#include "STM32f10x.h" #include "I2C.h" #include /* Private typedef -----------------------------------------------------------*/ #define Device_Addr 0xe8 /* Private define ------------------------------------------------------------*/ /* I2C控制线的定义 */ #define SCL_H GPIOB->BSRR = GPIO_Pin_9 #define SCL_L GPIOB->BRR = GPIO_Pin_9 #define SDA_H GPIOB->BSRR = GPIO_Pin_8 #define SDA_L GPIOB->BRR = GPIO_Pin_8 #define SCL_read GPIOB->IDR & GPIO_Pin_9 #define SDA_read GPIOB->IDR & GPIO_Pin_8 void I2C_GPIO_Config(void); void I2C_delay(void); bool I2C_Start(void); void I2C_Stop(void); void I2C_Ack(void); void I2C_NoAck(void); bool I2C_WaitAck(void); void I2C_SendByte(u8 SendByte); void I2C_FM_Init(void); void I2C_Write(u8 address,u8 reg,u8 command); //bool I2C_Write(uint8_t* pBuffer, uint8_t Write, uint8_t NumByteToWrite); extern void Delay(__IO uint32_t nCount); void FM_Configuration(void) { GPIO_InitTypeDef GPIO_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE); // RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1,ENABLE); /* 配置PB10,PB11为I2C的 SCL SDL */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9| GPIO_Pin_8; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; GPIO_Init(GPIOB, &GPIO_InitStructure); } void I2C_FM_Init(void) { /* I2C控制线配置 */ FM_Configuration(); /* I2C 初始化 */ //I2C_Configuration(); } //模拟I2C信号 void I2C_INIT(void) //i2c init { SDA_H; SCL_H; } void I2C_Write(u8 address,u8 reg,u8 command) //address+register+command { I2C_INIT(); I2C_Start(); I2C_SendByte(address); I2C_Ack(); I2C_SendByte(reg); I2C_Ack(); I2C_SendByte(command); I2C_Ack(); I2C_Stop(); } /**************************************************************************** * 名 称:void I2C_delay(void) * 功 能:I2C 控制延时函数 * 入口参数:无 * 出口参数:无 * 说 明:无 * 调用方法:无 ****************************************************************************/ void I2C_delay(void) { u8 i=100; while(i) { i--; } } /**************************************************************************** * 名 称:bool I2C_Start(void) * 功 能:I2C起始状态 * 入口参数:无 * 出口参数:无 * 说 明:无 * 调用方法:无 ****************************************************************************/ bool I2C_Start(void) { SDA_H; //SDA置高 SCL_H; //SCL置高 I2C_delay(); if(!SDA_read)return FALSE; //SDA线为低电平则总线忙,退出 SDA_L; I2C_delay(); if(SDA_read) return FALSE; //SDA线为高电平则总线出错,退出 SDA_L; //SDA置低 I2C_delay(); return TRUE; } /**************************************************************************** * 名 称:void I2C_Stop(void) * 功 能:I2C停止状态 * 入口参数:无 * 出口参数:无 * 说 明:无 * 调用方法:无 ****************************************************************************/ void I2C_Stop(void) { SCL_L; I2C_delay(); SDA_L; I2C_delay(); SCL_H; I2C_delay(); SDA_H; I2C_delay(); } /**************************************************************************** * 名 称:void I2C_Ack(void) * 功 能:I2C ACK应答 * 入口参数:无 * 出口参数:无 * 说 明:无 * 调用方法:无 ****************************************************************************/ void I2C_Ack(void) { SCL_L; I2C_delay(); SDA_L; I2C_delay(); SCL_H; I2C_delay(); SCL_L; I2C_delay(); } /**************************************************************************** * 名 称:void I2C_NoAck(void) * 功 能:I2C 无应答 * 入口参数:无 * 出口参数:无 * 说 明:无 * 调用方法:无 ****************************************************************************/ void I2C_NoAck(void) { SCL_L; I2C_delay(); SDA_H; I2C_delay(); SCL_H; I2C_delay(); SCL_L; I2C_delay(); } /**************************************************************************** * 名 称:bool I2C_WaitAck(void) * 功 能:I2C等待应答 * 入口参数:无 * 出口参数:无 * 说 明:无 * 调用方法:无 ****************************************************************************/ bool I2C_WaitAck(void) //返回为:=1有ACK,=0无ACK { SCL_L; I2C_delay(); SDA_H; I2C_delay(); SCL_H; I2C_delay(); if(SDA_read) { SCL_L; return FALSE; } SCL_L; return TRUE; } /**************************************************************************** * 名 称:void I2C_SendByte(u8 SendByte) * 功 能:发送数据字节 * 入口参数:无 * 出口参数:无 * 说 明:无 * 调用方法:无 ****************************************************************************/ void I2C_SendByte(u8 SendByte) //数据从高位到低位// { u8 i=8; while(i--) { SCL_L; I2C_delay(); if(SendByte&0x80) SDA_H; else SDA_L; SendByte<<=1; I2C_delay(); SCL_H; I2C_delay(); } SCL_L; } /**************************************************************************** * 名 称:u8 I2C_ReceiveByte(void) * 功 能:I2C接收数据字节 * 入口参数:无 * 出口参数:无 * 说 明:无 * 调用方法:无 ****************************************************************************/ u8 I2C_ReceiveByte(void) //数据从高位到低位// { u8 i=8; u8 ReceiveByte=0; SDA_H; while(i--) { ReceiveByte<<=1; SCL_L; I2C_delay(); SCL_H; I2C_delay(); if(SDA_read) { ReceiveByte|=0x01; } } SCL_L; return ReceiveByte; } u8 read_byte(u8 address,u8 reg) //address(with bit 0 set) + register { u8 dat; I2C_INIT(); I2C_Start(); I2C_SendByte(address); I2C_Ack(); I2C_SendByte(reg); I2C_Ack(); I2C_Start(); I2C_SendByte(address+1); I2C_Ack(); dat = I2C_ReceiveByte(); I2C_NoAck(); I2C_Stop(); return dat; } // //void change_i2c_address(unsigned char addr_old, unsigned char addr_new) //// addr_old is the address now, addr_new will be the new address //{ //that you want change to //delayms(2000); //I2C_Write(&write_command, WriteAddr, 3) // Protect the eeprom ,you can delete this sentence //write_byte(addr_old,2,0x9a); //delayms(1); //write_byte(addr_old,2,0x92); //delayms(1); //write_byte(addr_old,2,0x9e); //delayms(1); //write_byte(addr_old,2, addr_new); //delayms(500); //Protect the eeprom, you can delete this sentence //} static void Delay_ARMJISHU(__IO uint32_t nCount) { for (; nCount != 0; nCount--); } void detect(void) //0xe8(address) + 0xb0(command) { u8 i; // u8 I2c_voice[3]={0xe8,2,0xb0}; u8 I2c_Buf[2]; I2C_Write(Device_Addr,2,0xb4); // I2C_Write(I2c_voice, Device_Addr,3); //use command "0xb0" to detect the distance Delay_ARMJISHU(360000); //安全延时,如果显示不清晰可以将延时调大一些 //delayms(80); //如果是探测温度此处延时需根据表1所列时间相应延长 //display(range); //等待探测结束,count值调小将减小探测等待时间 while(!GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_9));//display(range); I2c_Buf[0]=read_byte(Device_Addr,2); I2c_Buf[1]=read_byte(Device_Addr,3); for(i=0;i<=2;i++) { printf("0x%Xt", I2c_Buf); } } |
GMT+8, 2025-12-14 19:15 , Processed in 0.769955 second(s), Total 67, Slave 49 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
