扫一扫,分享给好友
帮忙看看
#include #define usher unsigned char #define uint unsigned int #define KEY P3^0 uchar KY; //KY作用在后面说明 uchar disp;//显示汉字指针 uchar pic=0,num=0;//pic为按键次数;num为中断次数 uchar code love[] = { 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0x3F,0x00,0x20,0x00,0x20,0x00,0x20, 0x00,0x20,0x00,0x20,0x00,0x20,0x00,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0xF8,0x0F, 0x04,0x10,0x02,0x20,0x02,0x20,0x02,0x20,0x02,0x20,0x04,0x10,0xF8,0x0F,0x00,0x00, 0x00,0x00,0x00,0x00,0xFE,0x07,0x00,0x08,0x00,0x10,0x00,0x20,0x00,0x20,0x00,0x10, 0x00,0x08,0xFE,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0x3F,0x82,0x20,0x82,0x20, 0x82,0x20,0x82,0x20,0x82,0x20,0x82,0x20,0x82,0x20,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*LOVE*/ }; uchar code loveyou[] = { 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x78,0x00,0xFC,0x00,0xFE,0x01,0xFE,0x03,0xFE,0x07,0xFE,0x0F,0xFE,0x1F,0xFC,0x3F, 0xF8,0x7F,0xFC,0x3F,0xFE,0x1F,0xFE,0x0F,0xFE,0x07,0xFE,0x03,0xFE,0x01,0xFC,0x00, 0x78,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*心形图案*/ }; uchar code hehe[] = { 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x01,0x40,0x01,0xC0,0x01,0x00,0x00,0x00,0x00, 0xF0,0x0F,0x08,0x10,0x04,0x20,0x00,0x00,0x00,0x00,0xF0,0x3F,0x08,0x00,0x04,0x00, 0x04,0x00,0x04,0x00,0x08,0x00,0xF0,0x3F,0x00,0x00,0x00,0x00,0x00,0x20,0x00,0x20, 0x00,0x20,0x00,0x20,0x00,0x20,0x00,0x00,0x00,0x00,0xF0,0x3F,0x08,0x00,0x04,0x00, 0x04,0x00,0x04,0x00,0x08,0x00,0xF0,0x3F,0x00,0x00,0x00,0x00,0x04,0x20,0x08,0x10, 0xF0,0x0F,0x00,0x00,0x00,0x00,0xC0,0x01,0x40,0x01,0xC0,0x01,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*呵呵o(∩_∩)o图案*/ }; unsigned char code hanzi[] = { //-- 欢 -- 0x04,0x10,0x34,0x08,0xC4,0x06,0x04,0x01, 0xC4,0x82,0x3C,0x8C,0x20,0x40,0x10,0x30, 0x0F,0x0C,0xE8,0x03,0x08,0x0C,0x08,0x10, 0x28,0x60,0x18,0xC0,0x00,0x40,0x00,0x00, //-- 迎 -- 0x40,0x00,0x42,0x40,0x44,0x20,0xC8,0x1F, 0x00,0x20,0xFC,0x47,0x04,0x42,0x02,0x41, 0x82,0x40,0xFC,0x7F,0x04,0x40,0x04,0x42, 0x04,0x44,0xFE,0x63,0x04,0x20,0x00,0x00, //-- 使 -- 0x40,0x00,0x20,0x00,0xF8,0xFF,0x07,0x00, 0x04,0x80,0xF4,0x43,0x14,0x45,0x14,0x29, 0x14,0x19,0xFF,0x17,0x14,0x21,0x14,0x21, 0x14,0x41,0xF6,0xC3,0x04,0x40,0x00,0x00, //-- 用 -- 0x00,0x80,0x00,0x60,0xFE,0x1F,0x22,0x02, 0x22,0x02,0x22,0x02,0x22,0x02,0xFE,0x7F, 0x22,0x02,0x22,0x02,0x22,0x42,0x22,0x82, 0xFF,0x7F,0x02,0x00,0x00,0x00,0x00,0x00, //-- 神 -- 0x08,0x01,0x88,0x00,0x49,0x00,0xEE,0xFF, 0x58,0x00,0x88,0x00,0x00,0x00,0xF8,0x1F, 0x88,0x08,0x88,0x08,0xFF,0xFF,0x88,0x08, 0x88,0x08,0xFC,0x1F,0x08,0x00,0x00,0x00, //-- 奇 -- 0x40,0x00,0x40,0x00,0x44,0x00,0x44,0x3E, 0x64,0x12,0x54,0x12,0x4C,0x12,0x47,0x12, 0x4C,0x3F,0x54,0x42,0x74,0x80,0xC6,0x7F, 0x44,0x00,0x60,0x00,0x40,0x00,0x00,0x00, //-- 魔 -- 0x00,0x40,0x00,0x30,0xFE,0x8F,0x4A,0x80, 0xAA,0x5F,0x9A,0x4A,0xFE,0x2A,0xAA,0x1A, 