#include
#include #define uint unsigned int //宏定义 #define uchar unsigned char //宏定义 ***it dula=P2^6; ***it wela=P2^7; ***it spk=P3^0; ***it k1=P3^7; uchar code table[]={ //显示数据编码 0x3f,0x06,0x5b,0x4f, 0x66,0x6d,0x7d,0x07, 0x7f,0x6f,0x77,0x7c, 0x39,0x5e,0x79,0x71}; uchar t0,t1,shi1,ge1,shi2,ge2; uint shu1,shu2; uchar ID1=1; uchar ID2=1; uchar flag=1; void init(); //函数声明 void display1(uchar shi1,uchar ge1); void display2(uchar shi2,uchar ge2); void delay(uint z) //延时子函数 { uint x,y; for(x=z;x>0;x--) for(y=110;y>0;y--); } void main() //主函数 { init(); while(1) { if(key1==0) //夜间模式,黄灯闪烁 { if(key1==0) while(1) { P1=0xfd&0xbf; delay2(500); P1=0xff; elay2(500); } while(!key1); delay2(5); while(!key1); } if(flag==1) display1( shi1, ge1); if(ID1==4) ID1=1; switch(ID1) { case 1:P1=0xfe;break; //红 case 2:P1=0xfb;break; //绿 case 3:P1=0xfd;break; //黄 default:break; } display2( shi2, ge2); if(ID2==4) ID2=1; switch(ID2) { case 1:P1=0x7f;break; //绿 case 2:P1=0xbf;break; //黄 case 3:P1=0xdf;break; //红 default:break; } } } void init() //初始化函数 { shu1=25; shu2=22; TMOD=0x00; TH0=(65536-50000)/256; //定时器初始化 TL0=(65536-50000)%256; TH1=(65536-50000)/256; TL1=(65536-50000)%256; EA=1; ET0=1; TR0=1; } void timer0() interrupt 1 //定时器0中断函数 { TH1=(65536-50000)/256; TL1=(65536-50000)%256; t1++; if(t1==100) { t1=0; shu1--; shu2--; shi1=shu1/10; shi2=shu2/10; ge1=shu1%10; ge2=shu2%10; if(shu1==0) //25 南北 { ID1++; if(ID1==5) ID1=2; switch(ID1) { case 1:shu1=3;break; case 2:shu1=22;break; case 3:shu1=3;break; case 4:shu1=25;break; default:break; } } if(shu2==0) //22 东西 { ID2++; if(ID2==5) ID2=2; switch(ID2) { case 1:shu2=25;break; case 2:shu2=3;break; case 3:shu2=25;break; case 4:shu2=22;break; default:break; } } } } void display1(uchar shi1,uchar ge1) //显示子函数 { dula=1; P0=table[shi1]; dula=0; P0=0xff; wela=1; P0=0xfe; wela=0; delay(5); dula=1; P0=table[ge1]; dula=0; P0=0xff; wela=1; P0=0xfd; wela=0; delay(5); } void display2(uchar shi2,uchar ge2) { dula=1; P0=table[ge2]; dula=0; P0=0xff; wela=1; P0=0xef; wela=0; delay(5); dula=1; P0=table[shi2]; dula=0; P0=0xdf; wela=1; P0=0xf7; wela=0; delay(5); } |
2个回答
循环3次{黄灯=1,延时,黄灯=0,延时}
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
265 浏览 0 评论
【原创】【RA4M2-SENSOR开发板评测】低功耗+USB综合测试
789 浏览 0 评论
1306 浏览 2 评论
787 浏览 0 评论
【RA4M2-SENSOR开发板评测】Analogue+Timers综合测试
1587 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
16901 浏览 31 评论
/9
GMT+8, 2025-12-2 04:35 , Processed in 0.560851 second(s), Total 77, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3702
