DISPBUF EQU 5AH SecCoun EQU 59H SpCoun EQU 57H ? Count EQU 56H SpCalc bit 00h Hidden EQU 16 ORG 0000H AJMP START ORG 1BH JMP tiMER1 ORG 30H START: MOV SP,#5FH MOV P1,#0FFH MOV P0,#0FFH MOV P2,#0FFH MOV TMOD,#00010101B MOV TH1,#HIGH(65536-5000) MOV TL1,#LOW(65536-5000) SETB TR1 SETB ET1 SETB EA LOOP:JNB SpCalc ,LOOP MOV R2,SpCoun MOV R3,SpCoun+1 MOV R6,#0 MOV R7,#60 call MULD MULD: MOV A,R3 MOV B,R7 MUL AB MOV R4,B MOV R5,A MOV A,R3 MOV B,R6 MUL AB ADD A,R4 MOV R4,A CLR A ADDC A,B MOV R3,A MOV A,R2 MOV B,R7 MUL AB ADD A,R4 MOV R4,A MOV A,R3 ADDC A,B MOV R3,A CLR A RLC A XCH A,R2 MOV B,R6 MUL AB ADD A,R3 MOV R3,A MOV A,R2 ADDC A,B MOV R2,A RET MOV A,R4 MOV R6,A MOV A,R5 MOV R7,A CALL HB2 HB2: CLR A MOV R3,A MOV R4,A MOV R5,A MOV R2,#10H HB3: MOV A,R7 RLC A MOV R7,A MOV A,R6 RLC A MOV R6,A MOV A,R5 ADDC A,R5 DA A MOV R5,A MOV A,R4 ADDC A,R4 DA A MOV R4,A MOV A,R3 ADDC A,R3 MOV R3,A DJNZ R2,HB2 RET CBCD: MOV DISPBUF,R3 MOV A,R4 ; ANL A,#0F0H SWAP A MOV DISPBUF+1,A MOV A,R4 ANL A,#0FH MOV DISPBUF+2,A MOV A,R5 ANL A,#0F0H SWAP A MOV DISPBUF+3,A MOV A,R5 ANL A,#0FH MOV DISPBUF+4,A CLR SpCalc JMP LOOP TIMER1: PUSH ACC PUSH PSW SETB RS0 JNB TR0,SETTR0 JMP GO1 SETTR0: SETB TR0 GO1: INC SecCoun MOV A,SecCoun CJNE A,#251,Go2 CLR TR0 MOV SpCoun,TH0 MOV SpCoun+1,TL0 CLR A MOV TH0,A MOV TL0,A SETB SpCalc MOV SecCoun,#0 Go2: INC COUNT MOV A,COUNT CLR C SUBB A,#6 JZ N1 JMP N2 N1: MOV COUNT,#0 N2: MOV A,#DISPBUF ADD A,COUNT MOV R0,A MOV A,@R0 MOV DPTR,#DISPTAB MOVC A,@A+DPTR MOV P0,A MOV A,COUNT MOV DPTR,#BitTab MOVC A,@A+DPTR ORL P2,#11110000B ANL P2,A MOV TH1,#HIGH(65536-5000) MOV TL1,#LOW(65536-5000) POP PSW POP ACC SETB RS0 RETI BitTab: DB 07Fh,0BFH,0DFH,0EFH,0F7H,0FBH DISPTAB:DB 0C0H,0F9H,0A4H,0B0H,99H,92H,82H,0F8H,80H,90H END
8个回答
第一次上论坛。发帖。谢谢你的提醒 |
看得有点花
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
506 浏览 0 评论
607 浏览 0 评论
837 浏览 0 评论
832 浏览 0 评论
RT-Thread与英飞凌(infineon)合作得板子PSOC 6 板子学习
768 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
17058 浏览 31 评论
/9
GMT+8, 2025-12-14 07:23 , Processed in 0.949792 second(s), Total 87, Slave 67 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2516
