如下两个代码,第一个是中断向量,第二个是中断设置,关于watchdog的中断
设置watchdog工作方式未定时器,然后间断的产生一个请求,之后再中断函数中清除 SUBSRCPND,SRCPND和INTPND,之后让LED亮,每一次中断,0x31000000地址的数据+1,然后判断它的最低有效位是否为0,如果是,选择style_1的方式亮,如果不为0,选择style_2的方式亮 现在我的问题是,我将程序加载到内存中后,uboot go 对应的地址后,发现中断处理程序无法正常返回到uboot的输入命令行,就卡再那里了,请问我的代码有错误吗 _____________________________向量_________________________________ b reset b undef b soft b resstop b datstop .word 0x00 .equ SUBSRCPND,0x4a000018 .equ SRCPND, 0x4a000000 .equ INTPND, 0x4a000010 .equ GPBCON,0x56000010 .equ GPBDAT, 0x56000014 .equ GPB5, (1<<(5*2)) .equ GPB6, (1<<(6*2)) .equ GPB7, (1<<(7*2)) .equ GPB8, (1<<(8*2)) .equ GPBVALUE, (GPB5|GPB6|GPB7|GPB8) .equ GPB5_DATA, (0<<5) .equ GPB6_DATA, (1<<6) .equ GPB7_DATA, (1<<7) .equ GPB8_DATA, (1<<8) .equ GPB5_DATA_T, (1<<5) .equ GPB6_DATA_T, (1<<6) .equ GPB7_DATA_T, (1<<7) .equ GPB8_DATA_T, (0<<8) .equ GPB_DATA, (GPB5_DATA|GPB6_DATA|GPB7_DATA|GPB8_DATA) .equ GPB_DATA_T, (GPB5_DATA_T|GPB6_DATA_T|GPB7_DATA_T|GPB8_DATA_T) b irq b firq reset: undef: soft: resstop: datstop: irq: clear_bit: ldr sp,=0x32000000 sub lr,lr,#4 stmfd sp!,{r0-r12,r14} ldr r0,=SUBSRCPND ldr r1,[r0] str r1,[r0] ldr r0,=INTPND ldr r1,=SRCPND ldr r2,[r0] str r2,[r1] str r2,[r0] feed_dog: led: ldr r0,=GPBCON ldr r1,=GPBVALUE str r1,[r0] ldr r4,=0x31000000 ldr r0,[r4] add r0,r0,#1 str r0,[r4] bic r0,r0,#0xfe cmp r0,#1 blt led_style_one beq led_style_two led_style_one: ldr r0,=GPBDAT ldr r1,=GPB_DATA str r1,[r0] b recover led_style_two: ldr r0,=GPBDAT ldr r1,=GPB_DATA_T str r1,[r0] b recover recover: ldmfd sp!,{r0-r12,pc}^ firq: _______________________________________________________________________________ ++++++++++++++++++++++++++++++++++中断设置+++++++++++++++++++++++++++++++++++++ .equ SRCPND,0X4A000000 .equ INTMOD,0X4A000004 .equ INTMSK,0X4A000008 .equ INTPND,0x4A000010 .equ SUBPND,0X4A000018 .equ SUBMSK,0x4A00001C .equ WTCON ,0X53000000 .equ WTDAT ,0X53000004 .equ WTCNT ,0X53000008 begin: stmfd sp!,{r0-r4,lr} ldr r0,=INTMSK mov r1,#0 str r1,[r0] ldr r0,=SUBMSK mov r1,#0 str r1,[r0] ldr r0,=WTCNT .equ WTCNT_DATA,0x8000 ldr r1,=WTCNT_DATA str r1,[r0] .equ fenpin,((0x80)<<8) .equ wtg_en,((1)<<5) .equ time_select,((0)<<3) .equ irq_en,((1)<<2) .equ reset_en,0 .equ WTCON_DATA, (fenpin|wtg_en|time_select|irq_en|reset_en) ldr r0,=WTCON ldr r1,=WTCON_DATA str r1,[r0] ldmfd sp!,{r0-r4,pc} |
1个回答
编译看看啊,相信编译器
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
飞凌嵌入式ElfBoard-文件I/O的深入学习之阻塞I/O与非阻塞I/O
307 浏览 0 评论
大神们,想知道你们都用什么ide编程调试器? Arduino IDE?还是 e2studio ?还有其他吗?哪个好用呢
459 浏览 0 评论
825 浏览 0 评论
790 浏览 0 评论
飞凌嵌入式ElfBoard-文件I/O的了解探究之复制文件描述符
717 浏览 0 评论
/9
GMT+8, 2025-12-2 06:52 , Processed in 0.566249 second(s), Total 73, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
977
