好像上电开机的时候会自己进中断?好像受什么东西干扰!!而且发送的数据很容易发送错误!概率比较大!不知道你遇到过没有????????
呵呵,一招就找到了。
#include "sys.h"
#include "delay.h" #include "usart.h" #include "lcd.h" #include "key.h" u8 USART1_TX_DAT_MENU1_CMD_BUF1[6]={0x01,0x02,0x03,0x04}; u8 flag=1; int main(void) { u8 i=0; u8 key_vable=0; delay_init(); //延时函数初始化 NVIC_Configuration(); //设置NVIC中断分组2:2位抢占优先级,2位响应优先级 uart_init(115200); //串口初始化为115200 lcd_init(); KEY_init(); clr_lcd(); while(1) { key_vable= KEY_Scan(); //键盘扫描 if(key_vable==KEY5_SURE) //如果key5按下就发送命令 { send_cmd_to_mainboard(USART1_TX_DAT_MENU1_CMD_BUF1); key_vable=0; } if((reecive_over_flag==1)) { clr_lcd(); //清屏 delay_ms(10); copy_data_to_LCD_dis(); //将接受buf中的数据copy到显示buf中 data_dis2(); //lcd的显示函数 reecive_over_flag=0; //清零接受完成标志 for(i=0;i<4;i++) //清零接受数据buf { usart1_r_dat_buf[i]=0; receive_dat[i]=0; //清零显示buf } } } } #include "sys.h" #include "usart.h" u8 usart1_r_dat_buf[4]={0}; u8 reecive_over_flag=0; void uart_init(u32 bound){ //GPIO端口设置 GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1|RCC_APB2Periph_GPIOA, ENABLE); //使能USART1,GPIOA时钟 //USART1_TX PA.9 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //PA.9 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出 GPIO_Init(GPIOA, &GPIO_InitStructure); //USART1_RX PA.10 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空输入 GPIO_Init(GPIOA, &GPIO_InitStructure); //Usart1 NVIC 配置 NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3 ;//抢占优先级3 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3; //子优先级3 NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道使能 NVIC_Init(&NVIC_InitStructure); //根据指定的参数初始化VIC寄存器 //USART 初始化设置 USART_InitStructure.USART_BaudRate = bound;//一般设置为9600; USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长为8位数据格式 USART_InitStructure.USART_StopBits = USART_StopBits_1;//一个停止位 USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶校验位 USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无硬件数据流控制 USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//收发模式 USART_Init(USART1, &USART_InitStructure); //初始化串口 USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//开启中断 USART_Cmd(USART1, ENABLE); //使能串口 } void USART1_IRQHandler(void) //串口1中断服务程序 { static unsigned char i=0,j=0; if(USART_GetITStatus(USART1, USART_IT_RXNE)==SET) //接收中断 { USART_ClearITPendingBit(USART1,USART_IT_RXNE); if(i>3) { i=0; } usart1_r_dat_buf[i] =USART1->DR; i++; reecive_over_flag=1; } if(USART_GetFlagStatus(USART1,USART_FLAG_ORE) == SET) //溢出 { USART_ClearFlag(USART1,USART_FLAG_ORE); //读 SR USART_ReceiveData(USART1); //读 DR } } void send_cmd_to_mainboard(u8 *send_cmd_buf) { unsigned char t=0; USART_ClearFlag(USART1,USART_FLAG_TC); for(t=0;t<4;t++) { USART_SendData(USART1, send_cmd_buf[t]); //向串口2发送数据 while(USART_GetFlagStatus(USART1,USART_FLAG_TC)!=SET);//等待发送结束 } } 另外一个开发板的程序和这个差不多!!! 你能把你的QQ留下吗???谢谢 |
919 浏览 0 评论
797 浏览 0 评论
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
4560 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
3369 浏览 1 评论
stm32用fsmc读取ad7606采集数据,数据不变,只有开发版复位才更新数据
2672 浏览 0 评论
/9
GMT+8, 2025-12-11 08:46 , Processed in 0.969488 second(s), Total 79, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
