在淘宝上买的PCB板,在本论坛下载的程序不能用,经过修过P1口改成P3口,可以正常点亮,音频和按键接口不知道要改那个地方,本人是菜鸟,请大师傅指导一下
#include #include #define uchar unsigned char #define uint unsigned int uchar display[8][8]; /*rank:A,1,2,3,4,I,心,U*/ uchar code table_cha[8][8]={0x51,0x51,0x51,0x4a,0x4a,0x4a,0x44,0x44,0x18,0x1c,0x18,0x18,0x18,0x18,0x18,0x3c,0x3c,0x66,0x66,0x30,0x18,0xc,0x6,0xf6,0x3c,0x66,0x60,0x38,0x60,0x60,0x66,0x3c,0x30,0x38,0x3c,0x3e,0x36,0x7e,0x30,0x30,0x3c,0x3c,0x18,0x18,0x18,0x18,0x3c,0x3c,0x66,0xff,0xff,0xff,0x7e,0x3c,0x18,0x18,0x66,0x66,0x66,0x66,0x66,0x66,0x7e,0x3c}; /*the "ideasoft"*/ uchar code table_id[40]={0x81,0xff,0x81,0x00,0xff,0x81,0x81,0x7e,0x00,0xff,0x89,0x89,0x00,0xf8,0x27,0x27,0xf8,0x00,0x8f,0x89,0x89,0xf9,0x00,0xff,0x81,0x81,0xff,0x00,0xff,0x09,0x09,0x09,0x01,0x0,0x01,0x01,0xff,0x01,0x01,0x00}; /*railway*/ uchar code dat[128]={0x0,0x20,0x40,0x60,0x80,0xa0,0xc0,0xe0,0xe4,0xe8,0xec,0xf0,0xf4,0xf8,0xfc,0xdc,0xbc,0x9c,0x7c,0x5c,0x3c,0x1c,0x18,0x14,0x10,0xc,0x8,0x4,0x25,0x45,0x65,0x85,0xa5,0xc5,0xc9,0xcd,0xd1,0xd5,0xd9,0xb9,0x99,0x79,0x59,0x39,0x35,0x31,0x2d,0x29,0x4a,0x6a,0x8a,0xaa,0xae,0xb2,0xb6,0x96,0x76,0x56,0x52,0x4e,0x6f,0x8f,0x93,0x73,0x6f,0x8f,0x93,0x73,0x4a,0x6a,0x8a,0xaa,0xae,0xb2,0xb6,0x96,0x76,0x56,0x52,0x4e,0x25,0x45,0x65,0x85,0xa5,0xc5,0xc9,0xcd,0xd1,0xd5,0xd9,0xb9,0x99,0x79,0x59,0x39,0x35,0x31,0x2d,0x29,0x0,0x20,0x40,0x60,0x80,0xa0,0xc0,0xe0,0xe4,0xe8,0xec,0xf0,0xf4,0xf8,0xfc,0xdc,0xbc,0x9c,0x7c,0x5c,0x3c,0x1c,0x18,0x14,0x10,0xc,0x8,0x4}; /*railway 2*/ uchar code dat2[28]={0x0,0x20,0x40,0x60,0x80,0xa0,0xc0,0xe0,0xe4,0xe8,0xec,0xf0,0xf4,0xf8,0xfc,0xdc,0xbc,0x9c,0x7c,0x5c,0x3c,0x1c,0x18,0x14,0x10,0xc,0x8,0x4}; /*railway 3*/ uchar code dat3[24]={0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x16,0x26,0x36,0x46,0x56,0x66,0x65,0x64,0x63,0x62,0x61,0x60,0x50,0x40,0x30,0x20,0x10}; /*3p char*/ uchar code table_3p[3][8]={0xff,0x89,0xf5,0x93,0x93,0xf5,0x89,0xff,0x0e,0x1f,0x3f,0x7e,0x7e,0x3f,0x1f,0x0e,0x18,0x3c,0x7e,0xff,0x18,0x18,0x18,0x18}; /*initializtion That is to initialize the program . It is write to set the timer in c52 mcu. So the program can renovate the led_3d_cube in fixed time use the interrupt function.*/ void sinter() { IE=0x82; TCON=0x01; TH0=0xc0; TL0=0; TR0=1; } void delay5us(void) //误差 -0.026765046296us STC 1T 22.1184Mhz { unsigned char b; for(b=7;b>0;b--); //for(a=2;a>0;a--); } void delay(uint i) { while (i--){ delay5us();}//12t的mcu 注释这个延时即可 } /*To judge the num bit*/ uchar judgebit(uchar num,uchar b) { char n; num=num&(1< if (num) n=1; else n=0; return n; } /*To figure out the round number*/ uchar abs(uchar a) { uchar b; b=a/10; a=a-b*10; if (a>=5) b++; return b; } /*To figure out the absolute value*/ uchar abss(char a) { if (a<0) a=-a; return a; } /*The function can comparat the character. And remove the big one to the back.