扫一扫,分享给好友
//TLC5917的CLK引脚接STM32的PC7
#include "stm32f10x.h" void GPIO_configuration(void) { GPIO_InitTypeDef GPIO_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE); RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM7, ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_Init(GPIOC, &GPIO_InitStructure); } void NVIC_Configuration(void) { //定义一个结构体 NVIC_InitTypeDef NVIC_InitStructure; //设置优先级组 NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0) ; //设置 TIM7线 NVIC_InitStructure.NVIC_IRQChannel =TIM7_IRQn; //使能优先级 NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //配置抢断优先级 NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority =0; //配置响应优先级 NVIC_InitStructure.NVIC_IRQChannelSubPriority =0; NVIC_Init(&NVIC_InitStructure); //设置存入寄存器 NVIC_SetVectorTable (NVIC_VectTab_FLASH ,0x0); } //*****定时器初始化********* void TIM_Configuration (void) { TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; // TIM_Cmd(TIM7, DISABLE); //预分频系数为3600-1,这样计数器时钟为72MHz/3600 = 20kHz TIM_TimeBaseStructure.TIM_Prescaler = 3600 - 1; //设置时钟分割 TIM_CKD_DIV1=0x0000,不分割 TIM_TimeBaseStructure.TIM_ClockDivision = 0; //设置计数器模式为向上计数模式 TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up ; //设置计数溢出大小,每计2个数就让PC7翻转一下产生10KHZ的时钟信号 TIM_TimeBaseStructure.TIM_Period = 1; TIM_TimeBaseStructure.TIM_RepetitionCounter = 0; //将配置应用到TIM7中 TIM_TimeBaseInit(TIM7,&TIM_TimeBaseStructure); TIM_UpdateRequestConfig( TIM7, TIM_UpdateSource_Regular); //使能计数器 TIM_Cmd(TIM7, ENABLE); //使能中断 TIM_ITConfig(TIM7,TIM_IT_Update,ENABLE); //清除标志位 // TIM_ClearFlag(TIM7, TIM_FLAG_Update); } //***************************** int main(void) { SystemInit(); //系统时钟配置函数 通过不同的定义 来选择不同的主频 这里设置是72m GPIO_configuration (); NVIC_Configuration (); TIM_Configuration (); GPIO_ResetBits(GPIOC,GPIO_Pin_9); GPIO_SetBits(GPIOC, GPIO_Pin_6); GPIO_ResetBits(GPIOC, GPIO_Pin_6); //初始化IO口 while (1) { } } it.c中的中断函数 让PC7翻转一下产生10KHZ的时钟信号 void TIM7_IRQHandler(void) { //检测是否发生溢出更新事件 if(TIM_GetITStatus(TIM7, TIM_IT_Update)== SET) { if(i==1) { GPIO_SetBits(GPIOC, GPIO_Pin_7 | GPIO_Pin_8); i=0; } else { GPIO_ResetBits(GPIOC, GPIO_Pin_7 | GPIO_Pin_8); i=1; } TIM_ClearITPendingBit(TIM7 , TIM_FLAG_Update); } } |
相关推荐 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
如何配置Linux操作系统设备树让我的开发板可以将板子上的GPIO接口用作 I2S输出??
196 浏览 1 评论
918 浏览 0 评论
1884 浏览 0 评论
1943 浏览 2 评论
1094 浏览 0 评论
GMT+8, 2024-8-14 05:23 , Processed in 0.463682 second(s), Total 40, Slave 32 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
