扫一扫,分享给好友
[size=14.4444446563721px]这是BMA250传感器,G_SDA_Read 读出来一直为1,请大家帮忙看看是哪里写错了,这个传感器在51单片机试验过可以用的,硬件连线也测过,还是找不出是怎么回事?
#ifndef BMA250_H #define BMA250_H //#include "intrins.h" #define uchar unsigned char #define uint unsigned int #define nop Delay_Nop(2) #define G_SDA PC_ODR_bit.ODR0 #define G_SDA_Read PC_IDR_bit.IDR0 #define G_SCL PC_ODR_bit.ODR1 unsigned char SensorFirstFlag=1,StepUpFlag=0; uchar rMode=0; uchar XData=0; uchar YData=0; uchar ZData=0; uchar XMode=0; uchar YMode=0; uchar ZMode=0; uint SquareSum=0,SquareSumBuf1=0,SquareSumBuf2=0,AvgSquareSum=0; uint SquareSumBuf3=0,SquareSumBuf4=0; //A=X方+Y方+Z方的平方和 uint BN1=0,BN2=0,TestData=0, MeasureUpCnt=0,StepCnt=0,MeasureDownCnt=0; /**************** BMA250加速度传感器实现 ***********************************************************/ void Delay_Nop(unsigned int Nop_Sec) { unsigned int Nop_i = 0; while(Nop_Sec--) { for(Nop_i = 0;Nop_i <10; Nop_i++) ; } } //系统时钟源,快时钟和慢,分频,模式选择 //void FAST_CLK(void) //{ // STPFCK=0; //Set 1 to stop Fast clock for power saving in Slow/Idle mode. // //This bit can be changed only in Slow mode. // _nop_(); // _nop_(); // _nop_(); // SELFCK=1; //Select Fast Clock as System clock source // _nop_(); // _nop_(); // _nop_(); // //TR0=0; // //TEST=1; //} //软件延时 void DelayB(uint n) { uint i,j; for(j=n;j>0;j--) {for(i=500;i>0;i--) { } } } //BMA250 IO初始化 void BMAIO_Init() { PC_DDR_bit.DDR0 = 1; //PC.0,G_SDA初始化 PC_CR1_bit.C10 = 1; PC_CR2_bit.C20 = 1; PC_DDR_bit.DDR1 = 1; //PC.1,G_SCL初始化 PC_CR1_bit.C11 = 1; PC_CR2_bit.C21 = 1; G_SDA = 1; G_SCL = 1; } //I2C起始信号 void Start_GSensor() { G_SCL=1; G_SDA=1; nop; nop; nop; G_SDA=0; nop; nop; G_SCL=0; nop; nop; } //I2C停止信号 void Stop_GSensor() { G_SDA=0; nop; nop; G_SCL=1; nop; nop; nop; G_SDA=1; nop; nop; DelayB(3); } //I2C从机应答 void ACKS() { // uint i=0; // P2|=0x08;//SDA(P2.3)为输入 // P2OE&=~0x08; G_SDA=0; nop; G_SCL=1; nop; nop; nop; // //等待应答 // while((G_SDA==1)&&(i<255)) // i++; G_SCL=0; nop; G_SDA=1; // P2OE|=0x08; // P2|=0x08; } //I2C主机应答 void ACKM(void) { G_SDA=0; nop; G_SCL=1; nop; nop; nop; G_SCL=0; nop; G_SDA=1; } //告诉从机接收完毕 void NACK(void) { G_SDA=1; nop; G_SCL=1; nop; nop; nop; G_SCL=0; nop; G_SDA=0; } //I2C写入一个字节 void Write_GSensor(uchar t) { uchar BitCnt; for (BitCnt=0;BitCnt<8;BitCnt++) { if((t< G_SDA=1; } else { G_SDA=0; } G_SCL=1; nop; G_SCL=0; nop; } ACKS(); } //I2C读出字节 uchar Read_GSensor(void) { uchar BitCnt; uchar ReadData=0; G_SDA = 1; PC_DDR_bit.DDR0 = 0; PC_CR2_bit.C20 = 