3 个讨论
这个使用单片机:stc12c5a60s2可不可以帮我改成stc at89c52 谢谢了.... //***************************************************** //名称:单片机串口输出ADXL335角度值 //使用单片机:stc12c5a60s2 //供电:电压5v //晶振:11.0592m //X轴->(ADC0)P1.0 //Y轴->(ADC1)P1.1 //Z轴->(ADC1)P1.2 //用pc串口助手显示时,选择字符显示 //参考宏晶网址例程 //***************************************************** #include "reg51.h" #include "intrins.h" #include #include //#define FOSC 18432000L #define FOSC 11059200L //晶振11.0592M #define BAUD 9600 typedef unsigned char BYTE; typedef unsigned int WORD; #define uchar unsigned char #define uint unsigned int /*Declare SFR associated with the ADC */ sfr AUXR1 = 0XA2; sfr ADC_CONTR = 0xBC; //ADC control register sfr ADC_RES = 0xBD; //ADC high 8-bit result register sfr ADC_RESL = 0xBE; sfr ADC_LOW2 = 0xBE; //ADC low 2-bit result register sfr P1ASF = 0x9D; //P1 secondary function control register /*Define ADC operation const for ADC_CONTR*/ #define ADC_POWER 0x80 //ADC power control bit #define ADC_FLAG 0x10 //ADC complete flag #define ADC_START 0x08 //ADC start control bit #define ADC_SPEEDLL 0x00 //420 clocks #define ADC_SPEEDL 0x20 //280 clocks #define ADC_SPEEDH 0x40 //140 clocks #define ADC_SPEEDHH 0x60 //70 clocks void InitUart(); void InitADC(); void SendData(BYTE dat); int GetADCResult(BYTE ch); void Delay(WORD n); uchar ge,shi,bai,qian,wan; //显示变量 void conversion(uint temp_data) { wan=temp_data/10000+0x30 ; temp_data=temp_data%10000; //取余运算 qian=temp_data/1000+0x30 ; temp_data=temp_data%1000; //取余运算 bai=temp_data/100+0x30 ; temp_data=temp_data%100; //取余运算 shi=temp_data/10+0x30 ; temp_data=temp_data%10; //取余运算 ge=temp_data+0x30; } /*---------------------------- Get ADC result ----------------------------*/ int GetADCResult(BYTE ch) { int AD10bitResult; ADC_CONTR = ADC_POWER | ADC_SPEEDLL | ch | ADC_START; _nop_(); //Must wait before inquiry _nop_(); _nop_(); _nop_(); while (!(ADC_CONTR & ADC_FLAG));//Wait complete flag ADC_CONTR &= ~ADC_FLAG; //Close ADC AD10bitResult=ADC_RES; AD10bitResult<<=8; AD10bitResult|=ADC_RESL; return AD10bitResult; //Return 10BIT ADC result } /*---------------------------- Initial UART ----------------------------*/ void InitUart() { SCON = 0x5a; //8 bit data ,no parity bit TMOD = 0x20; //T1 as 8-bit auto reload TH1 = TL1 = -(FOSC/12/32/BAUD); //Set Uart baudrate TR1 = 1; //T1 start running } /*---------------------------- Initial ADC sfr ----------------------------*/ void InitADC() { P1ASF = 0xff; //Open 8 channels ADC function AUXR1=AUXR1|0X04; //ad值左对齐 ADC_RES = 0; //Clear previous result ADC_CONTR = ADC_POWER | ADC_SPEEDLL; Delay(2); //ADC power-on and delay } /*---------------------------- Send one byte data to PC Input: dat (UART data) Output:- ----------------------------*/ void SendData(BYTE dat) { while (!TI); //Wait for the previous data is sent TI = 0; //Clear TI flag SBUF = dat; //Send current data } /*---------------------------- Software delay function ----------------------------*/ void Delay(WORD n) { WORD x; while (n--) { x = 5000; while (x--); } } //****************************************************************************** void main() { int x,y,z; float Q,T,K,Roll,Pitch; InitUart(); //Init UART, use to show ADC result InitADC(); //Init ADC sfr while (1) { x=GetADCResult(0); y=GetADCResult(1); z=GetADCResult(2); // 0-5v 对应 0-1024 // 3.3v/2 = 1.65v(0g时候值) // 1.65v ->= 338 (AD值即0X0152) x-=0X0152; // y-=0X0152; z-=0X0152; Q=x; T=y; K=z; Q=-Q; Roll=(float)(((atan2(K,Q)*180)/3.14159265)+180); Pitch=(float)(((atan2(K,T)*180)/3.14159265)+180); conversion(Roll); //横滚角0-360度 //conversion(Pitch); //俯仰角0-360度 SendData(bai); SendData(shi); SendData(ge); SendData(0x0d); SendData(0x0a);//换行,回车 Delay(30); } } |
