/********************************************************************************/ #include
#include typedef unsigned char unint8;
typedef unsigned char unint16; unsigned char str1[]={" "};
unsigned char str2[]={" "};
unsigned char code dis1[] = {"TRH RH: "};
unsigned char code dis2[] = {"TRH T: "}; ***it TRH = P2^0;//温湿度传感器DHT11数据接入
***it ST = P2^1;//状态显示,是为了方便调试,具体使用的时候可以不要
***it LCD_RS = P2^6;
***it LCD_RW = P2^5;
***it LCD_EN = P2^7; unint8 TH_data,TL_data,RH_data,RL_data,CK_data;
unint8 TH_temp,TL_temp,RH_temp,RL_temp,CK_temp;
unint8 com_data,untemp,temp;
unint8 respond; /*********************************************************************************/
void delayNOP()
_nop_();
_nop_();
_nop_();
_nop_();
// 毫秒级延时子程序
void delay_ms(unsigned char ms)
unsigned char i;
while(ms--)
for(i = 0; i< 150; i++)
_nop_();
_nop_();
_nop_();
_nop_();
//5us级延时程序
void delay_us()
unint8 i;
i--;
i--;
i--;
i--;
i--;
i--;
// 测试LCD忙碌状态
//lcd_busy()为1时,忙,等待。lcd_busy()为0时,闲,可写指令与数据。
bit lcd_busy()
bit result;
LCD_RS = 0;
LCD_RW = 1;
LCD_EN = 1;
delayNOP();
result = (bit)(P0&0x80);
LCD_EN = 0;
return(result);
// 写入指令数据到LCD
void lcd_wcmd(unsigned char cmd)
while(lcd_busy());
LCD_RS = 0;
LCD_RW = 0;
LCD_EN = 0;
_nop_();
_nop_();
P0 = cmd;
delayNOP();
LCD_EN = 1;
delayNOP();
LCD_EN = 0;
//写显示数据到LCD
//RS=高电平,RW=低电平,E=高脉冲,D0-D7=数据。
void lcd_wdata(unsigned char dat)
while(lcd_busy());
LCD_RS = 1;
LCD_RW = 0;
LCD_EN = 0;
P0 = dat;
delayNOP();
LCD_EN = 1;
delayNOP();
LCD_EN = 0;
//LCD初始化设定
void lcd_init()
delay_ms(15);
lcd_wcmd(0x38); //16*2显示,5*7点阵,8位数据
delay_ms(5);
lcd_wcmd(0x38);
delay_ms(5);
lcd_wcmd(0x38);
delay_ms(5);
lcd_wcmd(0x0c); //显示开,关光标
delay_ms(5);
lcd_wcmd(0x06); //移动光标
delay_ms(5);
//lcd_wcmd(0x01); //清除LCD的显示内容,如果屏幕过暗,可将这俩句删除
//delay_ms(5);
//设定LCD显示位置
void lcd_dis_pos(unsigned char pos)
lcd_wcmd(pos | 0x80); //数据指针=80+地址变量
//收发信号检测,数据读取
char receive()
unint8 i;
ST=0;
com_data=0;
for(i=0;i<=7;i++)
respond=2;
while((!TRH)&&respond++);
delay_us();
delay_us();
delay_us();
if(TRH)
temp=1;
respond=2;
while((TRH)&&respond++);
else
temp=0;
com_data<<=1;
com_data|=temp;
return(com_data);
//湿度读取子程序
//温度高8位== TL_data
//温度低8位== TH_data
//湿度高8位== RH_data
//湿度低8位== RH_data
//校验 8位 == CK_data
//调用的程序有 delay();, Delay_5us();,RECEIVE();
void read_TRH()
//主机拉低18ms
TRH=0;
delay_ms(18);
TRH=1;
//DATA总线由上拉电阻拉高 主机延时20us
delay_us();
delay_us();
delay_us();
delay_us();
//delay_us();
//delay_us();delay_us();delay_us();delay_us();
//主机设为输入 判断从机响应信号
TRH=1;
//判断DHT11是否有低电平响应信号 如不响应则跳出,响应则向下运行
if(!TRH)
respond=2;
//判断DHT11发出 80us 的低电平响应信号是否结束
while((!TRH)&& respond++);
respond=2;
//判断从机是否发出 80us 的高电平,如发出则进入数据接收状态
while(TRH && respond++);
//数据接收状态
RH_temp = receive();
RL_temp = receive();
TH_temp = receive();
TL_temp = receive();
CK_temp = receive();
TRH=1;ST=1;
//数据校验
untemp=(RH_temp+RL_temp+TH_temp+TL_temp);
if(untemp==CK_temp)
RH_data = RH_temp;
RL_data = RL_temp;
TH_data = TH_temp;
TL_data = TL_temp;
CK_data = CK_temp;
//湿度整数部分
str1[0] = (char)(0X30+RH_data/10);
str1[1] = (char)(0X30+RH_data%10);
str1[2] = 0x2e; //小数点
//湿度小数部分
str1[3] = (char)(0X30+RL_data/10);
str1[5] = 0X25; //"%"
str1[6] = 0X52; //"R"
str1[7] = 0X48; //"H"
//温度整数部分
str2[0] = (char)(0X30+TH_data/10);
str2[1] = (char)(0X30+TH_data%10);
str2[2] = 0x2e; //小数点
//温度小数部分
str2[3] = (char)(0X30+TL_data/10);
str2[5] = 0X27; //"'"
str2[6] = 0X43; //"C"
//主函数
//TH,TL,RH,RL分别代表温湿度的整数和小数部分
void main()
unsigned char i,n=0x40,m;
lcd_init();
delay_us();
while(1)
read_TRH();
//写字符
for(i=0;i<=7;i++)
lcd_dis_pos(i); //显示字符
lcd_wdata(dis1);
lcd_dis_pos(n+i); //显示字符
lcd_wdata(dis2);
//写湿度数据
m=0x08;
for(i=0;i<=7;i++)
lcd_dis_pos(m);
lcd_wdata(str1);
m++;
//写温度数据
m=0x48;
for(i=0;i<=7;i++)
lcd_dis_pos(m);
lcd_wdata(str2);
m++;
//延时
delay_ms(1000) ;
