扫一扫,分享给好友
請問為什麼我在matlab的 command window 開啟port沒反應??
但是在GUI下開啟又正常.....請問各位神人問題在哪邊?? 感謝各位神人。 function result = PLCFNC(num,action) try s=serial('COM3','BaudRate',9600,'Parity','even','DataBits',7,'StopBits',1); seris=s; set(s,'OutputBufferSize',512); set(s,'InputBufferSize',1024); fopen(s); catch errmsg = lasterr; errordlg(['不能打開port: COM3',char(10),'請檢查串口連接或該串口已打開'],'串口打開錯誤'); rethrow(lasterror); end switch num case 0 if (action == 1) tmp = '023730303035034646'; else tmp = '023830303035033030'; end case 1 if (action == 1) tmp = '023730313035033030'; else tmp = '023830313035033031'; end case 2 if (action == 1) tmp = '023730323035033031'; else tmp = '023830323035033032'; end case 3 if (action == 1) tmp = '023730333035033032'; else tmp = '023830333035033033'; end case 4 if (action == 1) tmp = '023730343035033033'; else tmp = '023830343035033034'; end case 5 if (action == 1) tmp = '023730353035033034'; else tmp = '023830353035033035'; end case 6 if (action == 1) tmp = '023730363035033035'; else tmp = '023830363035033036'; end case 7 if (action == 1) tmp = '023730373035033036'; else tmp = '023830373035033037'; end case 10 if (action == 1) tmp = '023730383035033037'; else tmp = '023830383035033038'; end case 11 if (action == 1) tmp = '023730323935033038'; else tmp = '023830393035033039'; end case 12 if (action == 1) tmp = '023730413035033130'; else tmp = '023830413035033131'; end case 13 if (action == 1) tmp = '023730423035033131'; else tmp = '023830423035033132'; end case 14 if (action == 1) tmp = '023730433035033132'; else tmp = '023830433035033133'; end case 15 if (action == 1) tmp = '023730443035033133'; else tmp = '023830443035033134'; end case 16 if (action == 1) tmp = '023730453035033134'; else tmp = '023830453035033135'; end case 17 if (action == 1) tmp = '023730463035033135'; else tmp = '023830463035033136'; end %寫入命令 data = sscanf(tmp,'%02x')'; fwrite(s,data,'uint8'); fclose(s); delete(s); result = 1; end |
1个回答
刚开始学习……加油!
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
我用matlab的coder 封装了一个c语言的dll, 但是在用labview调用时,会出现识别不到库的问题,有大神遇到过吗
2630 浏览 0 评论
5216 浏览 0 评论
在matlab中如何计算含有第一类修正的贝塞尔函数的积分算不出的问题?
9012 浏览 0 评论
怎么利用matlab得到95%,80%和70%的置信区间,并生成不同区间下的功率误差贝塔分布?
10454 浏览 0 评论
请问simulink的s-function模块如何添加多输入输出接口
14615 浏览 2 评论
/9
GMT+8, 2025-12-1 22:02 , Processed in 0.545224 second(s), Total 73, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1940
