1.取消makefile中的注释 2.在k230_sdk目录下进入docker环境后使用make mpp-apps编译 期待结果和实际结果 期待得到opencv_camera_test.elf文件 实际却报错 软硬件版本信息 创乐博k230V3.0,sdk版本1.9 错误日志 make[1]: Entering directory '/home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src' make[2]: Entering directory '/home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/sensor' riscv64-unknown-linux-musl-ar -rc /home/k230/Desktop/k230_sdk/src/big/mpp/userapps/lib/libsensor.a /home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/sensor/mpi_sensor_type_to_mirror.o /home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/sensor/mpi_sensor.o cmake -S /home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/sensor/dewarp/k230dwmapgen -B build -- The C compiler identification is GNU 9.4.0 -- The CXX compiler identification is GNU 9.4.0 -- Detecting C compiler ABI info -- Detecting C compiler ABI info - done -- Check for working C compiler: /usr/bin/cc - skipped -- Detecting C compile features -- Detecting C compile features - done -- Detecting CXX compiler ABI info -- Detecting CXX compiler ABI info - done -- Check for working CXX compiler: /usr/bin/c++ - skipped -- Detecting CXX compile features -- Detecting CXX compile features - done -- Found PkgConfig: /usr/bin/pkg-config (found version "0.29.1") -- Checking for module 'yaml-0.1' -- Found yaml-0.1, version 0.2.2 -- Configuring done (0.3s) -- Generating done (0.0s) -- Build files have been written to: /home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/sensor/build cmake --build build -j make[3]: Entering directory '/home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/sensor/build' make[4]: Entering directory '/home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/sensor/build' make[5]: Entering directory '/home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/sensor/build' make[5]: Leaving directory '/home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/sensor/build' make[5]: Entering directory '/home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/sensor/build' [ 14%] Building CXX object CMakeFiles/k230dwmapgen.dir/src/DewarpMap.cpp.o [ 28%] Building CXX object CMakeFiles/k230dwmapgen.dir/src/basic.cpp.o [ 42%] Linking CXX static library libk230dwmapgen.a make[5]: Leaving directory '/home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/sensor/build' [ 42%] Built target k230dwmapgen make[5]: Entering directory '/home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/sensor/build' make[5]: Entering directory '/home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/sensor/build' make[5]: Leaving directory '/home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/sensor/build' make[5]: Entering directory '/home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/sensor/build' make[5]: Leaving directory '/home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/sensor/build' make[5]: Entering directory '/home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/sensor/build' [ 57%] Building C object CMakeFiles/k230dwmapgen-splitscreen.dir/exe/split_screen.c.o [ 71%] Building C object CMakeFiles/k230dwmapgen-dump.dir/exe/main.c.o [ 85%] Linking CXX executable k230dwmapgen-splitscreen [100%] Linking CXX executable k230dwmapgen-dump make[5]: Leaving directory '/home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/sensor/build' [100%] Built target k230dwmapgen-splitscreen make[5]: Leaving directory '/home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/sensor/build' [100%] Built target k230dwmapgen-dump make[4]: Leaving directory '/home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/sensor/build' make[3]: Leaving directory '/home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/sensor/build' ./build/k230dwmapgen-dump < /home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/sensor/dewarp/imx335-1920x1080.yml > /home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/sensor/dewarp/imx335-1920x1080.bin image_width: 1920 image_height: 1080 camera_matrix: 1963.266005 0.000000 1033.985274 0.000000 1963.266005 782.579320 0.000000 0.000000 1.000000 distortion_coefficients: -0.385155 0.226728 -0.000228 0.000002 -0.211029 ./build/k230dwmapgen-dump < /home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/sensor/dewarp/imx335-2592x1944.yml > /home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/sensor/dewarp/imx335-2592x1944.bin image_width: 2592 image_height: 1944 camera_matrix: 1968.558599 