#include "reg52.h"
#include #define USE_T2 #define FOSC 11059200 #define BAUD 9600 void display(); void RH(); //端口位定义,可修改 ***it SDA=P1^0; ***it SCL=P1^1; //内部数据定义 #define IIC_Add 0xB8 //器件地址 #define IIC_RX_Length 15 unsigned char IIC_TX_Buffer[]={0x03,0x00,0x04}; //读温湿度命令(无CRC校验) unsigned char IIC_RX_Buffer[IIC_RX_Length] = {0x00};//读回的温湿度 unsigned char Uart_RX_Buffer[30] = {0x00}; unsigned char *String; unsigned char WR_Flag; unsigned int Tmp; unsigned char a3[5]; unsigned char a1[3]; unsigned char a[2]; #define S_Function "Function: 03 04" #define S_Temp "Temp:" #define S_RH "RH:" #define S_CRCT "CRC: True" #define S_CRCF "CRC: Wrong" #define S_Data "Data: " #define S_NotS "Sensor Not Connected" void Ack(void); void NoAck(void); void delay10us(void) //这个延时函数 要大于5US以上 { _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); _nop_(); } void delay1ms(unsigned int t) { unsigned int i; unsigned int j; for(j=t;j>0;j--) for(i=124;i>0;i--); } void InitUART(void) { unsigned int iTmpBaud; unsigned long lTmpBaud; iTmpBaud = 0; //首先选定定时器2作为波特率发生器,16位定时器,自动装载 SCON = 0x50; //SM0 SM1 SM2 REN TB8 RB8 TI RI //0 1 0 1 0 0 0 0 PCON = 0x00; //PCON的地址是87H,这里SMOD =0 T2CON = 0x30; //TF2 EXF2 RCLK TCLK EXEN2 TR2 C(/T2) CP(/RL2) //0 0 1 1 0 0 0 0 TMOD = 0x00; // / / / / / / T2OE DCEN //0 0 0 0 0 0 0 0 //fosc = 22.1184M,6T: 144,设置波特率 //(RCAP2H,RCAP2L) = 65536- fosc/(n*Baud)。n:32(12T-mode),16:(6T-mode) lTmpBaud = FOSC/BAUD; lTmpBaud /= 32; //12T-mode iTmpBaud = lTmpBaud & 0xFFFF; iTmpBaud = 65536 - iTmpBaud; RCAP2H = (iTmpBaud>>8) & 0x0FF; RCAP2L = iTmpBaud & 0x0FF; RI = 0; //清除接收中断标志 REN = 1; //允许串行接收 ES = 1; //允许串行中断 TR2 = 1; //启动定时器1 EA=1;//开总中断 } //串口发送 void UARTSend(char UCHAR) { SBUF=UCHAR; while(TI==0); TI=0; } void UARTRead(void) interrupt 4 { char temp; if(RI) { RI=0; temp = SBUF; } } //********************************************** //送起始位 sda=1->0 void I2C_Start() { SDA=1; SCL=1; delay10us(); SDA=0; delay10us(); SCL=0; } //************************************************ //送停止位 sda=0->1 void I2C_Stop() { SDA=0; delay10us(); SCL=1; delay10us(); SDA=1; } //************************************************ //主应答(包含ack:sda=0和no_ack:sda=0) void Ack(void) { //设置SDA 口为输出 SDA=0; SCL=0; delay10us(); SCL=1; delay10us(); SCL=0; SDA=1; } void NoAck(void) { //设置SDA 口为输出 SDA=1; SCL=0; delay10us(); SCL=1; delay10us(); SDA=1; SCL=0; } // 检测 SDA是否回ACK bit Test_Ack() { //设置SDA 口为输入 bit ACK_Flag=0; SCL=0; SDA=1; delay10us(); SCL=1; delay10us(); if(SDA==0) ACK_Flag = 1; else ACK_Flag = 0; SCL=0; return ACK_Flag; } //************************************************* //字节发送程序 //发送c(可以是数据也可是地址),送完后接收从应答 //不考虑从应答位 void SendData(unsigned char buffer) { unsigned char BitCnt=8;//一字节8位 //设置SDA 口为输出 do { SCL=0; delay10us(); if((buffer&0x80)==0) //判断最高位是0还是1 SDA=0; else SDA=1; SCL=1; delay10us(); buffer=buffer<<1;//将buffer中的数据左移一位 BitCnt--; } while(BitCnt); SCL=0; } //************************************************** //字节接收程序 //接收器件传来的数据,此程序应配合|主应答函数|i2c_ack_main()使用 //return: uchar型1字节 unsigned char ReceiveData() { unsigned char BitCnt=8,IIC_RX_Data=0; unsigned char temp=0; SDA=1; //读入数据 设置SDA 口为输入 do { SCL=0; delay10us(); IIC_RX_Data=_crol_(IIC_RX_Data,1); //数据左移一位 BitCnt--; SCL=1; delay10us(); if(SDA==1) IIC_RX_Data = IIC_RX_Data|0x01; //低位置1 else IIC_RX_Data = IIC_RX_Data&0x0fe; //低位清0 } while(BitCnt); SCL=0; return IIC_RX_Data; } //*************************************************** bit