#include #define uchar unsigned char #define uint unsigned int ***it DQ=P1^0;//ds18b20与单片机连接口 ***it RS=P3^0; ***it RW=P3^1; ***it EN=P3^2; unsigned char code str1[]={"temperature: "}; unsigned char code str2[]={" "}; uchar data disdata[5]; uint tvalue;//温度值 uchar tflag;//温度正负标志 /*************************lcd1602程序**************************/ void delay1ms(unsigned int ms)//延时1毫秒(不够精确的) {unsigned int i,j; for(i=0;i } void wr_com(unsigned char com)//写指令// { delay1ms(1); RS=0; RW=0; EN=0; P2=com; delay1ms(1); EN=1; delay1ms(1); EN=0; } void wr_dat(unsigned char dat)//写数据// { delay1ms(1);; RS=1; RW=0; EN=0; P2=dat; delay1ms(1); EN=1; delay1ms(1); EN=0; } void lcd_init()//初始化设置// {delay1ms(15); wr_com(0x38);delay1ms(5); wr_com(0x08);delay1ms(5); wr_com(0x01);delay1ms(5); wr_com(0x06);delay1ms(5); wr_com(0x0c);delay1ms(5); } void display(unsigned char *p)//显示// { while(*p!=' |