*/ void max(uchar *a,uchar *b) { uchar t; if ((*a)>(*b)) { t=(*a); (*a)=(*b); (*b)=t; } } /*The function is to figure out the max number and return it.*/ uchar maxt(uchar a,uchar b,uchar c) { if (a a=b; if (a return a; } void clear(char le) { uchar i,j; for (j=0;j<8;j++) { for (i=0;i<8;i++) display[j][i]=le; } } void trailler(uint speed) { char i,j; for (i=6;i>=-3;i--) { if (i>=0) { for (j=0;j<8;j++) display[j][i]=display[j][i+1]; } if (i<4) { for (j=0;j<8;j++) display[j][i+4]=0; } delay(speed); } } void point(uchar x,uchar y,uchar z,uchar le) { uchar ch1,ch0; ch1=1< if (le) display[z][y]=display[z][y]|ch1; else display[z][y]=display[z][y]&ch0; } void type(uchar cha,uchar y) { uchar xx; for (xx=0;xx<8;xx++) { display[xx][y]=table_cha[cha][xx]; } } /*The first variable is the distance from the midpoint. The second is the layer. the third is the flash speed of the time between each two point. The forth is the enable io,it controls weather draw or claen.*/ void cirp(char cpp,uchar dir,uchar le) { uchar a,b,c,cp; if ((cpp<128)&(cpp>=0)) { if (dir) cp=127-cpp; else cp=cpp; a=(dat[cp]>>5)&0x07; b=(dat[cp]>>2)&0x07; c=dat[cp]&0x03; if (cpp>63) c=7-c; point (a,b,c,le); } } void line(uchar x1,uchar y1,uchar z1,uchar x2,uchar y2,uchar z2,uchar le) { char t,a,b,c,a1,b1,c1,i; a1=x2-x1; b1=y2-y1; c1=z2-z1; t=maxt(abss(a1),abss(b1),abss(c1)); a=x1*10; b=y1*10; c=z1*10; a1=a1*10/t; b1=b1*10/t; c1=c1*10/t; for (i=0;i point(abs(a),abs(b),abs(c),le); a+=a1; b+=b1; c+=c1; } point(x2,y2,z2,le); } void box(uchar x1,uchar y1,uchar z1,uchar x2,uchar y2,uchar z2,uchar fill,uchar le) { uchar i,j,t=0; max(&x1,&x2); max(&y1,&y2); max(&z1,&z2); for (i=x1;i<=x2;i++) t|=1< if (!le) t=~t; if (fill) { if (le) { for (i=z1;i<=z2;i++) { for (j=y1;j<=y2;j++) display[j][i]|=t; } } else { for (i=z1;i<=z2;i++) { for (j=y1;j<=y2;j++) display[j][i]&=t; } } } else { if (le) { display[y1][z1]|=t; display[y2][z1]|=t; display[y1][z2]|=t; display[y2][z2]|=t; } else { display[y1][z1]&=t; display[y2][z1]&=t; display[y1][z2]&=t; display[y2][z2]&=t; } t=(0x01< t=~t; if (le) { for (j=z1;j<=z2;j+=(z2-z1)) { for (i=y1;i<=y2;i++) display[i][j]|=t; } for (j=y1;j<=y2;j+=(y2-y1)) { for (i=z1;i<=z2;i++) display[j][i]|=t; } } else { for (j=z1;j<=z2;j+=(z2-z1)) { for (i=y1;i<=y2;i++) { display[i][j]&=t; } } for (j=y1;j<=y2;j+=(y2-y1)) { for (i=z1;i<=z2;i++) { display[j][i]&=t; } } } } } void box_apeak_xy(uchar x1,uchar y1,uchar z1,uchar x2,uchar y2,uchar z2,uchar fill,uchar le) { uchar i; max(&z1,&z2); if (fill) { for (i=z1;i<=z2;i++) { line (x1,y1,i,x2,y2,i,le); } } else { line (x1,y1,z1,x2,y2,z1,le); line (x1,y1,z2,x2,y2,z2,le); line (x2,y2,z1,x2,y2,z2,le); line (x1,y1,z1,x1,y1,z2,le); } } void poke(uchar n,uchar x,uchar y) { uchar i; for (i=0;i<8;i++) { point(x,y,i,judgebit(n,i)); } } void boxtola(char i,uchar n) { if ((i>=0)&(i<8)) { poke(n,0,7-i); } if ((i>=8)&(i<16)) { poke(n,i-8,0); } if ((i>=16)&(i<24)) { poke(n,7,i-16); } } void rolldisplay(uint speed) { uchar j; char i,a; for (i=23;i>-40;i--) { for (j=0;j<40;j++) { a=i+j; if ((a>=0)&(a<24)) boxtola(a,table_id[j]); } delay(speed); } } void roll_apeak_yz(uchar n,uint speed) { uchar i; switch(n) { case 1: for (i=0;i<7;i++) { display[i][7]=0; display[7][6-i]=255; delay(speed); }; break; case 2: for (i=0;i<7;i++) { display[7][7-i]=0; display[6-i][0]=255; delay(speed); }; break; case 3: for (i=0;i<7;i++) { display[7-i][0]=0; display[0][i+1]=255; delay(speed); }; break; case 0: for (i=0;i<7;i++) { display[0][i]=0; display[i+1][7]=255; delay(speed); }; } } void roll_apeak_xy(uchar n,uint speed) { uchar i; switch(n) { case 1: for (i=0;i<7;i++) { line(0,i,0,0,i,7,0); line(i+1,7,0,i+1,7,7,1); delay(speed); }; break; case 2: for (i=0;i<7;i++) { line(i,7,0,i,7,7,0); line(7,6-i,0,7,6-i,7,1); delay(speed); }; break; case 3: for (i=0;i<7;i++) { line(7,7-i,0,7,7-i,7,0); line(6-i,0,0,6-i,0,7,1); delay(speed); }; break; case 0: for (i=0;i<7;i++) { line(7-i,0,0,7-i,0,7,0); line(0,i+1,0,0,i+1,7,1); delay(speed); }; } } void roll_3_xy(uchar n,uint speed) { uchar i; switch(n) { case 1: for (i=0;i<8;i++) { box_apeak_xy (0,i,0,7,7-i,7,1,1); delay(speed); if (i<7) box_apeak_xy (3,3,0,0,i,7,1,0); }; break; case 2: for (i=0;i<8;i++) { box_apeak_xy (7-i,0,0,i,7,7,1,1); delay(speed); if (i<7) box_apeak_xy (3,4,0,i,7,7,1,0); }; break; case 3: for (i=0;i<8;i++) { box_apeak_xy (0,i,0,7,7-i,7,1,1); delay(speed); if (i<7) box_apeak_xy (4,4,0,7,7-i,7,1,0); }; break; case 0: for (i=0;i<8;i++) { box_apeak_xy (7-i,0,0,i,7,7,1,1); delay(speed); if (i<7) box_apeak_xy (4,3,0,7-i,0,7,1,0); }; } } void trans(uchar z,uint speed) { uchar i,j; for (j=0;j<8;j++) { for (i=0;i<8;i++) { display[z][i]>>=1; } delay(speed); } } void tranoutchar(uchar c,uint speed) { uchar