module getValue1(input clk,
input [7:0]datinB, input ntrig, input rdclk, input [2:0] type1, input type_en, input req, output reg [7:0] datout, output reg [11:0]rdaddr, output reg busy, output reg RDY=0, output reg [11:0] wraddr ); reg [2:0] TYPE=4; reg ntrig_next,busy_next,req_next,startWr; //用于判断边沿,start标识边沿后持续时间段(标识一帧) reg [2:0] startRd; reg [7:0] datinB_next; //datinA_next,用于判断过零点 reg [15:0] zeroB[50:0]; //起/始像素点(过零点 pixel) reg [7:0] averB[25:0];// reg [7:0] memB[4095:0]; reg [7:0]index_Bz,index_Bs ;//过零点 pixel 数组下标 reg [7:0] index_Bv;//过零点 pixel 数组下标 reg [15:0]index_Bm;//非零像素数组下标 reg startBz;//非零区段标识 reg [7:0] widthB;// reg [31:0] sumB;//sumA, reg [15:0]len_memB,len_Rd,len_zeroB;// reg [7:0] len_averB;// always @(posedge clk) begin //下降沿触发延时,延时一帧处理 ntrig_next<=ntrig; if((ntrig_next)&(~ntrig)) //下降沿 begin startWr<=1; wraddr<=0; index_Bz<=0; index_Bv<=0; index_Bm<=0;///长度可能大于255 end if(startWr==1)//标识持续读取一帧 begin busy<=1; datinB_next<=datinB; ////----B 通道-------- if((datinB_next==0)&&(datinB>0)) //起始点 begin startBz<=1; index_Bs<=index_Bz; zeroB[index_Bz]<=wraddr;//zeroA[1]开始存数据,[0]用于存长度 index_Bz<=index_Bz+1; sumB<=datinB;//sumB<=0; end if(startBz) sumB<=sumB+datinB; if((datinB_next>0)&&(datinB==0))//终了点 begin startBz<=0; zeroB[index_Bz]<=wraddr; widthB<=wraddr-zeroB[index_Bs];//widthB<=zeroB[index_Bz]-zeroB[index_Bs]; if(((wraddr-zeroB[index_Bs])>0)&&((wraddr-zeroB[index_Bs])<3640))//if((widthB>2)&&(widthB<500)) if((widthB>0)&&(widthB<500)) begin index_Bz<=index_Bz+1; averB[index_Bv]=sumB/(wraddr-zeroB[index_Bs]);//averB[index_Bv]=sumB/widthB; index_Bv<=index_Bv+1; end else index_Bz<=index_Bs;//超出,则覆盖本次 end //--------------------------------------- //------------去掉 0 数值的帧内容--------- if(datinB>0) begin memB[index_Bm]=datinB;//自memA[2]开始存数据,[0:1]用于存长度 index_Bm<=index_Bm+1; end //------------------------------- wraddr<=wraddr+1; end//end startWr==1 if((startWr==1)&&(wraddr>=3647)) begin startWr<=0; busy<=0; //-------B-------- len_zeroB<=(index_Bz<<1);//过零点位置数组 B ,位置16bit,长度*2 // zeroB[0]<=len_zeroB+1; len_averB<=index_Bv; //平均值数组B // averB[0]<=len_averB+1; len_memB<=index_Bm; //非零值数组B // memB[0]<=len_memB+1; //--------------- end //--------------------------------------- end always @(posedge rdclk) begin busy_next<=busy; req_next<=req; datout<=8'h0; if((busy_next==1)&&(busy==0))//(||((~req_next)&(req))) //busy 下降沿 or req 上升沿 begin startRd<=1;//下降沿触发 RDY<=1; rdaddr<=0; case (type1) 3'h4://读取过零点位置数组 B //len_Rd<=len_zeroB; begin len_Rd<=len_zeroB; if(len_zeroB!=0) datout<=8'h55; else datout<=8'h00; end 3'h5://读取平均值数组B //len_Rd<=len_averB; begin len_Rd<=len_averB; if(len_averB!=0) datout<=8'h55; else datout<=8'h00; end 3'h6://读取 非零数组B //len_Rd<=len_memB; begin len_Rd<=len_memB; if(len_memB!=0) datout<=8'h55; else datout<=8'h00; end default://reserve datout<=0; endcase //datout<=8'h55; end if(startRd==1&&len_Rd>0)// begin datout<=len_Rd+2; //55 len data startRd<=2;//startRd<=2; RDY<=1; end if(RDY==1&&len_Rd==0)//清零,防止触发后没有合适的数据,导致RDY一直为1,不停发送零 RDY<=0; if(startRd==2)//if(startRd==2) begin case (type1) 3'h4://读取过零点位置数组 B begin if(rdaddr[0]==0) datout<=zeroB[rdaddr>>1][15:8]; if(rdaddr[0]==1) datout<=zeroB[rdaddr>>1][7:0]; end 3'h5://读取平均值数组B datout<=averB[rdaddr]; 3'h6://读取 非零数组B datout<=memB[rdaddr]; default://reserve datout<=0; endcase rdaddr<=rdaddr+1; RDY<=1; end if((rdaddr>=len_Rd)&&(rdaddr!=0))//if(rdaddr>=len_Rd)// begin startRd<=0; RDY<=0; rdaddr<=0; len_Rd<=0; end end endmodule 主要占用资源的是以上模块,加上后Total Logic Elements由10%直接增加到94%,芯片型号是cyclone 4 E系列。 图中,如果不把typeA[2..0]连接到getvalue1,Total Logic Elements只用了10%,连接上后,Total Logic Elements直接飙到了94%,请问是哪里出了问题,还是getvalue1模块的问题,getvalue1中的代码有什么优化的方法可以减少Total Logic Elements的使用。 |
4个回答
模块连线与资源使用情况在附件图中。
typeA是不是就是代码里的type? 然后代码里clk和rdclk分别是多少M?如果是高频的时钟频率你的代码有异步时钟域之间的信号交互情况,例如len_zeroB,这样很容易引入不稳定状态;但是不是会造成资源消耗增加就不好说了,
程序我没有细看,我猜想你是不是之前的程序很多倍综合了,加了一根线后才是正常的?我之前遇到过,找到的原因是这个
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
130 浏览 0 评论
NVMe高速传输之摆脱XDMA设计54:如何测试队列管理功能2
354 浏览 0 评论
NVMe高速传输之摆脱XDMA设计53:如何测试队列管理功能
378 浏览 0 评论
NVMe高速传输之摆脱XDMA设计52:主要功能测试结果与分析4(NVMe 指令提交与完成机制测试)
923 浏览 0 评论
NVMe高速传输之摆脱XDMA设计51:主要功能测试结果与分析3 nvmePCIe高速存储 PCIe高速存储
569 浏览 0 评论
4559 浏览 64 评论
/9
GMT+8, 2025-12-12 00:06 , Processed in 0.718684 second(s), Total 49, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1680
