代码: #include #define uchar unsigned char #define uint unsigned int #define OPPREAD 0xa1 #define OPPWRITE 0xa0 ***it SCL = P3^4; ***it SDA = P3^5; ***it K5 = P1^4;//小时加1; ***it K6 = P1^5;//分钟加1; ***it K7 = P1^6;//秒加1; ***it K8 = P1^7;//复位; uchar code k[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};//数码管显示数字; uchar fen = 0; uchar miao = 0; uchar shi = 0; uint num = 0; void delay(uchar i) { uchar j; while(i--) { for(j = 0; j < 115; j ++) { ; } } } void start() {//起始; SDA = 1; SCL = 1; delay(5); SDA = 0; delay(5); SCL = 0; } void stop() {//终止; SDA = 0; SCL = 1; delay(5); SDA = 1; delay(5); SCL = 0; SDA = 0; } bit ask(){//应答; bit ack_bit; SDA = 1; delay(5); SCL = 1; delay(5); ack_bit = SDA; SCL = 0; return ack_bit; } uchar readdata() {//读; uchar i, x; for(i = 0; i < 8; i ++) { SCL = 1; x <<= 1; x |=(uchar) SDA; SCL = 0; } return x; } void writecurrent(uchar y) {//当前地址写; uchar i; for(i = 0; i < 8; i ++) { SDA =(bit) (y&0x80); delay(1); SCL = 1; delay(2); SCL = 0; y <<= 1; } } void writeset(uchar addr, uchar dat) {//指定地址写; start(); writecurrent(OPPWRITE); ask(); writecurrent(addr); ask(); writecurrent(dat); ask(); stop(); delay(5); } uchar readcurrent() {//当前地址读; uchar x; start(); writecurrent(OPPREAD); ask(); x = readdata(); stop(); return x; } uchar readset(uchar set) {//指定地址读; start(); writecurrent(OPPWRITE); ask(); writecurrent(set); ask(); return readcurrent(); } void displayshi(int h) {//数码管显示小时; P2 = 0xfe; P0 = k[h / 10]; delay(1); P2 = 0xfd; P0 = k[h % 10]; delay(1); P2 = 0xff; } void displayfen(int f) {//数码管显示分钟; P2 = 0xf7; P0 = k[f / 10]; delay(1); P2 = 0xef; P0 = k[f % 10]; delay(1); P2 = 0xff; } void displaymiao(int m) {//数码管显示秒; P2 = 0xbf; P0 = k[m / 10]; delay(1); P2 = 0x7f; P0 = k[m % 10]; delay(1); P2 = 0xff; } void keyscan() {//键盘扫描; if(K5 | K6 | K7 | K8 == 1){ TR0 = 0; if(K5 == 0){ delay(15); if(K5 == 0){ shi ++; writeset(2, shi); while(!K5); } } if(K8 == 0){ delay(15); if(K8 == 0){ shi = 0; fen = 0; miao = 0; writeset(2, shi); writeset(3, fen); writeset(4, miao); while(!K8); } } if(K6 == 0){ delay(15); if(K6 == 0){ fen ++; writeset(3, fen); while(!K6); } } if(K7 == 0){ delay(15); if(K7 == 0){ miao ++; writeset(4, miao); while(!K7); } } } } void init() { TMOD = 0x01; EA = 1; ET0 = 1; TR0 = 1; TH0 = (65536 - 45872) / 256; TL0 = (65536 - 45872) % 256; } void main() { init(); SDA = 1; SCL = 1; shi = readset(2); fen = readset(3); miao = readset(4); while(1) { keyscan(); TR0 = 1; displaymiao(miao); displayfen(fen); displayshi(shi); } } void t000() interrupt 1 { TH0 = (65536 - 45872) / 256; TL0 = (65536 - 45872) % 256; num ++; if(num == 20) { miao ++; writeset(4, miao); num = 0; if(miao == 60) { fen ++; writeset(3, fen); miao = 0; if(fen == 60) { shi ++; writeset(2, shi); fen = 0; if(shi == 24) { shi = 0; } } } } } |
3个回答
回帖奖励 +1 分积分
delay时间太长了。
没看程序,一般是动态显示切换位选的延时太长了。
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
【瑞萨RA6E2】瑞萨E2S软件安装过程,等待过程玩下97_e2 studio_ZGZZ
331 浏览 0 评论
532 浏览 0 评论
【原创】【RA4M2-SENSOR开发板评测】低功耗+USB综合测试
842 浏览 0 评论
1383 浏览 2 评论
824 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
16911 浏览 31 评论
/9
GMT+8, 2025-12-3 11:07 , Processed in 0.705677 second(s), Total 80, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2245
