扫一扫,分享给好友
基于滞环控制的电压型逆变器的仿真,用的simulink仿真,出现代数环,还有很多的不连续,什么意思?怎么改啊?
Warning: Block diagram 'untitledbest' contains 1 algebraic loop(s). To see more details about the loops use the command line Simulink debugger by typing "sldebug untitledbest" in the matlab command window. To eliminate this message, set the Algebraic loop option in the Diagnostics page of the Simulation Parameters Dialog to "None". Found algebraic loop containing: 'untitledbest/Subsystem/Relay1' (discontinuity) 'untitledbest/Subsystem/Relay2' (discontinuity) 'untitledbest/Subsystem/Relay3' (discontinuity) 'untitledbest/Subsystem/Relay4' (discontinuity) 'untitledbest/Subsystem/Relay5' (discontinuity) 'untitledbest/Subsystem/Relay6' (discontinuity) 'untitledbest/Multimeter/source/Switches2/Model1/Conduction Logic/ ' (discontinuity) 'untitledbest/Multimeter/source/Switches2/Model1/Conduction Logic/Test2' (discontinuity) 'untitledbest/Multimeter/source/Switches2/Model1/Tail/Integrator' (discontinuity) 'untitledbest/Multimeter/source/Switches2/Model1/Tail/Look-Up Table' 'untitledbest/Multimeter/source/Switches2/Model1/Integrator' (discontinuity) 'untitledbest/Multimeter/source/Switches2/Model1/Tail/Product' (algebraic variable) 'untitledbest/Multimeter/source/Switches2/Model1/Tail/Switch' (discontinuity) 'untitledbest/Multimeter/source/State-Space' 'untitledbest/Multimeter/Gain2' 'untitledbest/Subsystem/Sum2' (algebraic variable) 'untitledbest/Subsystem/Sum1' (algebraic variable) 'untitledbest/Subsystem/Sum3' (algebraic variable) Warning: Discontinuities detected within algebraic loop(s), may have trouble solving. Warning: Detected algebraic loop path(s) through integrator reset or IC ports. Results may not be intuitive (see documentation). Use integrator state port to avoid algebraic loops. >>
1个回答
补充的图片啊啊啊啊
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
我用matlab的coder 封装了一个c语言的dll, 但是在用labview调用时,会出现识别不到库的问题,有大神遇到过吗
2645 浏览 0 评论
5229 浏览 0 评论
在matlab中如何计算含有第一类修正的贝塞尔函数的积分算不出的问题?
9025 浏览 0 评论
怎么利用matlab得到95%,80%和70%的置信区间,并生成不同区间下的功率误差贝塔分布?
10466 浏览 0 评论
请问simulink的s-function模块如何添加多输入输出接口
14632 浏览 2 评论
/9
GMT+8, 2025-12-2 05:15 , Processed in 0.732119 second(s), Total 75, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2975
