扫一扫,分享给好友
程
#include "msp430g2553.h" #define high 1 #define low 0 /*************Pin Define***************/ #define SCL_l P1OUT&=~BIT0 #define SCL_h P1OUT|=BIT0 //SCL接P1.0 #define SDA_l P1OUT&=~BIT1 #define SDA_h P1OUT|=BIT1 //SCL接P1.1 //***it SCL=P1^0; //***it SDA=P1^1; /****************************************************/ void Initial_LY096BG30(); //#define ulong unsigned long //void Delay_50ms(unsigned int Del_50ms); //void Delay_1ms(unsigned int Del_1ms); #define CPU_F ((double)1048000) #define delay_ms(x) __delay_cycles((long)(CPU_F*(double)x/1000.0)) //#define delay_ms(x) __delay_cycles((ulong)x*1000) void fill_picture(unsigned char fill_Data); void Picture_1(); void IIC_Start(); void IIC_Stop(); void Write_IIC_Command(unsigned char IIC_Command); void Write_IIC_Data(unsigned char IIC_Data); void Write_IIC_Byte(unsigned char IIC_Byte); /***********************Initial code*********************/ void Initial_LY096BG30() { Write_IIC_Command(0xAE); //display off Write_IIC_Command(0x20); //Set Memory Addressing Mode Write_IIC_Command(0x10); //00,Horizontal Addressing Mode;01,Vertical Addressing Mode;10,Page Addressing Mode (RESET);11,Invalid Write_IIC_Command(0xb0); //Set Page Start Address for Page Addressing Mode,0-7 Write_IIC_Command(0xc8); //Set COM Output Scan Direction Write_IIC_Command(0x00);//---set low column address Write_IIC_Command(0x10);//---set high column address Write_IIC_Command(0x40);//--set start line address Write_IIC_Command(0x81);//--set contrast control register Write_IIC_Command(0x7f); Write_IIC_Command(0xa1);//--set segment re-map 0 to 127 Write_IIC_Command(0xa6);//--set normal display Write_IIC_Command(0xa8);//--set multiplex ratio(1 to 64) Write_IIC_Command(0x3F);// Write_IIC_Command(0xa4);//0xa4,Output follows RAM content;0xa5,Output ignores RAM content Write_IIC_Command(0xd3);//-set display offset Write_IIC_Command(0x00);//-not offset Write_IIC_Command(0xd5);//--set display clock divide ratio/oscillator frequency Write_IIC_Command(0xf0);//--set divide ratio Write_IIC_Command(0xd9);//--set pre-charge period Write_IIC_Command(0x22); // Write_IIC_Command(0xda);//--set com pins hardware configuration Write_IIC_Command(0x12); Write_IIC_Command(0xdb);//--set vcomh Write_IIC_Command(0x20);//0x20,0.77xVcc Write_IIC_Command(0x8d);//--set DC-DC enable Write_IIC_Command(0x14);// Write_IIC_Command(0xaf);//--turn on oled panel } /***********************Picture Code**************************/ unsigned char show1[]= { 0x00,0x06,0x0A,0xFE,0x0A,0xC6,0x00,0xE0,0x00,0xF0,0x00,0xF8,0x00,0x00,0x00,0x00, 0x00,0x00,0xFE,0x7D,0xBB,0xC7,0xEF,0xEF,0xEF,0xEF,0xEF,0xEF,0xEF,0xC7,0xBB,0x7D, 0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08, 0x0C,0xFE,0xFE,0x0C,0x08,0x20,0x60,0xFE,0xFE,0x60,0x20,0x00,0x00,0x00,0x78,0x48, 0xFE,0x82,0xBA,0xBA,0x82,0xBA,0xBA,0x82,0xBA,0xBA,0x82,0xBA,0xBA,0x82,0xFE,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0xFF, 0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0xFF,0xFF,0x00,0x00,0xFE,0xFF,0x03, 0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0xFF,0xFE,0x00,0x00,0x00,0x00,0xC0,0xC0, 0xC0,0x00,0x00,0x00,0x00,0xFE,0xFF,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03, 0xFF,0xFE,0x00,0x00,0xFE,0xFF,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0xFF, 0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0x00,0x00,0xFF,0xFF,0x0C, 0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0xFF,0xFF,0x00,0x00,0x00,0x00,0xE1,0xE1, 0xE1,0x00,0x00,0x00,0x00,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0xFF,0xFF,0x00,0x00,0xFF,0xFF,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0x0C,0xFF, 0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0x1F, 0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x1F,0x0F,0x00,0x00,0x0F,0x1F,0x18, 0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x1F,0x0F,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x0F,0x1F,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18, 