扫一扫,分享给好友
我想要当采集时钟时间为晚上八点也就是20点时,蜂鸣器响,为什么从仿真中看引脚一直是灰色的呢?
#include #include #define uint unsigned int #define uchar unsigned char ***it SDA=P1^0; //1302引脚端 ***it SCK=P1^1; ***it RST=P1^2; ***it lcden=P2^2; //1602引脚端 ***it lcdrs=P2^0; ***it lcdrw=P2^1; ***it bemp=P3^7; //蜂鸣器 uchar code table[]={"0123456789-:"}; //显示 void delayus(uint t) { uchar i; for(i=0;i void write_1302_byte(uchar dat) //写一个字节 { uchar i; SCK=0; delayus(2); for(i=0;i<8;i++) { SDA=dat&0x01; delayus(2); SCK=1; delayus(2); SCK=0; dat>>=1; } } void write_1302(uchar add,uchar date) //写一条命令 { RST=0; SCK=0; RST=1; delayus(2); write_1302_byte(add); write_1302_byte(date); SCK=1; RST=0; } uchar read_1302_byte() //读一个字节 { uchar i,dat; delayus(2); for(i=0;i<8;i++) { dat>>=1; if(SDA==1) dat|=0x80; SCK=1; delayus(2); SCK=0; delayus(2); } return dat; } uchar read_1302(uchar add) //读一条命令 { uchar date; RST=0; SCK=0; RST=1; write_1302_byte(add); date=read_1302_byte(); SCK=1; RST=0; return date; } void init_1302() //1302初始化 { uchar flag; flag=read_1302(0x81); if(flag&0x80) //如果秒最高位为1,则此时始终振荡器停止 { write_1302(0x8e,0x00); //写不保护指令打开 write_1302(0x80,((55/10)<<4|(55%10))); //写秒,55s write_1302(0x82,((59/10)<<4|(59%10))); //写分,59min write_1302(0x84,((21/10)<<4|(21%10))); //写时,21h write_1302(0x86,((11/10)<<4|(11%10))); //写日,11日 write_1302(0x88,((4/10)<<4|(4%10))); //写月,4月 write_1302(0x8c,((13/10)<<4|(13%10))); //写年,13年 write_1302(0x8e,0x80); //打开写保护指令 } } void delayms(uint z) //1ms延时 { uint x,y; for(x=z;z>0;z--) for(y=110;y>0;y--); } void write_com(uchar com) //1602写命令 { lcdrs=0; lcdrw=0; P0=com; delayms(5); lcden=1; delayms(5); lcden=0; } void write_date(uchar date) //1602写数据 { lcdrs=1; lcdrw=0; P0=date; delayms(5); lcden=1; delayms(5); lcden=0; } void dispsecond(uchar x) //显示秒 { uchar i,j; i=x/10; j=x%10; write_com(0xc0+0x0c); write_date(table[i]); write_date(table[j]); delayms(50); } void dispminute(uchar x) //显示分 { uchar i,j; i=x/10; j=x%10; write_com(0xc0+0x09); write_date(table[i]); write_date(table[j]); write_date(table[11]); delayms(50); } void disphour(uchar x) //显示时 { uchar i,j; i=x/10; j=x%10; write_com(0xc0+0x06); write_date(table[i]); write_date(table[j]); write_date(table[11]); delayms(50); } void dispday(uchar x) //显示日 { uchar i,j; i=x/10; j=x%10; write_com(0x80+0x0d); write_date(table[i]); write_date(table[j]); delayms(50); } void dispmonth(uchar x) //显示月 { uchar i,j; i=x/10; j=x%10; write_com(0x80+0x0a); write_date(table[i]); write_date(table[j]); write_date(table[10]); delayms(50); } void dispyear(uchar x) //显示年 { uchar i,j; i=x/10; j=x%10; write_com(0x80+0x07); write_date(table[i]); write_date(table[j]); write_date(table[10]); delayms(50); } void init_1602() //1602初始化 { lcden=0; write_com(0x38); write_com(0x0c); write_com(0x06); write_com(0x01); } void init() { TMOD=0X01; TH0=(65535-50000)/256; TL0=(65535-50000)%256; EA=1; ET0=1; TR0=1; } void main() { uchar second,minute,hour,day,month,year; uchar read_value; init_1602(); init_1302(); write_com(0x80); write_date('D'); write_date('a'); write_date('t'); write_date('e'); write_com(0x80+0x05); write_date('2'); write_date('0'); write_com(0xc0); write_date('T'); write_date('i'); write_date('m'); write_date('e'); init(); while(1) { read_value=read_1302(0x8d); //读年 year=((read_value&0x70)>>4)*10+(read_value&0x0f); dispyear(year); //显示年 read_value=read_1302(0x89); //读月 month=((read_value&0x70)>>4)*10+(read_value&0x0f); dispmonth(month); //显示月 read_value=read_1302(0x87); //读日 day=((read_value&0x70)>>4)*10+(read_value&0x0f); dispday(day); //显示日 read_value=read_1302(0x85); //读时 hour=((read_value&0x70)>>4)*10+(read_value&0x0f); disphour(hour); //显示小时 read_value=read_1302(0x83); //读分 minute=((read_value&0x70)>>4)*10+(read_value&0x0f); dispminute(minute); //显示分 read_value=read_1302(0x81); //读秒 second=((read_value&0x70)>>4)*10+(read_value&0x0f);//将BCD码转换为十进制 dispsecond(second);//显示秒 /* if(hour/10==2&&(hour%10==2)) { bemp=0; delayms(5); bemp=1; delayms(5); }*/ } } void xx() interrupt 1 { uchar num,read_value,hour; TH0=(65535-50000)/256; TL0=(65535-50000)%256; num++; if(num==20) { num=0; read_value=read_1302(0x85); //读时 hour=((read_value&0x70)>>4)*10+(read_value&0x0f); if(hour/10==2&&(hour%10==0)) bemp=~bemp; } } |
相关推荐 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
265 浏览 0 评论
【原创】【RA4M2-SENSOR开发板评测】低功耗+USB综合测试
789 浏览 0 评论
1306 浏览 2 评论
787 浏览 0 评论
【RA4M2-SENSOR开发板评测】Analogue+Timers综合测试
1587 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
16901 浏览 31 评论
/9
GMT+8, 2025-12-2 06:04 , Processed in 0.565152 second(s), Total 70, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3729
