扫一扫,分享给好友
2个回答
module counter(clk,key_in,sm_bit,sm_seg);
input clk; input [1:0] key_in; output [7:0] sm_seg; output [3:0] sm_bit; reg ms,keyen; reg [3:0] sm_bit_reg; reg [7:0] sm_seg_reg; reg [15:0]counter; reg [21:0] count; reg [7:0] dis_dat; reg [1:0] dout1,dout2,dout3; wire[1:0] key_done; wire [3:0] sm_bit; wire [7:0] sm_seg; assign sm_bit = sm_bit_reg; assign sm_seg = sm_seg_reg; assign key_done = (dout1 | dout2 | dout3); always @(posedge count[17]) begin dout1 <= key_in; dout2 <= dout1; dout3 <= dout2; end always @(posedge clk) begin count<=count+1'b1; if(count==22'd2500000) begin count<=22'd0; ms = ~ms; end end always @(negedge key_done[1]) begin keyen = ~keyen; end always @(posedge ms) begin if(!key_done[0]) counter<=16'd0; else if(!keyen) begin counter[3:0]<=counter+1'b1; if(counter[3:0]==4'h9) begin counter[3:0]<=4'd0; counter[7:4]<=counter[7:4]+1'b1; if(counter[7:4]==4'h9) begin counter[7:4]<=4'd0; counter[11:8]<=counter[11:8]+1'b1; if(counter[11:8]==4'h9) begin counter[11:8]<=4'd0; counter[15:12]<=counter[15:12]+1'b1; if(counter[15:12]==4'h9) begin counter[15:12]<=4'd0; end end end end end end always @(posedge clk) begin case(count[17:16]) 2'd0:sm_bit_reg<=4'b1110; 2'd1:sm_bit_reg<=4'b1101; 2'd2:sm_bit_reg<=4'b1011; 2'd3:sm_bit_reg<=4'b0111; default:sm_bit_reg<=4'b0000; endcase case(count[17:16]) 2'd0:dis_dat<=counter[3:0]; 2'd1:dis_dat<=counter[7:4]; 2'd2:dis_dat<=counter[11:8]; 2'd3:dis_dat<=counter[15:12]; default:dis_dat<=4'd0; endcase end always @(posedge clk) begin case(dis_dat) 4'h0 : sm_seg_reg = 8'hc0; // "0" 4'h1 : sm_seg_reg = 8'hf9; // "1" 4'h2 : sm_seg_reg = 8'ha4; // "2" 4'h3 : sm_seg_reg = 8'hb0; // "3" 4'h4 : sm_seg_reg = 8'h99; // "4" 4'h5 : sm_seg_reg = 8'h92; // "5" 4'h6 : sm_seg_reg = 8'h82; // "6" 4'h7 : sm_seg_reg = 8'hf8; // "7" 4'h8 : sm_seg_reg = 8'h80; // "8" 4'h9 : sm_seg_reg = 8'h90; // "9" default:sm_seg_reg<=8'hff; endcase if(count[17:16]==2'd1) sm_seg_reg<=8'b0xxx_xxxx; end endmodule 参考然后自己修改一下看看咯 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
NVMe高速传输之摆脱XDMA设计50:主要功能测试结果与分析2 nvmePCIe高速存储
252 浏览 0 评论
NVMe高速传输之摆脱XDMA设计49:主要功能测试结果与分析1
1501 浏览 0 评论
907 浏览 0 评论
855 浏览 0 评论
658 浏览 0 评论
4426 浏览 63 评论
/9
GMT+8, 2025-12-2 03:53 , Processed in 0.586159 second(s), Total 76, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2409
