扫一扫,分享给好友
#include
#include unsigned int scount; ***it KEY=P3^0; ***it RS = P2^4; //定义端口 ***it RW = P2^5; ***it EN = P2^6; #define RS_CLR RS=0 #define RS_SET RS=1 #define RW_CLR RW=0 #define RW_SET RW=1 #define EN_CLR EN=0 #define EN_SET EN=1 #define DataPort P0 void DelayUs2x(unsigned char t) { while(--t); }//微秒延时 void DelayMs(unsigned char t) { while(t--) { //大致延时1mS DelayUs2x(245); DelayUs2x(245); } }//毫秒延迟 /*------------------------------------------------ 判忙函数 ------------------------------------------------*/ bit LCD_Check_Busy(void) { DataPort= 0xFF; RS_CLR; RW_SET; EN_CLR; _nop_(); EN_SET; return (bit)(DataPort & 0x80); } /*------------------------------------------------ 写入命令函数 ------------------------------------------------*/ void LCD_Write_Com(unsigned char com) { while(LCD_Check_Busy()); //忙则等待 RS_CLR; RW_CLR; EN_SET; DataPort= com; _nop_(); EN_CLR; } /*------------------------------------------------ 写入数据函数 ------------------------------------------------*/ void LCD_Write_Data(unsigned char Data) { while(LCD_Check_Busy()); //忙则等待 RS_SET; RW_CLR; EN_SET; DataPort= Data; _nop_(); EN_CLR; } /*------------------------------------------------ 清屏函数 ------------------------------------------------*/ void LCD_Clear(void) { LCD_Write_Com(0x01); DelayMs(5); } /*------------------------------------------------ 写入字符串函数 ------------------------------------------------*/ void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s) { if (y == 0) { LCD_Write_Com(0x80 + x); //表示第一行 } else { LCD_Write_Com(0xC0 + x); //表示第二行 } while (*s) { LCD_Write_Data( *s); s ++; } } /*------------------------------------------------ 写入字符函数 ------------------------------------------------*/ void LCD_Write_Char(unsigned char x,unsigned char y,unsigned char Data) { if (y == 0) { LCD_Write_Com(0x80 + x); } else { LCD_Write_Com(0xC0 + x); } LCD_Write_Data( Data); } /*------------------------------------------------ 初始化函数 ------------------------------------------------*/ void LCD_Init(void) { LCD_Write_Com(0x38); /*显示模式设置*/ DelayMs(5); LCD_Write_Com(0x38); DelayMs(5); LCD_Write_Com(0x38); DelayMs(5); LCD_Write_Com(0x38); LCD_Write_Com(0x08); /*显示关闭*/ LCD_Write_Com(0x01); /*显示清屏*/ LCD_Write_Com(0x06); /*显示光标移动设置*/ DelayMs(5); LCD_Write_Com(0x0C); /*显示开及光标设置*/ } void timer0_int(void) interrupt 1 using 1 { TR0=0; TH0=(65536-50000)/256; TL0=(65536-50000)%256; TF0=0; scount--; if(scount>0) TR0=1; else TR1=0; } main() { unsigned char a[3]; unsigned char shang,yu; unsigned long int xinlv; TMOD=0xD1;//定时器1计数方式1,定时器0定时方式1 TH0=(65536-50000)/256; TL0=(65536-50000)%256; TH1=0; TL1=0; scount=600; ET0=1;//开定时器0中断 EA=1;//开总中断 while(1) { if(!KEY) //如果检测到低电平,说明按键按下 { DelayMs(10); //延时去抖 if(!KEY) { while(!KEY); { TR0=1; TR1=1; } } } if(!scount) { shang=TH1; yu=TL1; TH1=0; TL1=0; TH0=(65536-50000)/256; TL0=(65536-50000)%256; scount=600; xinlv=shang*256+yu; a[0]=xinlv/100; a[1]=(xinlv/10)%10; a[2]=xinlv%10; LCD_Init(); LCD_Clear();//清屏 } LCD_Write_Char(6,0,a[0]+'0'); LCD_Write_Char(7,0,a[1]+'0'); LCD_Write_Char(8,0,a[2]+'0'); } } 我的红外心率计最后下载程序到单片机 按键接计数器1能测按键的次数 但是把心率计的输出接计数器1 30秒后显示计数为0 心率计输出波形我用示波器看过了 是可以的 高电平是3V多的一个矩形波 求助 |
3个回答
麻烦 问一下,心率是 怎么检测的呢.......很想只要, 可以做一个类似心电图的东西出来么..........
没看到你在哪儿计的数呢
电路图可以贴出来看看吗?
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
506 浏览 0 评论
607 浏览 0 评论
837 浏览 0 评论
832 浏览 0 评论
RT-Thread与英飞凌(infineon)合作得板子PSOC 6 板子学习
768 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
17058 浏览 31 评论
浏览过的版块 |
/9
GMT+8, 2025-12-14 07:45 , Processed in 0.626460 second(s), Total 75, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2201