0; Delay_Nop(4); G_SCL=0; ReadData=0; Delay_Nop(4); for(BitCnt=0;BitCnt<8;BitCnt++) { G_SCL=1; Delay_Nop(4); ReadData<<=1; if(G_SDA==1) { ReadData|=1; } G_SCL=0; Delay_Nop(4); } PC_DDR_bit.DDR0 = 1; PC_CR2_bit.C20 = 1; return ReadData; } //写寄存器 void WriteG_Reg(uchar reg_addr,uchar reg_data) { Start_GSensor(); Write_GSensor(0x30); //I2C从设备地址 Write_GSensor(reg_addr); Write_GSensor(reg_data); Stop_GSensor(); } ////读寄存器 //uchar ReadG_Reg(uchar reg_addr) //{ // uchar date; // Start_GSensor(); // Write_GSensor(0x30); // ACKS(); // Write_GSensor(reg_addr); // ACKS(); // Start_GSensor(); // Write_GSensor(0x31); // ACKS(); // date=Read_GSensor(); // NACK(); // Stop_GSensor(); // return date; //} //BMA250传感器复位 void ResetGSensor(void) { WriteG_Reg(0x14,0xb6); //使能复位寄存器 DelayB(180); } //BMA250加速度传感器寄存器初始化 void SetGSensorInit(void) { WriteG_Reg(0x0f,0x05); //设置加速度范围为+-4g WriteG_Reg(0x13,0x40); //设置数据采集及输出,高位寄存器由低位决定 WriteG_Reg(0x10,0x10); //设置数据过滤带宽为1000HZ WriteG_Reg(0x11,0x58); //为写一个寄存器电源模式寄存器,置为不延时,低电压模式,休眠50MS } //置BMA250 1S休眠状态 void SetGSensorSleep(void) { WriteG_Reg(0x11,0x5e); //设置电源模式寄存器值为0x5e,不延迟模式,低功耗运行,休眠时间为1s } //置BMA250 50MS工作状态 void SetGSensorWakeup(void) { WriteG_Reg(0x11,0x58); //为写一个寄存器电源模式寄存器,置为不延时,低电压模式,休眠50MS } //读取BMA加速度数据值 void ReadAxesData(void) { Start_GSensor(); Write_GSensor(0x30); Write_GSensor(0x02); Start_GSensor(); Write_GSensor(0x31); XData=Read_GSensor(); ACKM(); XData=Read_GSensor(); ACKM(); YData=Read_GSensor(); ACKM(); YData=Read_GSensor(); ACKM(); ZData=Read_GSensor(); ACKM(); ZData=Read_GSensor(); NACK(); G_SDA=0; nop; nop; G_SCL=1; nop; nop; G_SDA=1; nop; nop; } uchar ReadMode(void) { Start_GSensor(); Write_GSensor(0x30); Write_GSensor(0x02); Start_GSensor(); Write_GSensor(0x31); XMode=Read_GSensor(); ACKM(); Read_GSensor(); ACKM(); YMode=Read_GSensor(); ACKM(); Read_GSensor(); ACKM(); ZMode=Read_GSensor(); ACKM(); Read_GSensor(); NACK(); G_SDA=0; nop; nop; G_SCL=1; nop; nop; G_SDA=1; nop; nop; XMode&=0x01; YMode&=0x01; ZMode&=0x01; if(XMode||YMode||ZMode) return 1; return 0; } //步数计算 void GetSquareSum(void) { if(XData & 0x80) XData=~XData+1; if(YData & 0x80) YData=~YData+1; if(ZData & 0x80) ZData=~ZData+1; SquareSum=XData*XData+YData*YData+ZData*ZData; } void CalcStep(void) { if(SensorFirstFlag) //第一次执行必须为1 { SquareSumBuf1=SquareSum; SquareSumBuf2=SquareSum; SquareSumBuf3=SquareSum; SquareSumBuf4=SquareSum; AvgSquareSum=SquareSum; SensorFirstFlag=0; } SquareSumBuf4=SquareSumBuf3; SquareSumBuf3=SquareSumBuf2; SquareSumBuf2=SquareSumBuf1; SquareSumBuf1=SquareSum; SquareSum=SquareSumBuf1+SquareSumBuf2+SquareSumBuf3+SquareSumBuf4; SquareSum>>=2; BN1=AvgSquareSum; //前一个平方和Bn1的值 