扫一扫,分享给好友
`我用的是PIC24FJ128GA006 时钟老是比正常时间慢,我觉得是时钟配置,或者是晶振的问题,大婶们帮忙看看,谢了 #include "p24FJ128GA006.h" _CONFIG1(JTAGEN_OFF & GCP_OFF & GWRP_OFF & COE_OFF & FWDTEN_OFF & ICS_PGx2) _CONFIG2(FCKSM_CSDCMD & OSCIOFNC_OFF & POSCMOD_HS & FNOSC_SOSC) typedef union tagRTCC { struct { unsigned char sec; unsigned char min; unsigned char hr; unsigned char wkd; unsigned char day; unsigned char mth; unsigned char yr; }; struct { unsigned int prt00; unsigned int prt01; unsigned int prt10; unsigned int prt11; }; } RTCC; RTCC _time; RTCC _time_chk; // macro #define mRTCCDec2Bin(Dec) (10*(Dec>>4)+(Dec&0x0f)) #define mRTCCBin2Dec(Bin) (((Bin/10)<<4)|(Bin%10)) void RTCCgrab(void); void RTCCInit(void); void RTCCSet(void); void RTCCUnlock(void); void RTCCCalculateWeekDay(void); void display(unsigned char x); // main int main(void) { RTCCInit(); // initialization includes set the time and date while (1) { RTCCgrab(); // grab once display(_time_chk.sec); } } void display(unsigned char x) { TRISE=0x00; LATE=x; } void RTCCgrab(void) { // Process time object only if time is not being set // Grab the time RCFGCALbits.RTCPTR = 3; _time.prt11 = RTCVAL; _time.prt10 = RTCVAL; _time.prt01 = RTCVAL; _time.prt00 = RTCVAL; // Grab the time again RCFGCALbits.RTCPTR = 3; _time_chk.prt11 = RTCVAL; _time_chk.prt10 = RTCVAL; _time_chk.prt01 = RTCVAL; _time_chk.prt00 = RTCVAL; // Verify there is no roll-over if ((_time.prt00 == _time_chk.prt00) && (_time.prt01 == _time_chk.prt01) && (_time.prt10 == _time_chk.prt10) && (_time.prt11 == _time_chk.prt11)) { // Here, you can watch structure _time, // which has the data from RTCC registers. // TO DO: do something as you like here. } } void RTCCInit(void) { // Enables the LP OSC for RTCC operation asm("mov #OSCCON,W1"); // move address of OSCCON to W1 asm("mov.b #0x02, W0"); // move 8-bit literal to W0, 16-bit. asm("mov.b #0x46, W2"); // unlock byte 1 for OSCCONL(low byte) asm("mov.b #0x57, W3"); // unlock byte 2 for OSCCONL(low byte) // move 8-bit of Wn to OSCCON register asm("mov.b W2, [W1]"); // write unlock byte 1 asm("mov.b W3, [W1]"); // write unlock byte 2 asm("mov.b W0, [W1]"); // enable SOSCEN // Unlock sequence must take place for RTCEN to be written RCFGCAL = 0x0000; RTCCUnlock(); RCFGCALbits.RTCEN = 1; // bit15 //RTCC pin pad conected to RTCC second clock PADCFG1bits.RTSECSEL = 1; RCFGCALbits.RTCOE = 1; //RTCC Output Enable bit // TO DO: Write the time and date to RTCC as follow. _time_chk.sec = 0x00; _time_chk.min = 0x05; _time_chk.hr = 0x7; _time_chk.wkd = 0x2; _time_chk.day = 0x24; _time_chk.mth = 0x07; _time_chk.yr = 0x07; RTCCCalculateWeekDay(); // To calculate and confirm the weekday // Set it after you change the time and date. RTCCSet(); } void RTCCSet(void) { RTCCUnlock(); // Unlock the RTCC RCFGCALbits.RTCPTR = 3; // Set the time RTCVAL = _time_chk.prt11; // set year RTCVAL = _time_chk.prt10; // set month:day RTCVAL = _time_chk.prt01; // set week:hour RTCVAL = _time_chk.prt00; // set min:sec RCFGCALbits.RTCWREN = 0; // Lock the RTCC } void RTCCUnlock() { asm volatile("disi #5"); asm volatile("mov #0x55, w7"); // write 0x55 and 0xAA to asm volatile("mov w7, _NVMKEY"); // NVMKEY to disable asm volatile("mov #0xAA, w8"); // write protection asm volatile("mov w8, _NVMKEY"); asm volatile("bset _RCFGCAL, #13"); // set the RTCWREN bit asm volatile("nop"); asm volatile("nop"); } void RTCCCalculateWeekDay() { const char MonthOffset[] = //jan feb mar apr may jun jul aug sep oct nov dec { 0, 3, 3, 6, 1, 4, 6, 2, 5, 0, 3, 5 }; unsigned Year; unsigned Month; unsigned Day; unsigned Offset; // calculate week day Year = mRTCCDec2Bin(_time_chk.yr); Month = mRTCCDec2Bin(_time_chk.mth); Day = mRTCCDec2Bin(_time_chk.day); // 2000s century offset = 6 + // every year 365%7 = 1 day shift + // every leap year adds 1 day Offset = 6 + Year + Year/4; // Add month offset from table Offset += MonthOffset[Month-1]; // Add day Offset += Day; // If it's a leap year and before March there's no additional day yet if((Year%4) == 0) if(Month < 3) Offset -= 1; // Week day is Offset %= 7; _time_chk.wkd = Offset; } ` |
3个回答
有没有做过手册172页上说的 Calibration ?
唐辉电子,深耕晶振行业15年,非常专业,行业公认!
唐辉电子 官网上,有很多晶振使用、搭配、常见故障分析等方面的技术文档,欢迎分享。 真诚地希望和各位研发工程师长期互动、交友、携手进步。 32.768KHZ晶振,直插,贴片各种型号的,8M的,11.0592M,我司手里有现货, 少许样品,可免费给您。 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
【敏矽微ME32G070开发板免费体验】使用coremark测试敏矽微ME32G070 跑分
148 浏览 0 评论
【敏矽微ME32G070开发板免费体验】开箱+点灯+点亮OLED
348 浏览 2 评论
558 浏览 0 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-内核编译之初次编译
252 浏览 0 评论
388 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
11973 浏览 31 评论
GMT+8, 2024-12-19 23:12 , Processed in 0.540562 second(s), Total 78, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
