这是利用DAC0832 和DAC0832 做的正弦波发生器,P2口是用于DAC0832的数据端,DAC0832用的是直通方式。利用改变2个取点之间的时间从而改变它的波形频率!
然后用proteus 仿真,但为什么当我按S7或S8时,波形都没有改变的呢,求指导!是我的方法错了,还是我的代码有问题!!求各位指导
下面是代码:
#include
#include
#define uchar unsigned char
#define uint unsigned int
***it s7=P1^6; //按键7
***it s8=P1^7; //按键8
uint p;
uint n;
uint ft,ff;
uchar code sintab[256]=
0x80,0x83,0x86,0x89,0x8d,0x90,0x93,0x96,
0x99,0x9c,0x9f,0xa2,0xa5,0xa8,0xab,0xae,
0xb1,0xb4,0xb7,0xba,0xbc,0xbf,0xc2,0xc5,
0xc7,0xca,0xcc,0xcf,0xd1,0xd4,0xd6,0xd8,
0xda,0xdd,0xdf,0xe1,0xe3,0xe5,0xe7,0xe9,
0xea,0xec,0xee,0xef,0xf1,0xf2,0xf4,0xf5,
0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfd,
0xfd,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,
0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfd,
0xfd,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,0xf6,
0xf5,0xf4,0xf2,0xf1,0xef,0xee,0xec,0xea,
0xe9,0xe7,0xe5,0xe3,0xe1,0xde,0xdd,0xda,
0xd8,0xd6,0xd4,0xd1,0xcf,0xcc,0xca,0xc7,
0xc5,0xc2,0xbf,0xbc,0xba,0xb7,0xb4,0xb1,
0xae,0xab,0xa8,0xa5,0xa2,0x9f,0x9c,0x99,
0x96,0x93,0x90,0x8d,0x89,0x86,0x83,0x80,
0x80,0x7c,0x79,0x76,0x72,0x6f,0x6c,0x69,
0x66,0x63,0x60,0x5d,0x5a,0x57,0x55,0x51,
0x4e,0x4c,0x48,0x45,0x43,0x40,0x3d,0x3a,
0x38,0x35,0x33,0x30,0x2e,0x2b,0x29,0x27,
0x25,0x22,0x20,0x1e,0x1c,0x1a,0x18,0x16,
0x15,0x13,0x11,0x10,0x0e,0x0d,0x0b,0x0a,
0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,
0x02,0x01,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02,
0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,
0x0a,0x0b,0x0d,0x0e,0x10,0x11,0x13,0x15,
0x16,0x18,0x1a,0x1c,0x1e,0x20,0x22,0x25,
0x27,0x29,0x2b,0x2e,0x30,0x33,0x35,0x38,
0x3a,0x3d,0x40,0x43,0x45,0x48,0x4c,0x4e,
0x51,0x55,0x57,0x5a,0x5d,0x60,0x63,0x66,
0x69,0x6c,0x6f,0x72,0x76,0x79,0x7c,0x80
void delay (uchar k);
void boxingkey(); //按键
void zhengxian(); //正弦波
void main()
n=0;
p=1;
P1=0xff;
ff=20;
ft=1000000/256/ff; //2点之间的时间
zhengxian();
while(1)
boxingkey();
void boxingkey()
if(s7==0)
delay(10);
if(s7==0)
TR0=0;
ff=ff+10; //频率+
ft=1000000/256/ff;
TH0=(65536-ft)/256;
TL0=(65536-ft)%256;
TR0=1;
while(!s7);
delay(10);
while(!s7);
else if(s8==0)
delay(10);
if(s8==0)
TR0=0;
ff=ff-10; //频率-
ft=1000000/256/ff;
TH0=(65536-ft)/256;
TL0=(65536-ft)%256;
TR0=1;
while(!s8);
delay(10);
while(!s8);
void zhengxian() //正弦波
TMOD=0x01;
TH0=(65536-ft)/256;
TL0=(65536-ft)%256;
EA=1;
ET0=1;
TR0=1;
void delay (uchar k) //延时
uchar j;
while((k--)!=0)
for(j=0;j<125;j++);
void external() interrupt 1 //中断
TH0=(65536-ft)/256;
TL0=(65536-ft)%256;
n++;
P2=sintab[n];
if(n>=256)n=0;
