扫一扫,分享给好友
![]() ![]() ![]() 各位大神,LCD1602为何在仿真上能显示,在硬件上不能显示,求助啊。。。 线路连接没有问题,也不存在背光问题。。。, 各位大神,帮我支支招。。。 程序如下: #include #include #define uchar unsigned char #define ulong unsigned long #define uint unsigned int uchar idata welcome[16]={" clock "}; //定义第一行显示数组 uchar idata lwelcome[16]={" clock "}; //定义第一行显示数组 uchar idata llwelcome[16]={" clock "}; //定义第一行显示数组 uchar idata lllwelcome[16]={" clock "}; //定义第一行显示数组 uchar idata sslcdtimer[16]={" 00:00:00 "}; uchar idata tsslcdtimer[16]={" 00:00:00 "}; uchar idata lcdtimer[16]={" 00:00:00 "}; //定义第二行显示数组 uchar idata mlcdtimer[16]={" 00: : "}; //定义第二行显示数组 uchar idata hlcdtimer[16]={" :00: "}; //定义第二行显示数组 uchar idata setlcdtimer[16]={" 00:01:00 "}; uchar timecount; uchar temps; bit timeflag; bit sstimeflag; ***it ring=P2^0;//蜂鸣闹铃 ***it e=P2^7;//LCD显示器E ***it rw=P2^6;//LCD显示器RW ***it rs=P2^5;//LCD显示器RS ***it P10=P1^0; //测试用闪灯 ***it Key=P3^2;//秒表暂停,清零 ***it Key0=P3^3;//调时,设定闹钟时间,秒表选择 ***it Key1=P3^4;//调时,设定闹钟时间改变 uchar th1_f; //在中断中装载的T0的值高8位 uchar tl1_f; //在中断中装载的T0的值低8位 uint m=0; uint n=0; ulong i; uint f=0,g=1; uint j,k; uchar code freq[3][14]= { {0xF2,0x42, 0xF3,0xC1, 0xF5,0x17, 0xF5,0xB6, 0xF6,0xD0, 0xF7,0xD1, 0xF8,0xB6}, {0xF9,0x21, 0xF9,0xE0, 0xFA,0x8B, 0xFA,0xD7, 0xFB,0x68, 0xFB,0xE8, 0xFC,0x5B }, {0xFC,0x8D, 0xFC,0xEE, 0xFD,0x44, 0xFD,0x6D, 0xFD,0xB4, 0xFD,0xF4, 0xFE,0x2D}, }; //音乐频率表,低音,中音,高音,系统振荡频率11.0592MHz uint code song1[]={26,25,23,25,31,26,25,26,23,25,26,25,23,22,21,16,25,23,22,22,23,23,23,26,23,22,21,25,23,22,21,16,21,15,26,25,23,25,31,26,25,26,23,25,26,25,23,22,21,16,25,23,22,22,23,23,23,26,23,22,21,25,23,22,21,16,21,15}; //编制音乐 //************************************************** //软件延时函数(系统晶振为11.0592MHz),延时时间约为40μs //入口条件:无符号整型变量del1,最终的延时时间为(del1*40)μs //************************************************** void delay(uint del1) { uchar del2; for(;del1>0;del1--) for(del2=10;del2>0;del2--); } //************************************************** //液晶显示器判忙函数 //************************************************** void busy() { uchar temp; temp=0x00; rs=0; rw=1; while((temp&0x80)==0x80) { P0=0xff; e=1; temp=P0; e=0; } } //************************************************** //向液晶显示器写命令函数 //************************************************** void WR_Com(uchar temp) { busy(); rs=0; rw=0; P0=temp; e=1; e=0; } //************************************************** //向液晶显示器写数据函数 //************************************************** void WR_Data(uchar num) { busy(); rs=1; rw=0; P0=num; e=1; e=0; } //************************************************** //向液晶显示器写入显示数据函数 //入口条件:液晶显示器行首地址(指示第一行还是第二行)和待显示数组的首地址 //************************************************** //void disp_lcdchar(uchar addr,uchar temp1) //{ // WR_Com(addr); // delay(100); // WR_Data(temp1); //} void disp_lcd(uchar addr,uchar *temp1) { uchar