#include
#include #define uchar unsigned char #define uint unsigned int ***it sck=P1^0; ***it io=P1^1; ***it rst=P3^6; ***it smgen=P2^3; unsigned char code smg_du[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x00,0x10}; unsigned char code smg_we[]={0x08,0x18,0x28,0x38,0x48,0x58,0x68,0x78}; uchar time_data[7]={10,6,4,17,11,58,30}; uchar time_add[7]={0x8c,0x8a,0x88,0x86,0x84,0x82,0x80}; uchar read_add[7]={0x8d,0x8b,0x89,0x87,0x85,0x83,0x81}; uchar disp[8]; void write_ds1302_byte(uchar dat); void write_ds1302(uchar add,uchar dat); uchar read_ds1302(uchar add); void set_rtc(void); void read_rtc(void); void time_pros(void); void delay_50ms(uint t) { uint j; for(;t>0;t--) for(j=6245;j>0;j--); } void write_ds1302_byte(uchar dat) { uchar i; for(i=0;i<8;i++) { sck=0; io=dat&0x01; dat=dat>>1; sck=1; } } void write_ds1302(uchar add,uchar dat) { rst=0; _nop_(); sck=0; _nop_(); rst=1; _nop_(); write_ds1302_byte(add); write_ds1302_byte(dat); rst=0; _nop_(); io=1; sck=1; } uchar read_ds1302(uchar add) { uchar i; uchar value; rst=0; _nop_(); sck=0; _nop_(); rst=1; _nop_(); write_ds1302_byte(add); for(i=0;i<8;i++) { value=value>>1; sck=0; if(io) value=value|0x80; sck=1; } rst=0; _nop_(); sck=0; _nop_(); sck=1; io=1; return value; } void set_rtc(void) { uchar i,j; for(i=0;i<7;i++) { j=time_data[i]/10; time_data[i]=time_data[i]%10; time_data[i]=time_data[i]+j*16; } write_ds1302(0x8e,0x00); for(i=0;i<7;i++) { write_ds1302(time_add[i],time_data[i]); } write_ds1302(0x8e,0x80); } void read_rtc(void) { uchar i; for(i=0;i<7;i++) { time_data[i]=read_ds1302(read_add[i]); } } void time_pros(void) { disp[0]=time_data[6]%16; disp[1]=time_data[6]/16; disp[2]=17; disp[3]=time_data[5]%16; disp[4]=time_data[5]/16; disp[5]=17; disp[6]=time_data[4]%16; disp[7]=time_data[4]/16; } void display(void) { uchar i; for(i=0;i<8;i++) { P1=smg_du[disp[i]]; P2=smg_we[i]; delay_50ms(20); } } void main(void) { set_rtc(); while(1) { smgen=0; read_rtc(); smgen=1; time_pros(); display(); } }
12个回答
我帮你看看
你qq多少,我发邮件给你
缺了单字节读的程序 能发我一份吗?181142649
我也出现的同样的问题 能否发一份给我 936315305谢谢了
好东西啊!!!!
高手们呀,我呢也出了同样的问题,能不能给我一份呀?我的QQ***在些表示感谢了!
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
2024年上海海思MCU开发者体验官招募,手机/MatePad大奖等你拿!
609 浏览 0 评论
【xG24 Matter开发套件试用体验】蓝牙控制板载LED
633 浏览 0 评论
768 浏览 0 评论
电赛:mspm0l1306的开发板可以烧录程序,但是程序运行不了,怎么解决这个问题?
952 浏览 1 评论
【xG24 Matter开发套件试用体验】Silicon Labs 基于 EFR32MG24 Explorer Kit 开发板 开箱试用体验
768 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
10499 浏览 31 评论
GMT+8, 2024-8-4 19:22 , Processed in 0.671394 second(s), Total 66, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
