扫一扫,分享给好友
3个回答
加:判断加数最低位,若为1则被加数加一,为0被加数不变,然后加数右移一位,重复判断最低位;
减:是把减数取反加一后,按加法进行计算; 这样说你也不会明白,我还是用一个乘法的例子给你说明吧;除法也是一样,都是通过移位实现的;称为booth算法移位乘法器:module booth_multiplier_module ( input clk, input rstn, input Start_Sig, input[7:0] A, input[7:0] B, output Done_Sig, output[15:0]Product, output[7:0] SQ_a, output[7:0] SQ_s, output[16:0]SQ_p ); /********************************/ reg [3:0] i; reg [7:0] a;//result of A reg [7:0] s;//reverse result of A reg[16:0] p;//operation register reg [3:0] X; reg isDone; always @(posedge clk or negedge rstn) if(!rstn) begin i <= 4'd0; a <= 8'd0; s <= 8'd0; p <= 17'd0; X <= 4'd0; isDone <= 1'b0; end else if(Start_Sig) case(i) 0: begin a <= A; s <= (~A + 1'b1); p <= {8'd0,B,1'b0}; i <= i + 1'b1; end 1: begin if(p[1:0] == 2'b01) p <= {p[16:9] + a,p[8:0]}; else if(p[1:0] == 2'b10) begin p <= {p[16:9] + s,p[8:0]}; i <= i + 1'b1; end end 2: if(X ==8) begin X <= 4'd0; i <= i + 1'b1; end else begin p <= {p[16],p[16:1]}; X <= X + 1'b1; i <= i - 1'b1; end 3: begin isDone <= 1'b1; i <= i + 1'b1; end 4: begin isDone <= 1'b0; i <= 4'd0; end endcase /*************************************/ assign Done_Sig = isDone; assign Product = p[16:1]; /********************/ assign SQ_a = a; assign SQ_s = s; assign SQ_p = p; endmodule |
再给你一个除法器:整两个都是整数除法器,你可以用数试一试:
module streamlined_divider_module ( input CLK, input RSTn, input Start_Sig, input [7:0] Dividend, input [7:0] Divisor, output Done_Sig, output [7:0]Quotient, output [7:0]Reminder, /***************************/ output[15:0]SQ_Diff, output[15:0]SQ_Temp ); /****************************/ reg [3:0] i; reg [8:0] s; reg[15:0] Temp; reg[15:0] Diff; reg isNeg; reg isDone; always @(posedge CLK or negedge RSTn) if(!RSTn) begin i <= 4'd0; s <= 9'd0; Temp <= 16'd0; Diff <= 16'd0; isNeg <= 1'b0; isDone <= 1'b0; end else if(Start_Sig) begin case(i) 0: begin isNeg <= Dividend[7]^Divisor[7]; s <= Divisor[7]?{1'b1,Divisor}:{1'b1,~Divisor+1'b1}; Temp <= Dividend[7]?{8'd0,~Dividend + 1'b1}:{8'd0,Dividend}; Diff <= 16'd0; i <= i + 1'b1; end 1,2,3,4,5,6,7,8: begin Diff = Temp + {s,7'd0}; if(Diff[15]) Temp<= {Temp[14:0],1'b0}; else Temp<= {Diff[14:0],1'b1}; i <= i + 1'b1; end 9: begin isDone<= 1'b1; i <= i + 1'b1; end 10: begin isDone<= 1'b0; i <= 2'd0; end endcase /********************************/ assign Done_Sig = isDone; assign Quotient = isNeg ? (~Temp[7:0] + 1'b1) : Temp[7:0]; assign Reminder = Temp[15:8]; /********************************/ assign SQ_Diff = Diff; assign SQ_Temp = Temp; /*********************************/ endmodule |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
NVMe高速传输之摆脱XDMA设计50:主要功能测试结果与分析2 nvmePCIe高速存储
252 浏览 0 评论
NVMe高速传输之摆脱XDMA设计49:主要功能测试结果与分析1
1501 浏览 0 评论
907 浏览 0 评论
855 浏览 0 评论
658 浏览 0 评论
4426 浏览 63 评论
/9
GMT+8, 2025-12-2 03:54 , Processed in 0.863415 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2202
