扫一扫,分享给好友
void tiM2_IRQHandler(void)
{ TIM_ClearITPendingBit(TIM2, TIM_IT_Update); ADC_SoftwareStartConvCmd(ADC1,ENABLE); while(!(DMA_GetFlagStatus(DMA1_FLAG_TC1))); adc_current[i]=adc_value[0]; adc_voltagea[i]=adc_value[1]; adc_voltageb[i]=adc_value[2]; DMA_ClearFlag(DMA1_FLAG_TC1); ADC_SoftwareStartConvCmd(ADC1,DISABLE); i++; LED_on; if(i==7) { i=0; Max_cu=adc_current[0]; Min_cu=adc_current[0]; sum_cu=adc_current[0]; Max_voa=adc_voltagea[0]; Min_voa=adc_voltagea[0]; sum_voa=adc_voltagea[0]; Max_vob=adc_voltageb[0]; Min_vob=adc_voltageb[0]; sum_vob=adc_voltageb[0]; for(i=1;i<7;i++) { sum_cu=sum_cu+adc_current[i]; if(adc_current[i]>Max_cu) Max_cu=adc_current[i]; if(adc_current[i] if(adc_voltagea[i]>Max_voa) Max_voa=adc_voltagea[i]; if(adc_voltagea[i] if(adc_voltageb[i]>Max_vob) Max_vob=adc_voltageb[i]; if(adc_voltageb[i] adc_cu=(sum_cu-Max_cu-Min_cu)/5; adc_voa=(sum_voa-Max_voa-Min_voa)/5; adc_vob=(sum_vob-Max_vob-Min_vob)/5; i=0; } } void RCC_Configuration(void) { /* Enable Prefetch Buffer 设置预取缓冲器可以提高CPU的执行速度*/ FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable); /* Flash 2 wait state */ FLASH_SetLatency(FLASH_Latency_2); /* RCC system reset(for debug purpose) */ RCC_DeInit(); /* Enable HSE */ RCC_HSEConfig(RCC_HSE_ON); /* Wait till HSE is ready */ while (RCC_GetFlagStatus(RCC_FLAG_HSERDY) == RESET); //也可以用:while (!(RCC_WaitForHSEStartUp()== SUCCESS)); /* HCLK = SYSCLK */ RCC_HCLKConfig(RCC_SYSCLK_Div1); /* PCLK2 = HCLK */ RCC_PCLK2Config(RCC_HCLK_Div1); /* PCLK1 = HCLK/2 */ RCC_PCLK1Config(RCC_HCLK_Div2); /* PLLCLK = 8MHz * 9 = 72 MHz */ RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9); /* Enable PLL */ RCC_PLLCmd(ENABLE); /* Wait till PLL is ready */ while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET); /* Select PLL as system clock source */ RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); /* Wait till PLL is used as system clock source */ while(RCC_GetSYSCLKSource() != 0x08); /* Enable GPIOB clocks */ } void GPIO_Configuration(void) { GPIO_InitTypeDef GPIO_InitStructure; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2; //选择PX.10/11 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //管脚频率为50MHZ GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; //模式为推挽输出 GPIO_Init(GPIOC, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; //选择PX.10/11 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //管脚频率为50MHZ GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //模式为推挽输出 GPIO_Init(GPIOF, &GPIO_InitStructure); } //GPIO的配置设置,包括管脚、模式和频率 void NVIC_Configuration(void) { NVIC_InitTypeDef NVIC_InitStructure; NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1); NVIC_InitStructure.NVIC_IRQChannel=TIM2_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1; NVIC_InitStructure.NVIC_IRQChannelSubPriority=0; NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE; NVIC_Init(&NVIC_InitStructure); } void