本帖最后由 硬汉Eric2013 于 2015-1-10 14:37 编辑 第10章 μCOS-III在高版本MDK开启FPU方案 由于官方提供的μCOS-III移植工程中对于浮点寄存器的入栈和出栈处理是错误的,所以网上就流传了各种修正版本。但是这些修正的代码只能在MDK4.7以下版本中可以正常的运行,MDK4.7及其以上的版本无法正常运行。本期教程为此而生。本期教程提供的方案只有任务使用了浮点寄存器(也就是做了浮点运算)才需要将其入栈,没有使用浮点寄存器的任务不需要进行入栈,认识到这点很重要。此方案在MDK4.54、4.73、5.10以及IAR6.3、6.7上面测试均通过。 10.1 官方移植方案 10.2 开启FPU解决方案 10.3 开启FPU的优劣 10.4 总结 10.1 官方移植方案 官方提供的移植工程里面,只有IAR工程里面才有浮点寄存器的入栈和出栈处理函数,MDK工程里面是没有的。下面这个是os_cpu_c.c文件夹中的函数: /* ********************************************************************************************************* * INItiALIZE A TASK'S STACK * * Description: This function is called by either OSTaskCreate() orOSTaskCreateExt() to initialize the * stack frame of thetask being created. This function ishighly processor specific. * * Arguments : task is a pointer to the task code * * p_arg is a pointer to a user supplied dataarea that will be passed to the task * whenthe task first executes. * * ptos is a pointer to the top ofstack. It is assumed that 'ptos' pointsto * a'free' entry on the task stack. IfOS_STK_GROWTH is set to 1 then * 'ptos'will contain the HIGHEST valid address of the stack. Similarly, if * OS_STK_GROWTH is set to 0, the 'ptos' willcontains the LOWEST valid address * of thestack. * * opt specifies options that can be usedto alter the behavior of OSTaskStkInit(). * (see uCOS_II.H for OS_TASK_OPT_xxx). * * Returns : Always returns thelocation of the new top-of-stack once the processor registers have * been placed on thestack in the proper order. * * Note(s) : (1) Interrupts areenabled when task starts executing. * * (2) All tasks run inThread mode, using process stack. * * (3) There are twodifferent stack frames depending on whether the Floating-Point(FP) * co-processor isenabled or not. * * (a) The stack frame shown in thediagram is used when the FP co-processor is not present and * OS_TASK_OPT_SAVE_FP is disabled. In this case, the FP registers and FPStatus Control * register arenot saved in the stack frame. * * (b) If the FPco-processor is present but the OS_TASK_OPT_SAVE_FP is not set, then the stack * frame issaved as shown in diagram (a). Moreover, if OS_TASK_OPT_SAVE_FP is set, thenthe * FP registers and FP StatusControl register are saved in the stack frame. * * (1) Whenenabling the FP co-processor, make sure to clear bits ASPEN and LSPEN in the * Floating-Point Context Control Register (FPCCR). * * +------------+ +------------+ * | | | | * +------------+ +------------+ * | xPSR | | xPSR | * +------------+ +------------+ * |Return Addr| |Return Addr | * +------------+ +------------+ * | LR(R14) | | LR(R14) | * +------------+ +------------+ * | R12 | | R12 | * +------------+ +------------+ * | R3 | | R3 | * +------------+ +------------+ * | R2 | | R0 | * +------------+ +------------+ * | R1 | | R1 | * +------------+ +------------+ * | R0 | | R0 | * +------------+ +------------+ * | R11 | | R11 | * +------------+ +------------+ * | R10 | | R10 | * +------------+ +------------+ * | R9 | | R9 | * +------------+ +------------+ * | R8 | | R8 | * +------------+ +------------+ * | R7 | | R7 | * +------------+ +------------+ * | R6 | | R6 | * +------------+ +------------+ * | R5 | | R5 | * +------------+ +------------+ * | R4 | | R4 | * +------------+ +------------+ * (a) | FPSCR | * +------------+ * | S31 | * +------------+ * . * . * . * +------------+ * | S1 | +------------+ * | S0 | * +------------+ * (b) * * (4) The SP must be 8-bytealigned in conforming to the Procedure Call Standard for the ARM architecture * * (a) Section 2.1of the ABI for the