这是我自己按照郭天祥视频第九节的课后作业编的程序,放掉电的计时器。
#include
#define uchar unsigned char
#define uint unsigned int
uchar code table[]={0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71}; //共阴数码管表
uchar date,sec,save,time0;
***it sda=P2^0;
***it scl=P2^1;
***it dula=P2^6;
***it wela=P2^7;
void somenop()//小延时
void delay(uint z)//ms延时
uint x,y;
for(x=0;x<110;x++)
for(y=0;y
void display(uchar x)//数码管显示
dula=1;
P0=table[x/10];
dula=0;
P0=0xff;
wela=1;
P0=0xfe;
wela=0;
P0=0x00;
delay(1);
dula=1;
P0=table[x%10];
dula=0;
P0=0xff;
wela=1;
P0=0xfd;
wela=0;
P0=0x00;
delay(1);
void I2Cstart() //起始信号
sda=1;
somenop();
scl=1;
somenop();
sda=0;
somenop();
void I2Cstop() //终止信号
sda=0;
somenop();
scl=1;
somenop();
sda=1;
somenop();
void I2Cresponse() //应答信号
uchar i;
scl=1;
somenop();
while((sda==1)&&(i<250))i++;
scl=0;
somenop();
void write_byte(uchar date) //写数据
uchar i,j;
j=date;
scl=0;
somenop();
for(i=0;i<8;i++)
j=j<<1;
sda=CY;
somenop();
scl=1;
somenop();
scl=0;
somenop();
sda=1;
somenop();
uchar read_byte() //读数据
uchar i,j,k;
scl=0;
somenop();
sda=1;
somenop();
for(i=0;i<8;i++)
scl=1;
somenop();
j=sda;
k=(k<<1)|j;
scl=0;
somenop();
return k;
void write_add(uchar x,uchar y) //地址,写入
I2Cstart(); //开始
write_byte(0xa0); //器件地址 写入
I2Cresponse();
write_byte(x); //写入地址
I2Cresponse();
write_byte(y);
I2Cresponse(); //写入数据
I2Cstop(); //结束
void read_add(uchar x)//地址 读出
I2Cstart(); //开始
I2Cresponse();
I2Cresponse();
I2Cstart(); //开始
write_byte(0xa1); //器件地址 读出
I2Cresponse();
date=read_byte();
I2Cstop();
void init() //初始化
time0=0;
sec=0;
read_add(0x06);
sec=date;
sda=1;
scl=1;
EA=1;
ET0=1;
TMOD=0x01;
TH0=0x4c;
TL0=0x00;
TR0=1;
void main()
init();
while(1)
display(sec);
if(save==1)
save=0;
write_add(0x06,sec);
void timer0() interrupt 1 //定时器
TH0=0x4c;
TL0=0x00;
time0++;
if(time0==20)
time0=0;
sec++;
save=1;
if(sec==100)
sec=0;
用proteus模拟后用秒表同步测量了下,发现每5分左右会有1秒的误差。。求解答