Timer2_Configuration(void) { TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_DeInit(TIM2); TIM_TimeBaseStructure.TIM_Period=9; TIM_TimeBaseStructure.TIM_Prescaler=35999; TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1; TIM_TimeBaseStructure.TIM_CounterMode=TIM_CounterMode_Up; TIM_TimeBaseInit(TIM2,&TIM_TimeBaseStructure); TIM_ClearFlag(TIM2,TIM_FLAG_Update); TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE); TIM_Cmd(TIM2,ENABLE); } void ADC_RegularChannelConfiguration(void) { ADC_InitTypeDef ADC_InitStructure; ADC_InitStructure.ADC_Mode=ADC_Mode_Independent; ADC_InitStructure.ADC_ScanConvMode=ENABLE; ADC_InitStructure.ADC_ContinuousConvMode=ENABLE; ADC_InitStructure.ADC_ExternalTrigConv=ADC_ExternalTrigConv_None; ADC_InitStructure.ADC_DataAlign=ADC_DataAlign_Right; ADC_InitStructure.ADC_NbrOfChannel=3; ADC_Init(ADC1,&ADC_InitStructure); ADC_RegularChannelConfig(ADC1,ADC_Channel_10,1,ADC_SampleTime_1Cycles5); ADC_RegularChannelConfig(ADC1,ADC_Channel_11,2,ADC_SampleTime_1Cycles5); ADC_RegularChannelConfig(ADC1,ADC_Channel_12,3,ADC_SampleTime_1Cycles5); ADC_DMACmd(ADC1,ENABLE); ADC_Cmd(ADC1,ENABLE); ADC_ResetCalibration(ADC1); while(ADC_GetResetCalibrationStatus(ADC1)); ADC_StartCalibration(ADC1); while(ADC_GetCalibrationStatus(ADC1)); ADC_ClearFlag(ADC1, ADC_FLAG_EOC); ADC_SoftwareStartConvCmd(ADC1,DISABLE); } void DMA_Configuration(void) { DMA_InitTypeDef DMA_InitStructure; DMA_DeInit(DMA1_Channel1); DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;//adc1的数据寄存器设备地址,数据手册上有 DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&adc_value;//一个有3个元素数组的首地址 DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; //BufferSize=2,因为ADC转换序列有2个通道 //如此设置,使序列1结果放在adc_value[0],序列2结果放在adc_value[1] DMA_InitStructure.DMA_BufferSize = 3; DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; //循环模式开启,Buffer写满后,自动回到初始地址开始传输 DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; DMA_InitStructure.DMA_Priority = DMA_Priority_High; DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; DMA_Init(DMA1_Channel1, &DMA_InitStructure); DMA_ClearFlag(DMA1_FLAG_TC1); //配置完成后,启动DMA通道 DMA_ClearITPendingBit(DMA1_IT_TC1); DMA_ITConfig(DMA1_Channel1, DMA_IT_TC, ENABLE); DMA_Cmd(DMA1_Channel1, ENABLE); } |
2个回答
ADC+DMA采集三通道AD值不对,改变引脚对应电平的AD值又变了。。。。
第一次代码不全
#include "stm32f10x.h" #define ADC1_DR_Address ((u32)0x4001244C) void TIM1_UP_IRQHandler(void) { round1++; TIM_ClearITPendingBit(TIM1, TIM_IT_Update); } void TIM2_IRQHandler(void) { TIM_ClearITPendingBit(TIM2, TIM_IT_Update); ADC_SoftwareStartConvCmd(ADC1,ENABLE); // while(!(ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC))); while(!(DMA_GetFlagStatus(DMA1_FLAG_TC1))); adc_current[i]=adc_value[0]; adc_voltagea[i]=adc_value[1]; adc_voltageb[i]=adc_value[2]; // while(!times); // while(!