ARM ArchitectureAdvisory Note. SP must be 8-byte aligned * on entry toAAPCS-Conforming functions states : * * TheProcedure Call Standard for the ARM Architecture [AAPCS] requires primitive * data typesto be naturally aligned according to their sizes (for size = 1, 2, 4, 8 bytes). * Doingotherwise creates more problems than it solves. * * In returnfor preserving the natural alignment of data, conforming code is permitted * to rely onthat alignment. To support aligning data allocated on the stack, the stack * pointer(SP) is required to be 8-byte aligned on entry to a conforming function. In * practicethis requirement is met if: * * (1) At each call site, the current size ofthe calling function抯 stack frame is a multiple of 8 bytes. * Thisplaces an obligation on compilers and assembly language programmers. * * (2) SPis a multiple of 8 when control first enters a program. * Thisplaces an obligation on authors of low level OS, RTOS, and runtime library * codeto align SP at all points at which control first enters * abody of (AAPCS-conforming) code. * * In turn,this requires the value of SP to be aligned to 0 modulo 8: * * (3) Byexception handlers, before calling AAPCS-conforming code. * * (4) ByOS/RTOS/run-time system code, before giving control to an application. * * (b) Section 2.3.1corrective steps from the the SP must be 8-byte aligned on entry * to AAPCS-conformingfunctions advisory note also states. * * " Thisrequirement extends to operating systems and run-time code for all architectureversions * prior toARMV7 and to the A, R and M architecture profiles thereafter. Specialconsiderations * associatedwith ARMV7M are discussed in ?.3.3" * * (1) Even ifthe SP 8-byte aligment is not a requirement for the ARMv7M profile, the stackis aligned * to 8-byte boundaries to support legacyexecution enviroments. * * (c) Section5.2.1.2 from the Procedure Call Standard for the ARM * architecturestates : "The stack must alsoconform to the following * constraint at a public interface: * * (1) SP mod 8 =0. The stack must be double-word aligned" * * (d) From the ARMTechnical Support Knowledge Base. 8 Byte stack aligment. * * "8 bytestack alignment is a requirement of the ARM Architecture Procedure * Call Standard[AAPCS]. This specifies that functions must maintain an 8 byte * aligned stackaddress (e.g. 0x00, 0x08, 0x10, 0x18, 0x20) on all external * interfaces.In practice this requirement is met if: * * (1) At eachexternal interface, the current stack pointer * is amultiple of 8 bytes. * * (2) Your OS maintains8 byte stack alignment on its external interfaces * e.g. ontask switches" * ********************************************************************************************************** */ OS_STK *OSTaskStkInit (void (*task)(void *p_arg), void *p_arg, OS_STK*ptos, INT16U opt) { OS_STK *p_stk; p_stk = ptos + 1u; /* Loadstack pointer */ /* Align the stack to 8-bytes. */ p_stk = (OS_STK *)((OS_STK)(p_stk) &0xFFFFFFF8u); /* Registers stacked as if auto-saved on exception */ *(--p_stk) =(OS_STK)0x01000000uL; /* xPSR */ *(--p_stk) = (OS_STK)task; /* EntryPoint */ *(--p_stk) =(OS_STK)OS_TaskReturn; /* R14 (LR) */ *(--p_stk) =(OS_STK)0x12121212uL; /* R12 */ *(--p_stk) =(OS_STK)0x03030303uL; /* R3 */ *(--p_stk) =(OS_STK)0x02020202uL; /* R2 */ *(--p_stk) =(OS_STK)0x01010101uL; /* R1 */ *(--p_stk) = (OS_STK)p_arg; /* R0 :argument */ /* Remaining registers saved on process stack */ *(--p_stk) =(OS_STK)0x11111111uL; /* R11 */ *(--p_stk) =(OS_STK)0x10101010uL; /* R10 */ *(--p_stk) =(OS_STK)0x09090909uL; /* R9 */ *(--p_stk) =(OS_STK)0x08080808uL; /* R8 */ *(--p_stk) =(OS_STK)0x07070707uL; /* R7 */ *(--p_stk) = (OS_STK)0x06060606uL; /* R6 */ *(--p_stk) =(OS_STK)0x05050505uL; /* R5 */ *(--p_stk) = (OS_STK)0x04040404uL; /* R4 */ #if (OS_CPU_ARM_FP_EN > 0u) if ((opt &OS_TASK_OPT_SAVE_FP) != (INT16U)0) { *--p_stk =(OS_STK)0x02000000u; /* FPSCR */ /* Initialize S0-S31 floating point registers */ *--p_stk =(OS_STK)0x41F80000u; /* S31 */ *--p_stk =(OS_STK)0x41F00000u; /* S30 */ *--p_stk =(OS_STK)0x41E80000u; /* S29 */ *--p_stk =(OS_STK)0x41E00000u; /* S28 */ *--p_stk = (OS_STK)0x41D80000u; /* S27 */ *--p_stk =(OS_STK)0x41D00000u; /* S26 */ *--p_stk = (OS_STK)0x41C80000u; /* S25 */ *--p_stk =(OS_STK)0x41C00000u; /* S24 */ *--p_stk =(OS_STK)0x41B80000u; /* S23 */ *--p_stk =(OS_STK)0x41B00000u; /* S22 */ *--p_stk =(OS_STK)0x41A80000u; /* S21 */ *--p_stk =(OS_STK)0x41A00000u; /* S20 */ *--p_stk =(OS_STK)0x41980000u; /* S19 */ *--p_stk =(OS_STK)0x41900000u; /* S18 */ *--p_stk =(OS_STK)0x41880000u; /* S17 */ *--p_stk =(OS_STK)0x41800000u; /* S16 */ *--p_stk =(OS_STK)0x41700000u; /* S15 */ *--p_stk =(OS_STK)0x41600000u; /* S14 */ *--p_stk =(OS_STK)0x41500000u; /* S13 */ *--p_stk =(OS_STK)0x41400000u; /* S12 */ *--p_stk =(OS_STK)0x41300000u; /* S11 */ *--p_stk =(OS_STK)0x41200000u; /* S10 */ *--p_stk =(OS_STK)0x41100000u; /* S9 */ *--p_stk =(OS_STK)0x41000000u; /* S8 */ *--p_stk =(OS_STK)0x40E00000u; /* S7 */ *--p_stk =(OS_STK)0x40C00000u; /* S6 */ *--p_stk =(OS_STK)0x40A00000u; /* S5 */ *--p_stk =(OS_STK)0x40800000u; /* S4 */ *--p_stk =(OS_STK)0x40400000u; /* S3 */ *--p_stk =(OS_STK)0x40000000u; /* S2 */ *--p_stk =(OS_STK)0x3F800000u; /* S1 */ *--p_stk = (OS_STK)0x00000000u; /* S0 */ } #endif return (p_stk); } 官方提供的这个堆栈初始化是错误的的,为什么是错误的?因为这个不符合浮点寄存器的入栈和出栈顺序。还有一部分代码在os_cpu_a.asm文件中,内容如下:
如果不理解为什么这个浮点寄存的入栈和出栈是错误的,需要认真学习一下第5章:任务切换设计。第5章对于这个问题有深入的讲解。 10.2 开启FPU解决方案 为了解决FPU的问题,有两个函数需要修改:一个是CPU_STK *OSTaskStkInit(),另一个是PendSV中断。 10.2.1 修改函数CPU_STK *OSTaskStkInit() 函数所在的位置如下:
下面是修改后的内容:
1. 这句话最重要,这里是将EXC_RETURN也进行了入栈处理。关于EXC_RETURN在前面4.2.5 特殊功能寄存器讲解。这里要补充一点,对于M4内核,EXC_RETURN的bit4也是有意义的。 当bit4 = 1时,8个寄存器自动入栈,还有8个寄存器需要手动入栈 当bit4 = 0时,18个浮点寄存器+8个寄存器自动入栈,还有16个浮点寄存器+8个寄存器需要手动入栈。 这些寄存器在第4章和第5章有详细的讲解,这里就不再赘述了。
10.2.2 修改函数OS_CPU_PendSVHandler 函数所在的位置如下:
PendSV中断需要修改的地方如下:
1. 通过检测EXC_RETURN(LR)的bit4来看这个任务是否使用了浮点寄存器,如果使用了需要将剩余的16个浮点寄存器入栈。 TST LR, #0x10: TST指令通常与EQ,NE条件码配合使用。当所有测试位均为0时,EQ有效。而只要有一个测试位不为0,则NE有效。这里LR和0x10的值按位作逻辑“与”操作。 IT EQ : 这里IT指令就是IF-THEN的缩写。IF‐THEN(IT)指令围起一个块,里面最多有4条指令,它里面的指令可以条件执行。 IT已经带了一个“T”,因此还可以最多再带3个“T”或者“E”。并且对T和E的顺序没有要求。其中T对应条件成立时执行的语句,E对应条件不成立时执行的语句。在If‐Then块中的指令必须加上条件后缀,且T对应的指令必须使用和IT指令中相同的条件,E对应的指令必须使用和IT指令中相反的条件。 IT的使用形式总结如下: IT IT IT IT 其中
这么说还不够形象,下面举一个简单的例子,用IT指令优化C伪代码: if(R0==R1) { R3= R4 + R5; R3= R3 / 2; } else { R3= R6 + R7; R3= R3 / 2; } 可以写作: CMP R0, R1 ; 比较R0和R1 ITTEEEQ ; 如果R0== R1, Then-Then-Else-Else ADDEQR3,R4, R5 ; 相等时加法 ASREQR3,R3, #1 ; 相等时算术右移 ADDNER3,R6, R7 ; 不等时加法 ASRNER3,R3, #1 ; 不等时算术右移 有了上面这些基础知识后再看下面的指令。 VSTMDBEQ R0!, {S16-S31}: 结合上面的IT EQ,这里的意思就是 if LR & 0x10 == 0 then VSTMDB R0!, {S16-S31}。也就是咱们前面所说的如果EXC_RETURN(LR)的bit4= 0就表示使用浮点寄存器了,这里需要入栈。 2. 这里比较好理解,只不过也将EXC_RETURN进行了入栈。 3. 参考上面的第二条,只不过这里是出栈。 4. 参考上面的第一条,只不过这里是出栈。 10.2.3 开启FPU 修改了上面的两个地方后别忘了开启FPU: |
1033 浏览 0 评论
2877 浏览 0 评论
图腾柱PFC无法上升至400V,且电感电流为正弦波形,但是幅值极小
9386 浏览 0 评论
飞凌嵌入式ElfBoard-Vim编辑器之静态链接和动态链接
2898 浏览 0 评论
使用 LinkBoy 将程序导出为 C 语言代码并烧录至 Arduino ESP32 开发板
2302 浏览 1 评论
/9
GMT+8, 2025-12-2 08:46 , Processed in 0.707836 second(s), Total 68, Slave 49 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
