 0; flag_300ms = 1; } if(flag_lj_en == 1) //按下按键使能 { key_time ++; if(key_time >= 250) //500ms { key_time = 0; key_500ms = 1; //500ms key_value ++; if(key_value > 3) { key_value = 10; flag_lj_3_en = 1; //3次后1.5秒连加大些 } } } } /*******************定时器1用做单片机模拟PWM 调节***********************/ void Timer1() interrupt 3 { TR1=0; moc30=1; moc30=1; moc30=0; moc30=0; moc30=0; moc30=0; moc30=0; } interrupt0() interrupt 0 { EX0=0; TMOD=0X11; if(temperature >= t_high) //风扇全开 { TR1=0; moc30=1; } if((temperature < t_high) && (temperature >= t_low)) //风扇缓慢 { TH1=(65536-50000)/256; TL1=(65536-50000)%256; ET1=1; TR1=1; EA=1; } if(temperature < t_low) //关闭风扇 { TR1=0 ; moc30=1; } } 可以实现外中断(过零检测电路实现),但进入不了T1中断服务程序,这是智能温控风扇(交流)的程序,求指教 |
4个回答
你指的T1中断是什么中断?是哪个中断?
外部中断一进入就关闭了,下面的就不执行,所以定时器1没有开启
不要采取这种方式去写,定时器0和定时器1会互相干扰,比如TMOD &= 0XF0; TMOD |= 0X01;这样写,将定时器0和定时器1配置分开试试 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
435 浏览 0 评论
464 浏览 0 评论
450 浏览 0 评论
806 浏览 0 评论
RT-Thread与英飞凌(infineon)合作得板子PSOC 6 板子学习
748 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
17012 浏览 31 评论
/9
GMT+8, 2025-12-12 07:20 , Processed in 0.734503 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
11044