(times==3)); // times=0; DMA_ClearFlag(DMA1_FLAG_TC1); // ADC_ClearFlag(ADC1, ADC_FLAG_EOC); i++; LED_on; if(i==7) { i=0; Max_cu=adc_current[0]; Min_cu=adc_current[0]; sum_cu=adc_current[0]; Max_voa=adc_voltagea[0]; Min_voa=adc_voltagea[0]; sum_voa=adc_voltagea[0]; Max_vob=adc_voltageb[0]; Min_vob=adc_voltageb[0]; sum_vob=adc_voltageb[0]; for(i=1;i<7;i++) { sum_cu=sum_cu+adc_current[i]; if(adc_current[i]>Max_cu) Max_cu=adc_current[i]; if(adc_current[i] if(adc_voltagea[i]>Max_voa) Max_voa=adc_voltagea[i]; if(adc_voltagea[i] if(adc_voltageb[i]>Max_vob) Max_vob=adc_voltageb[i]; if(adc_voltageb[i] adc_cu=(sum_cu-Max_cu-Min_cu)/5; adc_voa=(sum_voa-Max_voa-Min_voa)/5; adc_vob=(sum_vob-Max_vob-Min_vob)/5; i=0; } RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO|RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOD|RCC_APB2Periph_GPIOC , ENABLE);// 使能APB2外设GPIOB时钟 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE|RCC_APB2Periph_GPIOF , ENABLE);// 使能APB2外设GPIOE时钟 RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2|RCC_APB1Periph_TIM3|RCC_APB1Periph_TIM4, ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 |RCC_APB2Periph_TIM1, ENABLE); RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1, ENABLE); RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);//使能DMA时钟 void ADC_RegularChannelConfiguration(void) { ADC_InitTypeDef ADC_InitStructure; ADC_InitStructure.ADC_Mode=ADC_Mode_Independent; ADC_InitStructure.ADC_ScanConvMode=ENABLE; ADC_InitStructure.ADC_ContinuousConvMode=ENABLE; ADC_InitStructure.ADC_ExternalTrigConv=ADC_ExternalTrigConv_None; ADC_InitStructure.ADC_DataAlign=ADC_DataAlign_Right; ADC_InitStructure.ADC_NbrOfChannel=3; ADC_Init(ADC1,&ADC_InitStructure); ADC_RegularChannelConfig(ADC1,ADC_Channel_10,1,ADC_SampleTime_1Cycles5); ADC_RegularChannelConfig(ADC1,ADC_Channel_11,2,ADC_SampleTime_1Cycles5); ADC_RegularChannelConfig(ADC1,ADC_Channel_12,3,ADC_SampleTime_1Cycles5); ADC_DMACmd(ADC1,ENABLE); ADC_Cmd(ADC1,ENABLE); ADC_ResetCalibration(ADC1); while(ADC_GetResetCalibrationStatus(ADC1)); ADC_StartCalibration(ADC1); while(ADC_GetCalibrationStatus(ADC1)); ADC_ClearFlag(ADC1, ADC_FLAG_EOC); ADC_SoftwareStartConvCmd(ADC1,DISABLE); } void DMA_Configuration(void) { DMA_InitTypeDef DMA_InitStructure; DMA_DeInit(DMA1_Channel1); DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;//adc1的数据寄存器设备地址,数据手册上有 DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&adc_value;//一个有3个元素数组的首地址 DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; //BufferSize=2,因为ADC转换序列有2个通道 //如此设置,使序列1结果放在adc_value[0],序列2结果放在adc_value[1] DMA_InitStructure.DMA_BufferSize = 3; DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; //循环模式开启,Buffer写满后,自动回到初始地址开始传输 DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; DMA_InitStructure.DMA_Priority = DMA_Priority_High; DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; DMA_Init(DMA1_Channel1, &DMA_InitStructure); DMA_ClearFlag(DMA1_FLAG_TC1); //配置完成后,启动DMA通道 DMA_ClearITPendingBit(DMA1_IT_TC1); DMA_ITConfig(DMA1_Channel1, DMA_IT_TC, ENABLE); DMA_Cmd(DMA1_Channel1, ENABLE); } |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
991 浏览 0 评论
AD7686芯片不传输数据给STM32,但是手按住就会有数据。
970 浏览 2 评论
2080 浏览 0 评论
如何解决MPU-9250与STM32通讯时,出现HAL_ERROR = 0x01U
1177 浏览 1 评论
hal库中i2c卡死在HAL_I2C_Master_Transmit
1599 浏览 1 评论
GMT+8, 2024-11-23 02:34 , Processed in 0.602969 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