i,j,k,a,i2=0; for (i=0;i<8;i++) { if (i<7) box_apeak_xy (i+1,0,0,i+1,7,7,1,1); box_apeak_xy (i2,0,0,i2,7,7,1,0); a=0; i2=i+1; for (j=0;j<=i;j++) { a=a|(1< for (k=0;k<8;k++) { display[k][3]|=table_cha[c][k]&a; display[k][4]|=table_cha[c][k]&a; } delay(speed); } } void transss() { uchar i,j; for (i=0;i<8;i++) { for (j=0;j<8;j++) display[i][j]<<=1; } } /*From now on,the function below is to display the flash.*/ void flash_1() { clear(0); type(1,0); delay(60000); type(2,0); delay(60000); type(3,0); delay(60000); type(4,0); delay(60000); delay(60000); clear(0); rolldisplay(30000); type(0,7); delay(60000); trailler(6000); delay(60000); } void flash_2() { uchar i; for (i=129;i>0;i--) { cirp(i-2,0,1); delay(8000); cirp(i-1,0,0); } delay(8000); for (i=0;i<136;i++) { cirp(i,1,1); delay(8000); cirp(i-8,1,0); } delay(8000); for (i=129;i>0;i--) { cirp(i-2,0,1); delay(8000); } delay(8000); for (i=0;i<128;i++) { cirp(i-8,1,0); delay(8000); } delay(60000); } void flash_3() { char i; for (i=0;i<8;i++) { box_apeak_xy(0,i,0,7,i,7,1,1); delay(20000); if (i<7) box_apeak_xy(0,i,0,7,i,7,1,0); } for (i=7;i>=0;i--) { box_apeak_xy(0,i,0,7,i,7,1,1); delay(20000); if (i>0) box_apeak_xy(0,i,0,7,i,7,1,0); } for (i=0;i<8;i++) { box_apeak_xy(0,i,0,7,i,7,1,1); delay(20000); if (i<7) box_apeak_xy(0,i,0,7,i,7,1,0); } } void flash_4() { char i,j,an[8]; for (j=7;j<15;j++) an[j-7]=j; for (i=0;i<=16;i++) { for (j=0;j<8;j++) { if ((an[j]<8)&(an[j]>=0)) line(0,an[j],j,7,an[j],j,1); } for (j=0;j<8;j++) { if (((an[j]+1)<8)&(an[j]>=0)) line(0,an[j]+1,j,7,an[j]+1,j,0); } for (j=0;j<8;j++) { if (an[j]>0) an[j]--; } delay(15000); } for (j=0;j<8;j++) an[j]=1-j; for (i=0;i<=16;i++) { for (j=0;j<8;j++) { if ((an[j]<8)&(an[j]>=0)) line(0,an[j],j,7,an[j],j,1); } for (j=0;j<8;j++) { if (((an[j]-1)<7)&(an[j]>0)) line(0,an[j]-1,j,7,an[j]-1,j,0); } for (j=0;j<8;j++) { if (an[j]<7) an[j]++; } delay(15000); } } void flash_5() { uint a=15000;//a=delay char i=8,j,an[4]; //1 for (j=7;j<11;j++) an[j-7]=j; while(i--) { for (j=0;j<4;j++) { if (an[j]<8) box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1); if (an[j]<7) box_apeak_xy(j,an[j]+1,j,7-j,an[j]+1,7-j,0,0); } for (j=0;j<4;j++) { if (an[j]>3) an[j]--; } delay(a); } //2 i=3; for (j=0;j<4;j++) an[j]=5-j; while(i--) { for (j=1;j<4;j++) { if (an[j]<4) box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1); if (an[j]<3) box_apeak_xy(j,an[j]+1,j,7-j,an[j]+1,7-j,0,0); } for (j=0;j<4;j++) { if (an[j]>0) an[j]--; } delay(a); } //3 i=3; for (j=1;j<4;j++) an[j]=4-j; while(i--) { for (j=1;j<4;j++) { if (an[j]>=0) box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1); if (an[j]>0) box_apeak_xy(j,an[j]-1,j,7-j,an[j]-1,7-j,0,0); } for (j=1;j<4;j++) { if (an[j]<3) an[j]++; } delay(a); } //4 i=3; for (j=0;j<4;j++) an[j]=j+1; while(i--) { for (j=1;j<4;j++) { if (an[j]>3) box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1); if (an[j]>3) box_apeak_xy(j,an[j]-1,j,7-j,an[j]-1,7-j,0,0); } for (j=0;j<4;j++) an[j]++; delay(a); } //5 i=3; for (j=3;j<6;j++) an[j-2]=j; while(i--) { for (j=1;j<4;j++) { box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1); box_apeak_xy(j,an[j]+1,j,7-j,an[j]+1,7-j,0,0); } for (j=0;j<4;j++) { if (an[j]>3) an[j]--; } delay(a); } //6 i=3; for (j=0;j<4;j++) an[j]=5-j; while(i--) { for (j=1;j<4;j++) { if (an[j]<4) box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1); if (an[j]<3) box_apeak_xy(j,an[j]+1,j,7-j,an[j]+1,7-j,0,0); } for (j=0;j<4;j++) { if (an[j]>0) an[j]--; } delay(a); } //7 i=3; for (j=0;j<4;j++) an[j]=3-j; an[0]=2; while(i--) { for (j=0;j<3;j++) { if (an[j]>=0) box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1); if (an[j]>=0) box_apeak_xy(j,an[j]+1,j,7-j,an[j]+1,7-j,0,0); } for (j=0;j<4;j++) { if (j<5-i) an[j]--; } delay(a); } //8 i=10; for (j=0;j<4;j++) an[j]=j-2; while(i--) { for (j=0;j<4;j++) { if (an[j]>=0) box_apeak_xy(j,an[j],j,7-j,an[j],7-j,0,1); if (an[j]>=0) box_apeak_xy(j,an[j]-1,j,7-j,an[j]-1,7-j,0,0); } for (j=0;j<4;j++) { if (an[j]<7) an[j]++; } delay(a); } } void flash_6() { uchar i,j,k,z; roll_apeak_yz(1,10000); roll_apeak_yz(2,10000); roll_apeak_yz(3,10000); roll_apeak_yz(0,10000); roll_apeak_yz(1,10000); roll_apeak_yz(2,10000); roll_apeak_yz(3,10000); for (i=0;i<3;i++) { for (j=0;j<8;j++) { for (k=0;k<8;k++) { if ((table_3p[i][j]>>k)&1) { for (z=1;z<8;z++) { point (j,7-k,z,1); if (z-1) point (j,7-k,z-1,0); delay(5000); } } } } trans(7,15000); } } void flash_7() { uchar i; uint a=3000; roll_apeak_yz(0,10000); roll_apeak_yz(1,10000); roll_apeak_yz(2,10000); roll_apeak_yz(3,10000); roll_apeak_yz(0,10000); roll_apeak_yz(1,10000); roll_apeak_yz(2,10000); roll_apeak_yz(3,10000); roll_apeak_yz(0,10000); roll_apeak_yz(1,10000); roll_apeak_yz(2,10000); roll_apeak_xy(0,10000); roll_apeak_xy(1,10000); roll_apeak_xy(2,10000); roll_apeak_xy(3,10000); roll_apeak_xy(0,10000); roll_apeak_xy(1,10000); roll_apeak_xy(2,10000); roll_apeak_xy(3,10000); for (i=0;i<8;i++) { box_apeak_xy (0,i,0,7-i,i,7,1,1); delay(a); } delay(30000); roll_3_xy(0,a); delay(30000); roll_3_xy(1,a); delay(30000); roll_3_xy(2,a); delay(30000); roll_3_xy(3,a); delay(30000); roll_3_xy(0,a); delay(30000); roll_3_xy(1,a); delay(30000); roll_3_xy(2,a); delay(30000); roll_3_xy(3,a); for (i=7;i>0;i--) { box_apeak_xy(i,0,0,i,7,7,1,0); delay(a); } } void flash_8() { uchar i; for (i=5;i<8;i++) { tranoutchar(i,10000); delay(60000); delay(60000); } } void flash_9() { char i; uchar j,an[8],x,y,t,x1,y1; for (i=0;i<8;i++) { box_apeak_xy (i,0,0,i,7,7,1,1); if (i) box_apeak_xy (i-1,0,0,i-1,7,7,1,0); delay(10000); } roll_apeak_xy(3,10000); roll_apeak_xy(0,10000); roll_apeak_xy(1,10000); for (i=0;i<7;i++) { line(6-i,6-i,0,6-i,6-i,7,1); line(i,7,0,i,7,7,0); delay(10000); } for (i=0;i<8;i++) an[i]=14; for (i=0;i<85;i++) { clear(0); for (j=0;j<8;j++) { t=an[j]%28; x=dat2[t]>>5; y=(dat2[t]>>2)&0x07; t=(an[j]-14)%28; x1=dat2[t]>>5; y1=(dat2[t]>>2)&0x07; line(x,y,j,x1,y1,j,1); } for (j=0;j<8;j++) { if ((i>j)&(j>i-71)) an[j]++; } delay(5000); } for (i=0;i<85;i++) { clear(0); for (j=0;j<8;j++) { t=an[j]%28; x=dat2[t]>>5; y=(dat2[t]>>2)&0x07; t=(an[j]-14)%28; x1=dat2[t]>>5; y1=(dat2[t]>>2)&0x07; line(x,y,j,x1,y1,j,1); } for (j=0;j<8;j++) { if ((i>j)&(j>i-71)) an[j]--; } delay(5000); } for (i=0;i<29;i++) { clear(0); t=an[0]%28; x=dat2[t]>>5; y=(dat2[t]>>2)&0x07; t=(an[0]-14)%28; x1=dat2[t]>>5; y1=(dat2[t]>>2)&0x07; box_apeak_xy(x,y,0,x1,y1,7,0,1); box_apeak_xy(x,y,1,x1,y1,6,0,1); an[0]++; delay(5000); } for (i=0;i<16;i++) { clear(0); t=an[0]%28; x=dat2[t]>>5; y=(dat2[t]>>2)&0x07; t=(an[0]-14)%28; x1=dat2[t]>>5; y1=(dat2[t]>>2)&0x07; box_apeak_xy(x,y,0,x1,y1,7,1,1); an[0]--; delay(5000); } for (i=0;i<8;i++) { line(i,i,0,0,0,i,0); delay(5000); } for (i=1;i<7;i++) { line(i,i,7,7,7,i,0); delay(5000); } for (i=1;i<8;i++) { clear(0); box(7,7,7,7-i,7-i,7-i,0,1); delay(10000); } for (i=1;i<7;i++) { clear(0); box(0,0,0,7-i,7-i,7-i,0,1); delay(10000); } for (i=1;i<8;i++) { clear(0); box(0,0,0,i,i,i,0,1); delay(10000); } for (i=1;i<7;i++) { clear(0); box(7,0,0,i,7-i,7-i,0,1); delay(10000); } for (i=1;i<8;i++) { box(7,0,0,7-i,i,i,1,1); delay(10000); } for (i=1;i<7;i++) { clear(0); box(0,7,7,7-i,i,i,1,1); delay(10000); } } void flash_10() { uchar i,j,an[4],x,y,t; for (i=1;i<7;i++) { clear(0); box(0,6,6,1,7,7,1,1); box(i,6,6-i,i+1,7,7-i,1,1); box(i,6,6,i+1,7,7,1,1); box(0,6,6-i,1,7,7-i,1,1); box(0,6-i,6,1,7-i,7,1,1); box(i,6-i,6-i,i+1,7-i,7-i,1,1); box(i,6-i,6,i+1,7-i,7,1,1); box(0,6-i,6-i,1,7-i,7-i,1,1); delay(30000); } for (i=0;i<4;i++) { an[i]=6*i; } for (i=0;i<35;i++) { clear(0); for(j=0;j<4;j++) { t=an[j]%24; x=dat3[t]>>4; y=dat3[t]&0x0f; box(x,y,0,x+1,y+1,1,1,1); box(x,y,6,x+1,y+1,7,1,1); } for (j=0;j<4;j++) an[j]++; delay(10000); } for (i=0;i<35;i++) { clear(0); for(j=0;j<4;j++) { t=an[j]%24; x=dat3[t]>>4; y=dat3[t]&0x0f; box(x,y,0,x+1,y+1,1,1,1); box(x,y,6,x+1,y+1,7,1,1); } for (j=0;j<4;j++) an[j]--; delay(10000); } for (i=0;i<35;i++) { clear(0); for(j=0;j<4;j++) { t=an[j]%24; x=dat3[t]>>4; y=dat3[t]&0x0f; box(x,0,y,x+1,1,y+1,1,1); box(x,6,y,x+1,7,y+1,1,1); } for (j=0;j<4;j++) an[j]++; delay(10000); } for (i=0;i<36;i++) { clear(0); for(j=0;j<4;j++) { t=an[j]%24; x=dat3[t]>>4; y=dat3[t]&0x0f; box(x,0,y,x+1,1,y+1,1,1); box(x,6,y,x+1,7,y+1,1,1); } for (j=0;j<4;j++) an[j]--; delay(10000); } for (i=6;i>0;i--) { clear(0); box(0,6,6,1,7,7,1,1); box(i,6,6-i,i+1,7,7-i,1,1); box(i,6,6,i+1,7,7,1,1); box(0,6,6-i,1,7,7-i,1,1); box(0,6-i,6,1,7-i,7,1,1); box(i,6-i,6-i,i+1,7-i,7-i,1,1); box(i,6-i,6,i+1,7-i,7,1,1); box(0,6-i,6-i,1,7-i,7-i,1,1); delay(30000); } } void flash_11() { uchar i,j,t,x,y; uchar code daa[13]={0,1,2,0x23,5,6,7,6,5,0x23,2,1,0}; for (j=0;j<5;j++) { for (i=0;i<13;i++) { if (daa[i]>>4) { t=daa[i]&0x0f; line (0,0,t+1,0,7,t+1,1); } else t=daa[i]; line (0,0,t,0,7,t,1); transss(); delay(20000); } } for (j=1;j<8;j++) { if (j>3) t=4; else t=j; for (i=0;i<24;i+=j) { x=dat3[i]>>4; y=dat3[i]&0x0f; box_apeak_xy(0,x,y,0,x+1,y+1,1,1); transss(); delay(20000); } } for (j=1;j<8;j++) { if (j>3) t=4; else t=j; for (i=0;i<24;i+=j) { x=dat3[i]>>4; y=dat3[i]&0x0f; point (0,x,y,1); transss(); delay(20000); } } } void main() { sinter(); while(1){ // clear(0); /*play list*/ //flash_1(); clear(0); flash_2(); flash_3(); flash_4(); flash_4(); flash_5(); flash_5(); flash_6(); flash_7(); flash_8(); flash_9(); flash_10(); clear (0); flash_11(); flash_9(); flash_5(); flash_7(); flash_5(); flash_6(); flash_8(); flash_9(); flash_10(); } } //P0; //573 in //P1; //uln2803 //P2; //573 LE void print() interrupt 1 { uchar i; static uchar layer=0; P1=0; for (i=0;i<8;i++) { P2=1< delay(3); P0=display[layer][i]; delay(3); } P1=1< layer++; else layer=0; TH0=0xc0; TL0=0; } |
1个回答
地方v第三方斯蒂芬斯蒂芬斯蒂芬宿舍的
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
435 浏览 0 评论
464 浏览 0 评论
450 浏览 0 评论
806 浏览 0 评论
RT-Thread与英飞凌(infineon)合作得板子PSOC 6 板子学习
748 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
17012 浏览 31 评论
/9
GMT+8, 2025-12-12 07:06 , Processed in 1.217345 second(s), Total 76, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2583