WriteNByte(unsigned char sla,unsigned char *s,unsigned char n) { unsigned char i; I2C_Start(); //启动I2C SendData(sla);//发送器件地址 if(!Test_Ack()) { WR_Flag = 1; return(0); } for(i=0;i SendData(*(s+i)); if(!Test_Ack()) { WR_Flag = 1; return(0); } } I2C_Stop(); return(1); } bit ReadNByte(unsigned char Sal, unsigned char *p,unsigned char n) { unsigned char i; I2C_Start(); // 启动I2C SendData((Sal)| 0x01); //发送器件地址 if(!Test_Ack()) { WR_Flag = 1; return(0); } delay10us(); delay10us(); delay10us(); // 延时时间必须大于30us 只要大于 30us 以上的值都可以 但是最好不要太长 ,测试时,试过25MS都OK! for(i=0;i *(p+i)=ReceiveData(); //读取数据 Ack(); } *(p+n-1)=ReceiveData(); NoAck(); I2C_Stop(); return(1); } ///计算CRC校验码 unsigned int CRC16(unsigned char *ptr, unsigned char len) { unsigned int crc=0xffff; unsigned char i; while(len--) { crc ^=*ptr++; for(i=0;i<8;i++) { if(crc & 0x1) { crc>>=1; crc^=0xa001; } else { crc>>=1; } } } return crc; } ///检测CRC校验码是否正确 unsigned char CheckCRC(unsigned char *ptr,unsigned char len) { unsigned int crc; crc=(unsigned int)CRC16(ptr,len-2); if(ptr[len-1]==(crc>>8) && ptr[len-2]==(crc & 0x00ff)) { return 0xff; } else { return 0x0; } } void Waken(void) { I2C_Start(); // 启动I2C SendData(IIC_Add); // 发送器件地址 Test_Ack(); // 唤醒指令时 传感器不会回ACK 但是第一定要发检测ACK的时钟 否则会出错 delay1ms(2); // 至少延时1个Ms 说明书里,有个最大值 ,实际当中 你只要大于1MS I2C_Stop(); } void UART_PutString(unsigned char *buf ) { while(*buf) UARTSend(*buf++); } void UART_PutStringAndNum(unsigned char *buf ,unsigned int num) { unsigned char i; a1[3] = '0'+num%10; a1[2] = '.'; a1[1] = '0'+num/10%10; a1[0] = '0'+num/100%10; while(*buf) UARTSend(*buf++); UARTSend(' '); for(i=0;i<4;i++) { UARTSend(a1[i]); } } void UART_PutStringAnd_Data(unsigned char *buf ,unsigned char *bufdata) { unsigned char i,j; while(*buf) UARTSend(*buf++); UARTSend(' '); for(i=0;i<8;i++) { a[0] = bufdata[i]/16; a[1] = bufdata[i]%16; for(j=0;j<2;j++) { if(a[j]>9) { a[j] = (a[j]-10)+'A'; } else { a[j] = a[j]+'0'; } UARTSend(a[j]); } UARTSend(' '); } } void UARTSend_Nbyte(void) { if(WR_Flag == 0) { if(CheckCRC(IIC_RX_Buffer,8)) { String = S_Function; // "Function: 03 04" UART_PutString(String); UARTSend(' '); UARTSend(' '); String = S_RH;//"RH:" Tmp = IIC_RX_Buffer[2]*256+IIC_RX_Buffer[3]; UART_PutStringAndNum(String,Tmp); UARTSend(' '); UARTSend(' '); String = S_Temp; //"Temp:" Tmp = IIC_RX_Buffer[4]*256+IIC_RX_Buffer[5]; UART_PutStringAndNum(String,Tmp); UARTSend(' '); UARTSend(' '); String = S_CRCT;//"CRC: True"; UART_PutString(String); }else { String = S_Data;//"Data: "; UART_PutStringAnd_Data(String,IIC_RX_Buffer); UARTSend(' '); UARTSend(' '); String = S_CRCF;//"CRC: Wrong"; UART_PutString(String); } } else { String = S_NotS;//"Sensor Not Connected"; UART_PutString(String); } UARTSend(0x0A); } void Clear_Data (void) { int i; for(i=0;i IIC_RX_Buffer[i] = 0x00; }//接收数据清零 } void main(void) { SCL = 1; SDA = 1; //上电时保证两总线为高 InitUART(); Clear_Data(); while(1) { Clear_Data(); // 清除收到数据 WR_Flag = 0; Waken(); // 唤醒传感器 //发送读指令 WriteNByte(IIC_Add,IIC_TX_Buffer,3); //发送读取或写数据命令后,至少等待2MS(给探头返回数据作时间准备) delay1ms(2); //读返回数据 ReadNByte(IIC_Add,IIC_RX_Buffer,8); SCL = 1; SDA = 1; //确认释放总线 //通过串口向上发送传感器数据 UARTSend_Nbyte(); display(); // delay1ms(2000); //延时 2S (两次读取间隔至少2S) } } 采用的是指针形式,小弟一直没读出数据来,应该怎么读出字符串,求大神指点,,,, |
1 个讨论
求大神指导。。。。。
/9
GMT+8, 2025-12-3 19:19 , Processed in 0.795863 second(s), Total 67, Slave 47 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3052
