扫一扫,分享给好友
过配置 ARR=0xfffff PSC=72-1. 也就是1M捕获 当我去测15HZ到50KHZ 时候,测出来数据没有问题,精度也差不多在1%。 问题是 当频率达到50KHZ以上的时候,根本无法测量,频率跳变,检测出来的数字还很奇怪 66666HZ .等等 理论上不是1M捕获 最大能测1M 最小15HZ吗 为什么我就测不出来,!!!急死我了!! void tiM4_PWMINPUT_INIT(u16 arr,u16 psc) { TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; NVIC_InitTypeDef NVIC_InitStructure; TIM_ICInitTypeDef TIM4_ICInitStructure; GPIO_InitTypeDef GPIO_InitStructure; RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE); //Open TIM4 clock RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE); //open gpioB clock GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7; //GPIO?? GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOB, &GPIO_InitStructure); TIM_TimeBaseStructure.TIM_Period = arr; //设置在下一个更新事件装入活动的自动重装载寄存器周期的值 TIM_TimeBaseStructure.TIM_Prescaler =psc; //设置用来作为TIMx时钟频率除数的预分频值 TIM_TimeBaseStructure.TIM_ClockDivision = 0; //设置时钟分割:TDTS = Tck_tim TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //TIM向上计数模式 TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure); //根据TIM_TimeBaseInitStruct中指定的参数初始化TIMx的时间基数单位 /*配置中断优先级*/ NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); TIM4_ICInitStructure.TIM_Channel = TIM_Channel_2; TIM4_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising; TIM4_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI; TIM4_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1; TIM4_ICInitStructure.TIM_ICFilter = 0x0; TIM_PWMIConfig(TIM4, &TIM4_ICInitStructure); //PWM输入配置 TIM_SelectInputTrigger(TIM4, TIM_TS_TI2FP2); //选择有效输入端 TIM_SelectSlaveMode(TIM4, TIM_SlaveMode_Reset); //配置为主从复位模式 TIM_SelectMasterSlaveMode(TIM4, TIM_MasterSlaveMode_Enable); TIM_ITConfig(TIM4, TIM_IT_CC2|TIM_IT_Update, ENABLE); //中断配置 TIM_ClearITPendingBit(TIM4, TIM_IT_CC2|TIM_IT_Update); //清除中断标志位 TIM_Cmd(TIM4, ENABLE); } u16 period = 0; u16 duty = 0; u8 CollectFlag = 1; void TIM4_IRQHandler(void) { if(CollectFlag){ if (TIM_GetITStatus(TIM4, TIM_IT_CC2) != RESET)//捕获1发生捕获事件 { duty = TIM_GetCapture1(TIM4); //采集占空比 period=TIM_GetCapture2(TIM4); //采集周期 } } TIM_ClearITPendingBit(TIM4, TIM_IT_CC2|TIM_IT_Update); //清除中断标志位 } |
相关推荐 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
2797 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
2403 浏览 1 评论
stm32用fsmc读取ad7606采集数据,数据不变,只有开发版复位才更新数据
2276 浏览 0 评论
2388 浏览 1 评论
1637 浏览 1 评论
/9
GMT+8, 2025-12-2 00:10 , Processed in 1.101673 second(s), Total 70, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3945