0xCB,0x0F,0xAA,0x7A,0xFE,0x8A,0x9A,0xAA, 0xAA,0x8F,0x6B,0x80,0x22,0xE0,0x00,0x00, //-- 幻 -- 0x80,0x20,0xC0,0x30,0xA0,0x28,0x98,0x24, 0x87,0x22,0x80,0x21,0xC4,0x30,0x04,0x60, 0x04,0x00,0x04,0x20,0x04,0x40,0x04,0x80, 0x04,0x40,0xFE,0x3F,0x04,0x00,0x00,0x00, //-- 摇 -- 0x10,0x02,0x10,0x42,0x10,0x81,0xFF,0x7F, 0x90,0x04,0x54,0x05,0xCC,0xF4,0xB4,0x44, 0x84,0x44,0xBC,0x7F,0x82,0x44,0xA2,0x44, 0x9B,0xF4,0x82,0x06,0x00,0x04,0x00,0x00, //-- 摇 -- 0x10,0x02,0x10,0x42,0x10,0x81,0xFF,0x7F, 0x90,0x04,0x54,0x05,0xCC,0xF4,0xB4,0x44, 0x84,0x44,0xBC,0x7F,0x82,0x44,0xA2,0x44, 0x9B,0xF4,0x82,0x06,0x00,0x04,0x00,0x00, //-- 棒 -- 0x10,0x04,0x10,0x03,0xD0,0x00,0xFF,0xFF, 0x90,0x00,0x54,0x05,0x44,0x12,0xD4,0x15, 0x74,0x14,0x5F,0xFF,0xD4,0x14,0x54,0x15, 0x56,0x12,0x44,0x06,0x40,0x02,0x00,0x00, //-- ! -- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x7C,0x10,0xFE,0x3B, 0xFE,0x3B,0x7C,0x10,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, }; /*****函数声明*****/ void display1(void); void display2(void); void display3(void); void display4(void); /*****n(us)延时子程序*****/ void DelayUs(uint N) { uint x; for(x=0; x<=N;x++); } /*****中断服务程序*****/ void intersvr0(void) interrupt 0 using 1 { KY=~KY;//每个摇动来回水银开关会在摆幅两端分别产生下降沿中断,只提取其中一次(从左向右摇才显示) if(KY==0)(从左向右摇才显示) { num++;//计算中断次数 switch(pic)//选择画面 { case 0:{display1();}break; case 1:{display2();}break; case 2:{display3();}break; case 3:{display4();}break; default:{display1();} } } } /*****显示子程序1(汉字)*****/ void display1(void) { uchar i; if(num>10){disp++;num=0;}//12个汉字分为3次显示完(每次显示4个),每中断10次切换 if(disp>2)disp=0; DelayUs(5200);//此处延时时间依各硬件差别而各不相同,试着调整使得显示内容居中即可 for(i=0;i<64;i++) { P0=~hanzi[disp*128+i*2]; P2=~hanzi[disp*128+i*2+1]; DelayUs(100); } } /*****显示子程序2(LOVE)*****/ void display2(void) { uchar i; DelayUs(4000); for(i=0;i<64;i++) { P0=~love[i*2]; P2=~love[i*2+1]; DelayUs(120); } } /*****显示子程序3(心形图案)*****/ void display3(void) { uchar i; DelayUs(4000); for(i=0;i<64;i++) { P0=~loveyou[i*2]; P2=~loveyou[i*2+1]; DelayUs(120); } } /*****显示子程序4(呵呵o(∩_∩)o图案)*****/ void display4(void) { uchar i; DelayUs(4000); for(i=0;i<64;i++) { P0=~hehe[i*2]; P2=~hehe[i*2+1]; DelayUs(120); } } /*****主函数*****/ void main(void) { IT0=1; EX0=1; EA=1;//开中断,下降沿中断 KY=0; while(1)//主程序中只检测按键 { if(KEY==0)//画面切换键按下 { DelayUs(10000);//按键去抖 if(KEY==0); pic++;} if(pic>3)pic=0; } } /*****END*****/
8个回答
说的那么清楚 少了个分号 还要怎么说呢?
粗心,认真点,看图就知道你写错哪了
还有开头就出差了
改着两处旧OK了
改好了,谢谢
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
265 浏览 0 评论
【原创】【RA4M2-SENSOR开发板评测】低功耗+USB综合测试
789 浏览 0 评论
1306 浏览 2 评论
787 浏览 0 评论
【RA4M2-SENSOR开发板评测】Analogue+Timers综合测试
1587 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
16901 浏览 31 评论
/9
GMT+8, 2025-12-2 05:47 , Processed in 0.798606 second(s), Total 87, Slave 68 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1588