AvgSquareSum=SquareSum; //平方和Bn2的值 BN2=AvgSquareSum; TestData=BN1-BN2; //相减后的测试值 if(TestData&0x8000) // 如果是负的,表示Bn>Bn1 { TestData=~TestData+1; if(TestData>0x360) { if(TestData<0x750) //小于750H { MeasureUpCnt++;//上升次数增加 if(MeasureUpCnt==2) //如果连续上升2次,置上升标志,计1步 { StepUpFlag=1; StepCnt++; } } else { StepUpFlag=1; //大于750H,置上升标志,计1步 StepCnt++; } } } else //Bn-1>Bn的情况下,Step down { if(TestData>0x220) { if(TestData<0x580) { MeasureDownCnt++; if(MeasureDownCnt==2) StepUpFlag=0; MeasureUpCnt=0; } else { MeasureUpCnt=0; StepUpFlag=0; } } } } #endif #include"iostm8l152c6.h" #include #include "bma250.h" unsigned char Work16Hz = 0; unsigned char Temp = 0; void Delay_Test(unsigned int Test_Ms) { unsigned char t = 0; while(Test_Ms--) for(t = 0;t<250;t++) ; } void tiM1_init() { CLK_PCKENR2 |= 0x02; TIM1_IER = 0x00; //Disable timer1 interrupt TIM1_EGR = 0x01; //Update generation TIM1_PSCRH = 0x00; TIM1_PSCRL = 0x0F; TIM1_ARRH = 0xF4; //中断62500us 即16HZ TIM1_ARRL = 0x24; TIM1_CNTRH = 0xF4; TIM1_CNTRL = 0x24; TIM1_CR1 = 0x01; //counter enable TIM1_IER = 0x01; //Enable timer1 interrupt } #pragma vector=TIM1_OVR_UIF_vector __interrupt void TIM1_UPD_OVF_IRQHandler(void) { TIM1_SR1 &= ~0x01; Work16Hz = 1; // flagcalc = 1; } #define G_SDA PC_ODR_bit.ODR0 #define G_SDA_Read PC_IDR_bit.IDR0 #define G_SCL PC_ODR_bit.ODR1 main() { __disable_interrupt(); CLK_CKDIVR = 0x00; TIM1_init(); __enable_interrupt(); // BMA_Init(); BMAIO_Init(); DelayB(65); ResetGSensor(); nop; ResetGSensor(); nop; SetGSensorInit(); DelayB(30); Temp=1; Start_GSensor(); Write_GSensor(0x30); Write_GSensor(0x0f); Start_GSensor(); Write_GSensor(0x31); Temp=Read_GSensor(); // NACK(); Stop_GSensor(); Delay_Test(100); while(1) // 进入无限循环 { /* Start_GSensor(); Write_GSensor(0x30); Write_GSensor(0x02); Start_GSensor(); Write_GSensor(0x31); XData=Read_GSensor(); ACKM(); */ // ReadStep(); } } |
7个回答
下一个看看 谢谢楼主 学习一下
哦哦哦,学习学习,谢谢
好~~~~~~~~~~~~~~~~~~~~~~~~~~
已经解决问题了,是STM8L开发板上PC1口的电容导致的,这个模拟I2C是可以用的
能联系一下吗?正在做bma250、222相关的 |
多谢楼主!!!
BMA250EF现货,欢迎咨询Q:1169984850
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
969 浏览 0 评论
AD7686芯片不传输数据给STM32,但是手按住就会有数据。
954 浏览 2 评论
2066 浏览 0 评论
如何解决MPU-9250与STM32通讯时,出现HAL_ERROR = 0x01U
1162 浏览 1 评论
hal库中i2c卡死在HAL_I2C_Master_Transmit
1587 浏览 1 评论
GMT+8, 2024-11-22 10:36 , Processed in 0.736915 second(s), Total 85, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