0.000000 1373.294827 0.000000 1968.558599 1000.350609 0.000000 0.000000 1.000000 distortion_coefficients: -0.377384 0.203702 -0.000569 0.000305 -0.127580 rm -rf build mkdir -p /home/k230/Desktop/k230_sdk/src/big/rt-smart/userapps/root/bin/ cp /home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/sensor/config/* /home/k230/Desktop/k230_sdk/src/big/rt-smart/userapps/root/bin/ cp /home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/sensor/dewarp/*.bin /home/k230/Desktop/k230_sdk/src/big/rt-smart/userapps/root/bin/ echo "/home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/sensor/Makefile all" /home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/sensor/Makefile all make[2]: Leaving directory '/home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/sensor' make[2]: Entering directory '/home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/connector' riscv64-unknown-linux-musl-ar -rc /home/k230/Desktop/k230_sdk/src/big/mpp/userapps/lib/libconnector.a /home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/connector/mpi_connector.o echo "/home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/connector/Makefile all" /home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/connector/Makefile all make[2]: Leaving directory '/home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/connector' make[2]: Entering directory '/home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/fft' riscv64-unknown-linux-musl-ar -rc /home/k230/Desktop/k230_sdk/src/big/mpp/userapps/lib/libfft.a /home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/fft/mpi_fft.o echo "/home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/fft/Makefile all" /home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/fft/Makefile all make[2]: Leaving directory '/home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/fft' make[2]: Entering directory '/home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/cipher' riscv64-unknown-linux-musl-ar -rc /home/k230/Desktop/k230_sdk/src/big/mpp/userapps/lib/libcipher.a /home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/cipher/mpi_cipher.o echo "/home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/cipher/Makefile all" /home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/cipher/Makefile all make[2]: Leaving directory '/home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/cipher' make[2]: Entering directory '/home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/pm' riscv64-unknown-linux-musl-ar -rc /home/k230/Desktop/k230_sdk/src/big/mpp/userapps/lib/libpm.a /home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/pm/mpi_pm.o echo "/home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/pm/Makefile all" /home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/pm/Makefile all make[2]: Leaving directory '/home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src/pm' make[1]: Leaving directory '/home/k230/Desktop/k230_sdk/src/big/mpp/userapps/src' make[1]: Entering directory '/home/k230/Desktop/k230_sdk/src/big/mpp/userapps/sample' make[2]: Entering directory '/home/k230/Desktop/k230_sdk/src/big/mpp/userapps/sample/opencv_camera_test' CXX /home/k230/Desktop/k230_sdk/src/big/mpp/userapps/sample/opencv_camera_test/opencv_videocapture_basic.o /home/k230/Desktop/k230_sdk/src/big/mpp/userapps/sample/opencv_camera_test/opencv_videocapture_basic.cpp:9:10: fatal error: opencv2/opencv.hpp: No such file or directory 9 | #include | ^~~~~~~~~~~~~~~~~~~~ compilation terminated. make[2]: *** [Makefile:51: /home/k230/Desktop/k230_sdk/src/big/mpp/userapps/sample/opencv_camera_test/opencv_videocapture_basic.o] Error 1 make[2]: Leaving directory '/home/k230/Desktop/k230_sdk/src/big/mpp/userapps/sample/opencv_camera_test' make[1]: *** [Makefile:10: all] Error 1 make[1]: Leaving directory '/home/k230/Desktop/k230_sdk/src/big/mpp/userapps/sample' /bin/bash: line 6: exit: check_src: numeric argument required make: *** [Makefile:229: mpp-apps] Error 2 |
只有小组成员才能发言,加入小组>>
AI_cube训练模型得到了npy文件,没有kmodel文件
770 浏览 0 评论
请问K230 V3.0版本烧录固件和使用IDE到底是烧录哪个啊?
735 浏览 0 评论
443浏览 4评论
AI Cube进行yolov8n模型训练,创建项目目标检测时显示数据集目录下存在除标注和图片外的其他目录如何处理?
462浏览 3评论
autodl算力云在.pt转换onnx文件时正常,但onnx转.kmodel文件时报错,为什么?
552浏览 2评论
如何在大核rtt上把kd_mpi_vicap_start_stream三个摄像头各自出的流拼成一个流呢?
164浏览 2评论
564浏览 2评论
/9
GMT+8, 2025-12-2 01:31 , Processed in 0.770569 second(s), Total 73, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
515
