用51单片机控制舵机转动超声波测距,然后用1602显示。结果是角度显示了,距离也显示了,就是舵机SG90不转动,没办法定位障碍位置,想了好几天,都还搞不好,求大神帮助 PS:我不是伸手党,已经查了好多资料,我是确实做不了,以下是我的程序,新手上路,不喜勿喷
*时间: *备注: ************************************************** ============================================================== LCD1602模拟口线接线方式 连接线图: --------------------------------------------------- |LCM-----51 | LCM-----51 | LCM------51 | --------------------------------------------------| |DB0-----P0.0 | DB4-----P0.4 | RW-------P3.4 | |DB1-----P0.1 | DB5-----P0.5 | RS-------P3.3 | |DB2-----P0.2 | DB6-----P0.6 | E--------P3.5 | |DB3-----P0.3 | DB7-----P0.7 | VLCD接1K电阻到GND| --------------------------------------------------- 接线:模块TRIG接 P1.1 ECH0 接P1.2 蜂鸣器报警 P2.2 =============================================================*/ #include #include #define uchar unsigned char #define uint unsigned int uchar anglecount ,jd =1 ; ***it TX = P1^1; //#define TX P1_1 超声波引脚配置 ***it RX = P1^2; //#define RX P1_2 ***it pwm = P1^3; ***it beep = P2^1; ***it LCM_RS = P2^4 ; //定义LCD引脚 ***it LCM_RW = P2^5 ; ***it LCM_E = P2^6 ; #define LCM_Data P0 ***it jia = P3^6 ;//定义Keyboard引脚 ***it jian = P3^7 ; #define Busy 0x80 //用于检测LCM状态字中的Busy标识 void LCMInit(void); void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData); void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData); void Delay5Ms(void); void Delay400Ms(void); void Decode(unsigned char ScanCode); void WriteDataLCM(unsigned char WDLCM); void WriteCommandLCM(unsigned char WCLCM,BuysC); //void T1_time0_init(void); unsigned char ReadDataLCM(void); unsigned char ReadStatusLCM(void); unsigned char code system[] ={"Warning systems "}; unsigned char code designer[] = {"Designed by Li "}; unsigned char code Cls[] = {" "}; unsigned char code ASCII[15] ={'0','1','2','3','4','5','6','7','8','9','.','-','M','*'}; static unsigned char DisNum = 0; //显示用指针 unsigned int time=0; unsigned long S=0; bit flag =0; unsigned char di***uff[4] ={ 0,0,0,0,}; unsigned char angbuff[4] ={ 0,0,0,0,}; /***********************************************************************************************/ /*****************************************LCD1602设置程序***************************************/ /***********************************************************************************************/ //写数据 void WriteDataLCM(unsigned char WDLCM) { ReadStatusLCM(); //检测忙 LCM_Data = WDLCM; LCM_RS = 1; LCM_RW = 0; LCM_E = 0; //若晶振速度太高可以在这后加小的延时 LCM_E = 0; //延时 LCM_E = 1; } //写指令 void WriteCommandLCM(unsigned char WCLCM,BuysC) //BuysC为0时忽略忙检测 { if (BuysC) ReadStatusLCM(); //根据需要检测忙 LCM_Data = WCLCM; LCM_RS = 0; LCM_RW = 0; LCM_E = 0; LCM_E = 0; LCM_E = 1; } //读数据 unsigned char ReadDataLCM(void) { LCM_RS = 1; LCM_RW = 1; LCM_E = 0; LCM_E = 0; LCM_E = 1; return(LCM_Data); } //读状态 unsigned char ReadStatusLCM(void) { LCM_Data = 0xFF; LCM_RS = 0; LCM_RW = 1; LCM_E = 0; LCM_E = 0; LCM_E = 1; while (LCM_Data & Busy); //检测忙信号 return(LCM_Data); } void LCMInit(void) //LCM初始化 { LCM_Data = 0; WriteCommandLCM(0x38,0); //三次显示模式设置,不检测忙信号 Delay5Ms(); WriteCommandLCM(0x38,0); Delay5Ms(); WriteCommandLCM(0x38,0); Delay5Ms(); WriteCommandLCM(0x38,1); //显示模式设置,开始要求每次检测忙信号 WriteCommandLCM(0x08,1); //关闭显示 WriteCommandLCM(0x01,1); //显示清屏 WriteCommandLCM(0x06,1); // 显示光标移动设置 WriteCommandLCM(0x0F,1); // 显示开及光标设置 } //按指定位置显示一个字符 void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData) { Y &= 0x1; X &= 0xF; //限制X不能大于15,Y不能大于1 if (Y) X |= 0x40; //当要显示第二行时地址码+0x40; X |= 0x80; //算出指令码 WriteCommandLCM(X, 1); //发命令字 WriteDataLCM(DData); //发数据 } //按指定位置显示一串字符 void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData) { unsigned char ListLength; ListLength = 0; Y &= 0x1; X &= 0xF; //限制X不能大于15,Y不能大于1 while (DData[ListLength]>0x19) //若到达字串尾则退出 { if (X <= 0xF) //X坐标应小于0xF { DisplayOneChar(X, Y, DData[ListLength]); //显示单个字符 ListLength++; X++; } } } /****************************************************************************************/ /**************************************延时程序***************************************/ /******************************************************************************************/ //5ms延时 void Delay5Ms(void) { unsigned int TempCyc = 5552; while(TempCyc--); } //400ms延时 void Delay400Ms(void) { unsigned char TempCycA = 5; unsigned int TempCycB; while(TempCycA--) { TempCycB=7269; while(TempCycB--); }; } void delay(uchar x) { uchar i,j; for(i=x;i>0;i--) for(j=125;j>0;j--); } void delayms(unsigned int ms) { unsigned char i=100,j; for(;ms;ms--) { while(--i) { j=10; while(--j); } } } /******************************************************************************************/ /********************************超声波距离显示*******************************************/ /*********************************************************************************************/ void Conut(void) { time=TH0*256+TL0; TH0=0; TL0=0; S=(time*17)/1000; //算出来是M if((S>=700)||flag==1) //超出测量范围显示“-” { flag=0; DisplayOneChar(0, 1, ASCII[11]); DisplayOneChar(1, 1, ASCII[10]); //显示点 DisplayOneChar(2, 1, ASCII[11]); DisplayOneChar(3, 1, ASCII[11]); DisplayOneChar(4, 1, ASCII[12]); //显示M } else { di***uff[0]=S%1000/100; di***uff[1]=S%1000%100/10; di***uff[2]=S%1000%10 %10; DisplayOneChar(0, 1, ASCII[di***uff[0]]); DisplayOneChar(1, 1, ASCII[10]); //显示点 DisplayOneChar(2, 1, ASCII[di***uff[1]]); DisplayOneChar(3, 1, ASCII[di***uff[2]]); DisplayOneChar( 4, 1, ASCII[12]); //显示M DisplayOneChar(11, 1, ASCII[13]); //显示角度* } } /***********************************************************************************************************/ /***********************************************角度按键控制扫描*********************************/ /************************************************************************************************************/ void keyscan() { if(jia==0) { delay(15); //消抖 if(jia==0) { jd++; //角度增加 1 anglecount=0; //按键按下则20ms周期重新开始计时 if(jd==6) jd=5; //已经是180度,保持 while(jia==0); } } if(jian==0) { delay(15); //消抖 if(jian==0) { jd--; anglecount=0; if(jd==0) jd=1; //已经0度,保持 while(jian==0); } } } /*******************************************************************************************************/ /***********************************************角度显示函数************************************************/ /*********************************************************************************************************/ void display() { uchar bai ,shi,ge ; switch(jd) { case 1: bai=0; shi=0; ge=0; break; case 2: bai=0; shi=4; ge=5; break; case 3: bai=0; shi=9; ge=0; break; case 4: bai=1; shi=3; ge=5; break; case 5: bai=1; shi=8; ge=0; break; } angbuff[0] = bai; angbuff[1] = shi; angbuff[2] = ge; delay(5); DisplayOneChar(8, 1, ASCII[angbuff[0]]); //bai DisplayOneChar(9, 1, ASCII[angbuff[1]]); //shi DisplayOneChar(10,1, ASCII[angbuff[2]]); //ge } /********************************************************/ void T0_time() interrupt 1 //T0中断用来计数器溢出,超过测距范围 { flag=1; //中断溢出标志 } /********************************************************/ /*void T1_time0_init() { TMOD=0x11; //定时器1工作方式1 IE=0x82; TH0=0xfe; TL0=0x33; //11.0592MHZ晶振,0.5ms TR0=1; } */ /*******************************************定时器1中断程序(角度控制)*************************/ void T1_time() interrupt 3 { uchar anglecount ; TH1=0xfe; TL1=0x33; if(anglecount else pwm=0; //否,输出低电平 anglecount=anglecount+1; anglecount=anglecount%40; //次数始终保持为40,即保持周期为20ms } /*****************************************************************************************/ /*******************************超声波发射函数*************************/ /*********************************************************************************************/ void StartModule() //启动模块函数 { TX=1; //启动一次模块 _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); TX=0; } /*******************************报警函数**************************** void warning() { beep = 0 ; if(S<=20) { beep = 1 ; } else { beep = 0 ; } } /**********************************************************************************************/ /**********************************************************************************************/ /******************************************主函数***************************************************/ void main(void) { unsigned char TempCyc; Delay400Ms(); //启动等待,等LCM讲入工作状态 LCMInit(); //LCM初始化 // beep = 0 ; Delay5Ms(); //延时片刻(可不要) DisplayListChar(0, 0, system); DisplayListChar(0, 1, designer); ReadDataLCM(); //测试用句无意义 for (TempCyc=0; TempCyc<10; TempCyc++) Delay400Ms(); //延时 DisplayListChar(0, 1, Cls); TMOD=0x11; //设T0,T1为方式1,GATE=1; TH0=0; TL0=0; TH1=0xfe; TL1=0x33; //11.0592MHZ晶振,0.5ms IE = 0x09; //允许T0,T1中断 EA=1 ; //开启总中断 TR1=1; anglecount=0; while(1) { StartModule(); //启动模块 DisplayOneChar(4, 1, ASCII[12]); //距离显示 while(!RX); //当RX为零时等待 TR0=1; //开启计数 while(RX); //当RX为1计数并等待 TR0=0; //关闭计数 Conut(); //距离计算 delayms(20); //80MS延时 TR1=1; keyscan(); // TR1=0; // delayms(80); display(); } } |
1个回答
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
265 浏览 0 评论
【原创】【RA4M2-SENSOR开发板评测】低功耗+USB综合测试
789 浏览 0 评论
1306 浏览 2 评论
787 浏览 0 评论
【RA4M2-SENSOR开发板评测】Analogue+Timers综合测试
1587 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
16900 浏览 31 评论
/9
GMT+8, 2025-12-2 01:16 , Processed in 0.548478 second(s), Total 41, Slave 33 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
5868
