扫一扫,分享给好友
而同样的程序复制给了后三行,全能正常使用呢。。。。
程序如下 #include ***it d1=P0^0; ***it key1=P3^4; ***it dula=P2^6; ***it wela=P2^7; unsigned char temp,x,y,num; unsigned char code table[]={0x3f,0x06,0x5b,0x4f, 0x66,0x6d,0x7d,0x07, 0x7f,0x6f,0x77,0x7c, 0x39,0x5e,0x79,0x71}; void display(unsigned char x,unsigned char y); void delay(unsigned int z); void main() { while(1) { P3=0xfe;//0xfe=11111110 temp=P3; temp=temp&0xf0;//0xf0=11110000做“与”的操作 while(temp!=0xf0) { delay(5); temp=P3; temp=temp&0xf0; while(temp!=0xf0) { temp=P3; switch(temp) { case 0xee: //第一个键按下去则为11101110(由P3^7读到P3^0) num=1; break; case 0xde: num=2; break; case 0xbe: num=3; break; case 0x7e: num=4; break; } while(temp!=0xf0)//松手检测 { temp=P3; temp=temp&0xf0; } } } //检测第二行 P3=0xfd;//11111101 temp=P3; temp=temp&0xf0; while(temp!=0xf0) { delay(5); temp=P3; temp=temp&0xf0; while(temp!=0xf0) { temp=P3;//跳出检测和防颤抖的循环 switch(temp) { case 0xed: //第一个键按下去则为11101110(由P3^7读到P3^0) num=5; break; case 0xdd: num=6; break; case 0xbd: num=7; break; case 0x7d: num=8; break; } while(temp!=0xf0)//松手检测 { temp=P3; temp=temp&0xf0; } } } //检测第三行 P3=0xfb; temp=P3; temp=temp&0xf0;//0xf0=11110000做“与”的操作 while(temp!=0xf0) { delay(5); temp=P3; temp=temp&0xf0; while(temp!=0xf0) { temp=P3;//跳出检测和防颤抖的循环 switch(temp) { case 0xeb: num=9; break; case 0xdb: num=10; break; case 0xbb: num=11; break; case 0x7b: num=12; break; } while(temp!=0xf0)//松手检测 { temp=P3; temp=temp&0xf0; } } } P3=0xf7; temp=P3; temp=temp&0xf0;//0xf0=11110000做“与”的操作 while(temp!=0xf0) { delay(5); temp=P3; temp=temp&0xf0; while(temp!=0xf0) { temp=P3;//跳出检测和防颤抖的循环 switch(temp) { case 0xe7: num=13; break; case 0xd7: num=14; break; case 0xb7: num=15; break; case 0x77: num=16; break; } while(temp!=0xf0)//松手检测 { temp=P3; temp=temp&0xf0; } } } x=num/10; y=num%10; display(x,y); } } void display(unsigned char x,unsigned char y) { wela=1; P0=0xfe; wela=0; dula=1; P0=table[x]; dula=0; delay(5); wela=1; P0=0xfd; wela=0; dula=1; P0=table[y]; dula=0; delay(5); } void delay(unsigned int z) { unsigned int xx,yy; for(xx=z;xx>0;xx--) for(yy=50;yy>0;yy--); } |
6个回答
求问啊!这个问题困扰我好久了==!
具体什么情况我也没弄懂,不过有两点问题,一你输出扫描代码是要延时一段时间等电平稳定了才读输入情况。二抖动延时要5~10ms,你只延时了2ms左右,延时不够。
你先把接线换一下,看看第一排的按键是不是好的。先排除硬件的因素。
不知道你的电路图是怎么连接的?如果其他语句没有问题,那就是第一行的检测或者数值错误,在检查下
你用的是u***下载线吧?把u***下载线拔下来就正常了,use转串口下载线芯片占用了部分端口,实验板反面有说明。
评分
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
528 浏览 0 评论
654 浏览 0 评论
858 浏览 0 评论
837 浏览 0 评论
RT-Thread与英飞凌(infineon)合作得板子PSOC 6 板子学习
770 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
17061 浏览 31 评论
/9
GMT+8, 2025-12-14 21:10 , Processed in 1.059674 second(s), Total 89, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2406