0x1F,0x0F,0x00,0x00,0x0F,0x1F,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x18,0x1F, 0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0xE2,0x92,0x8A,0x86,0x00,0x00,0x7C,0x82,0x82,0x82,0x7C, 0x00,0xFE,0x00,0x82,0x92,0xAA,0xC6,0x00,0x00,0xC0,0xC0,0x00,0x7C,0x82,0x82,0x82, 0x7C,0x00,0x00,0x02,0x02,0x02,0xFE,0x00,0x00,0xC0,0xC0,0x00,0x7C,0x82,0x82,0x82, 0x7C,0x00,0x00,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x24,0xA4,0x2E,0x24,0xE4,0x24,0x2E,0xA4,0x24,0x00,0x00,0x00,0xF8,0x4A,0x4C, 0x48,0xF8,0x48,0x4C,0x4A,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x20,0x10,0x10, 0x10,0x10,0x20,0xC0,0x00,0x00,0xC0,0x20,0x10,0x10,0x10,0x10,0x20,0xC0,0x00,0x00, 0x00,0x12,0x0A,0x07,0x02,0x7F,0x02,0x07,0x0A,0x12,0x00,0x00,0x00,0x0B,0x0A,0x0A, 0x0A,0x7F,0x0A,0x0A,0x0A,0x0B,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0x20,0x40,0x40, 0x40,0x50,0x20,0x5F,0x80,0x00,0x1F,0x20,0x40,0x40,0x40,0x50,0x20,0x5F,0x80,0x00, }; /********************************************** //IIC Start **********************************************/ void IIC_Start() { SCL_h; //Delay_us(1); SDA_h; //Delay_us(1); SDA_l; // Delay_us(1); SCL_l; // Delay_us(1); } /********************************************** //IIC Stop **********************************************/ void IIC_Stop() { SCL_l; //Delay_us(1); SDA_l; //Delay_us(1); SCL_h; //Delay_us(1); SDA_h; //Delay_us(1); } /********************************************** // IIC Write byte **********************************************/ void Write_IIC_Byte(unsigned char IIC_Byte) { unsigned char i; for(i=0;i<8;i++) { if(IIC_Byte & 0x80) //1?0? SDA_h; else SDA_l; //Delay_us(1); SCL_h; //Delay_us(1); SCL_l; //Delay_us(1); IIC_Byte<<=1; //loop } SDA_h; //Delay_us(1); SCL_h; //Delay_us(1); SCL_l; //Delay_us(1); } /********************************************** // IIC Write Command **********************************************/ void Write_IIC_Command(unsigned char IIC_Command) { IIC_Start(); Write_IIC_Byte(0x78); //Slave address,SA0=0 Write_IIC_Byte(0x00); //write command Write_IIC_Byte(IIC_Command); IIC_Stop(); } /********************************************** // IIC Write Data **********************************************/ void Write_IIC_Data(unsigned char IIC_Data) { IIC_Start(); Write_IIC_Byte(0x78); Write_IIC_Byte(0x40); //write data Write_IIC_Byte(IIC_Data); IIC_Stop(); } /******************************************** // fill_Picture ********************************************/ void fill_picture(unsigned char fill_Data) { unsigned char m,n; for(m=0;m<8;m++) { Write_IIC_Command(0xb0+m); //page0-page1 Write_IIC_Command(0x00); //low column start address Write_IIC_Command(0x10); //high column start address for(n=0;n<128;n++) { Write_IIC_Data(fill_Data); } } } // picture /* void picture_1() { unsigned char x,y; unsigned int i=0; for(y=0;y<8;y++) { Write_IIC_Command(0xb0+y); Write_IIC_Command(0x00); Write_IIC_Command(0x10); for(x=0;x<128;x++) { Write_IIC_Data(show1[i++]); } } } */ /***********************Delay****************************************/ /*void Delay_50ms(unsigned int Del_50ms) { unsigned int m; for(;Del_50ms>0;Del_50ms--) for(m=6245;m>0;m--); } *//* void Delay_1ms(unsigned int Del_1ms) { unsigned char j; while(Del_1ms--) { for(j=0;j<123;j++); } }*/ /*******************************Main*******************************/ void main(void) { Initial_LY096BG30(); delay_ms(5); while(1) { fill_picture(0xff); delay_ms(1250); fill_picture(0xf0); delay_ms(1250); //Picture_1(); delay_ms(1250); } } 序如下,请大位大神帮忙指点指点 |
5个回答
同求!!!!!!!
哈哈哈 听说你是黄佳杰那个屌丝 |
黄佳杰是谁呀黄佳杰是谁呀
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
435 浏览 0 评论
464 浏览 0 评论
450 浏览 0 评论
806 浏览 0 评论
RT-Thread与英飞凌(infineon)合作得板子PSOC 6 板子学习
748 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
17021 浏览 31 评论
/9
GMT+8, 2025-12-12 17:48 , Processed in 0.731856 second(s), Total 83, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
665