i; WR_Com(addr); delay(100); for(i=0;i<16;i++) { WR_Data(temp1); delay(100); } } //************************************************** //液晶显示器初始化函数 //************************************************** void lcd_ini() { char i; for(i=3;i>0;i--) { P0=0x30; rs=0; rw=0; e=1; e=0; delay(100); } P0=0x38; rs=0; rw=0; e=1; e=0; delay(100); } //************************************************** //液晶显示器复位函数 //************************************************** void lcd_Reset() { WR_Com(0x01); delay(100); WR_Com(0x06); delay(100); WR_Com(0x0c); delay(100); } //************************************************** //外部中断函数,秒表暂停,清零 //************************************************** void modess() interrupt 0 using 0 { delay(10000); n++; if(n==3) n=0; } //************************************************** //外部中断函数,模式选择 //************************************************** void modepp() interrupt 2 using 1 { delay(30000); m++; if(m==6) n=0; if(m==7) m=0; } //************************************************** //定时/计数器中断函数,1S及0.01S //************************************************** void timer0() interrupt 1 using 2 { TH0=0xdc; TL0=0x23; sstimeflag=1; if(--timecount==0) { timecount=100; timeflag=1; } } //************************************************** //定时/计数器中断函数,装入音乐频率计数初值 //************************************************** void timer1() interrupt 3 using 3 { TL1=tl1_f;TH0=th1_f; //调入预定时值 ring=!ring; //取反音乐输出IO } //************************************************** //主函数 //************************************************** void main() { P10=1; lcd_ini(); lcd_Reset(); /* for(i=0;i<10;i++) { temps=welcome; disp_lcdchar(0x80+1,temps); //LCD 单字符从左到右显示 delay(10000); }*/ disp_lcd(0x80,welcome); delay(10000); disp_lcd(0x80,lwelcome); delay(10000); disp_lcd(0x80,llwelcome); delay(10000); disp_lcd(0x80,lllwelcome); delay(10000); disp_lcd(0x80,llwelcome); delay(10000); disp_lcd(0x80,lwelcome); delay(10000); disp_lcd(0x80,welcome); //LCD滚动显示 delay(10000); disp_lcd(0xc0,lcdtimer); P10=0; TMOD=0x11; TH0=0xdc; TL0=0x23; TR0=1; IE=0x86; timeflag=0; //1秒计时标志 sstimeflag=0; //0.01秒计时标志 timecount=100; while(1) { while(m==6)//秒表 { IE=0x87; if(n==0) //秒表跑动 { if(sstimeflag==1) { sstimeflag=0; sslcdtimer[11]+=1; if(sslcdtimer[11]>=0x3a) { sslcdtimer[11]=0x30; sslcdtimer[10]+=1; if(sslcdtimer[10]>=0x3a) { sslcdtimer[10]=0x30; sslcdtimer[8]+=1; if(sslcdtimer[8]>=0x3a) { sslcdtimer[8]=0x30; sslcdtimer[7]+=1; if(sslcdtimer[7]>=0x36) { sslcdtimer[7]=0x30; } } } } disp_lcd(0xc0,sslcdtimer); } if(n==1)//秒表暂停 { disp_lcd(0xc0,sslcdtimer); } if(n>=2)//秒表清零 { disp_lcd(0xc0,tsslcdtimer); for(i=0;i<16;i++) sslcdtimer=tsslcdtimer; } } } while(m==0||m>=3) //时钟程序,只要不是调时,就一直运行 { IE=0x86; if(timeflag==1) { timeflag=0; lcdtimer[11]+=1; if(lcdtimer[11]>=0x3a) { lcdtimer[11]=0x30; lcdtimer[10]+=1; if(lcdtimer[10]>=0x36) { lcdtimer[10]=0x30; lcdtimer[8]+=1; if(lcdtimer[8]>=0x3a) { lcdtimer[8]=0x30; lcdtimer[7]+=1; if(lcdtimer[7]>=0x36) { lcdtimer[7]=0x30; lcdtimer[5]+=1; if(lcdtimer[5]>=0x3a) { lcdtimer[5]=0x30; lcdtimer[4]+=1; if(lcdtimer[4]>=0x33&&lcdtimer[5]>=0x35) { lcdtimer[5]=0x30; lcdtimer[4]=0x30; } } } } } } } if(m==0) { disp_lcd(0xc0,lcdtimer); if(!Key1)//关掉闹钟 { g=0; } if(lcdtimer[8]==setlcdtimer[8]&&lcdtimer[7]==setlcdtimer[7]&&lcdtimer[5]==setlcdtimer[5]&&lcdtimer[4]==setlcdtimer[4]) f=1; //开启闹钟 ,播放音乐 if(f&&g) { /*ring=1; delay(10000); ring=0; f=0; */ IE=0x8e; j=song1/10-1; k=2*(song1%10-1); th1_f=freq[j][k]; //取出对应的定时值送给T0 tl1_f=freq[j][++k]; TR1=1; for(n=0;n<50000;n++); //音符间延时 i++; TR1=0; f=0; } } } while(m==1) //调时分 { if(!Key1) { delay(10000); timeflag=0; lcdtimer[8]+=1; if(lcdtimer[8]>=0x3a) { lcdtimer[8]=0x30; lcdtimer[7]+=1; if(lcdtimer[7]>=0x36) { lcdtimer[7]=0x30; } } } disp_lcd(0xc0,lcdtimer); delay(8000); mlcdtimer[11]=lcdtimer[11]; mlcdtimer[10]=lcdtimer[10]; mlcdtimer[5]=lcdtimer[5]; mlcdtimer[4]=lcdtimer[4]; disp_lcd(0xc0,mlcdtimer); } while(m==2) //调时时 { if(!Key1) { delay(10000); lcdtimer[5]+=1; if(lcdtimer[5]>=0x3a) { lcdtimer[5]=0x30; lcdtimer[4]+=1; } if(lcdtimer[4]==0x32&&lcdtimer[5]>=0x34) { lcdtimer[5]=0x30; lcdtimer[4]=0x30; } } disp_lcd(0xc0,lcdtimer); delay(8000); hlcdtimer[11]=lcdtimer[11]; hlcdtimer[10]=lcdtimer[10]; hlcdtimer[8]=lcdtimer[8]; hlcdtimer[7]=lcdtimer[7]; disp_lcd(0xc0,hlcdtimer); } while(m==3)//显示闹铃时间 { if(!Key1) { delay(10000); } disp_lcd(0xc0,setlcdtimer); } while(m==4) //调闹铃分 { if(!Key1) { delay(10000); setlcdtimer[8]+=1; if(setlcdtimer[8]>=0x3a) { setlcdtimer[8]=0x30; setlcdtimer[7]+=1; if(setlcdtimer[7]>=0x36) { setlcdtimer[7]=0x30; } } } disp_lcd(0xc0,setlcdtimer); delay(8000); mlcdtimer[11]=setlcdtimer[11]; mlcdtimer[10]=setlcdtimer[10]; mlcdtimer[5]=setlcdtimer[5]; mlcdtimer[4]=setlcdtimer[4]; disp_lcd(0xc0,mlcdtimer); } while(m==5)//调闹铃时 { if(!Key1) { delay(10000); setlcdtimer[5]+=1; if(setlcdtimer[5]>=0x3a) { setlcdtimer[5]=0x30; setlcdtimer[4]+=1; } if(setlcdtimer[4]==0x32&&setlcdtimer[5]>=0x34) { setlcdtimer[5]=0x30; setlcdtimer[4]=0x30; } } disp_lcd(0xc0,setlcdtimer); delay(8000); hlcdtimer[11]=setlcdtimer[11]; hlcdtimer[10]=setlcdtimer[10]; hlcdtimer[8]=setlcdtimer[8]; hlcdtimer[7]=setlcdtimer[7]; disp_lcd(0xc0,hlcdtimer); } } |
3个回答
软件仿真不是万能,像你这个问题,只能自己去找,别人还真难帮到你的。
出现这样的问题,就要一个个排查,先从你的LCD函数看有没问题,看能不能有显示的时候再去加入你的闹钟之类的东西吧,个人感觉比较大的可能性是你的LCD的时序还不对。软件仿真时的时序跟硬件上的时序还是有小差别的,对照着规格书上的时序去排查吧 评分
一般是硬件问题 最好结合硬件原理图的方式进行查错
仿真和实际电路有时候是有区别的,不能完全依赖仿真判断设计是否正确;
你这个问题我判断是由于时序不能满足1602造成的,你每次在对R/W、E、RS操作后加一条或两条空操作,应该能解决问题。 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
265 浏览 0 评论
【原创】【RA4M2-SENSOR开发板评测】低功耗+USB综合测试
789 浏览 0 评论
1306 浏览 2 评论
787 浏览 0 评论
【RA4M2-SENSOR开发板评测】Analogue+Timers综合测试
1587 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
16903 浏览 31 评论
/9
GMT+8, 2025-12-2 13:44 , Processed in 0.837108 second(s), Total 78, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
20524