下面程序使用单片机:stc12c5a60s2帮我改成 stc at89c52 谢谢... //***************************************************** //名称:单片机串口输出ADXL335角度值 //使用单片机:stc12c5a60s2 //供电:电压5v //晶振:11.0592m //X轴->(ADC0)P1.0 //Y轴->(ADC1)P1.1 //Z轴->(ADC1)P1.2 //用pc串口助手显示时,选择字符显示 //参考宏晶网址例程 //***************************************************** #include "reg51.h" #include "intrins.h" #include #include //#define FOSC 18432000L #define FOSC 11059200L //晶振11.0592M #define BAUD 9600 typedef unsigned char BYTE; typedef unsigned int WORD; #define uchar unsigned char #define uint unsigned int /*Declare SFR associated with the ADC */ sfr AUXR1 = 0XA2; sfr ADC_CONTR = 0xBC; //ADC control register sfr ADC_RES = 0xBD; //ADC high 8-bit result register sfr ADC_RESL = 0xBE; sfr ADC_LOW2 = 0xBE; //ADC low 2-bit result register sfr P1ASF = 0x9D; //P1 secondary function control register /*Define ADC operation const for ADC_CONTR*/ #define ADC_POWER 0x80 //ADC power control bit #define ADC_FLAG 0x10 //ADC complete flag #define ADC_START 0x08 //ADC start control bit #define ADC_SPEEDLL 0x00 //420 clocks #define ADC_SPEEDL 0x20 //280 clocks #define ADC_SPEEDH 0x40 //140 clocks #define ADC_SPEEDHH 0x60 //70 clocks void InitUart(); void InitADC(); void SendData(BYTE dat); int GetADCResult(BYTE ch); void Delay(WORD n); uchar ge,shi,bai,qian,wan; //显示变量 void conversion(uint temp_data) { wan=temp_data/10000+0x30 ; temp_data=temp_data%10000; //取余运算 qian=temp_data/1000+0x30 ; temp_data=temp_data%1000; //取余运算 bai=temp_data/100+0x30 ; temp_data=temp_data%100; //取余运算 shi=temp_data/10+0x30 ; temp_data=temp_data%10; //取余运算 ge=temp_data+0x30; } /*---------------------------- Get ADC result ----------------------------*/ int GetADCResult(BYTE ch) { int AD10bitResult; ADC_CONTR = ADC_POWER | ADC_SPEEDLL | ch | ADC_START; _nop_(); //Must wait before inquiry _nop_(); _nop_(); _nop_(); while (!(ADC_CONTR & ADC_FLAG));//Wait complete flag ADC_CONTR &= ~ADC_FLAG; //Close ADC AD10bitResult=ADC_RES; AD10bitResult<<=8; AD10bitResult|=ADC_RESL; return AD10bitResult; //Return 10BIT ADC result } /*---------------------------- Initial UART ----------------------------*/ void InitUart() { SCON = 0x5a; //8 bit data ,no parity bit TMOD = 0x20; //T1 as 8-bit auto reload TH1 = TL1 = -(FOSC/12/32/BAUD); //Set Uart baudrate TR1 = 1; //T1 start running } /*---------------------------- Initial ADC sfr ----------------------------*/ void InitADC() { P1ASF = 0xff; //Open 8 channels ADC function AUXR1=AUXR1|0X04; //ad值左对齐 ADC_RES = 0; //Clear previous result ADC_CONTR = ADC_POWER | ADC_SPEEDLL; Delay(2); //ADC power-on and delay } /*---------------------------- Send one byte data to PC Input: dat (UART data) Output:- ----------------------------*/ void SendData(BYTE dat) { while (!TI); //Wait for the previous data is sent TI = 0; //Clear TI flag SBUF = dat; //Send current data } /*---------------------------- Software delay function ----------------------------*/ void Delay(WORD n) { WORD x; while (n--) { x = 5000; while (x--); } } //****************************************************************************** void main() { int x,y,z; float Q,T,K,Roll,Pitch; InitUart(); //Init UART, use to show ADC result InitADC(); //Init ADC sfr while (1) { x=GetADCResult(0); y=GetADCResult(1); z=GetADCResult(2); // 0-5v 对应 0-1024 // 3.3v/2 = 1.65v(0g时候值) // 1.65v ->= 338 (AD值即0X0152) x-=0X0152; // y-=0X0152; z-=0X0152; Q=x; T=y; K=z; Q=-Q; Roll=(float)(((atan2(K,Q)*180)/3.14159265)+180); Pitch=(float)(((atan2(K,T)*180)/3.14159265)+180); conversion(Roll); //横滚角0-360度 //conversion(Pitch); //俯仰角0-360度 SendData(bai); SendData(shi); SendData(ge); SendData(0x0d); SendData(0x0a);//换行,回车 Delay(30); } } |
只有小组成员才能发言,加入小组>>
/9
GMT+8, 2025-12-2 01:03 , Processed in 0.764408 second(s), Total 49, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
118
