电子发烧友论坛|
在部署模型到canmvk230d-zero时,烧录镜像CanMV-K230D_Zero_micropython_v1.2.2-0-g4b8cae1_nncase_v2.9.0.img,无法识别到板子
期待结果和实际结果 软硬件版本信息 错误日志 尝试解决过程 补充材料 你好,你这是自己做得板子吗?看起来是卡没有正常识别 建议换个tf卡试下,看串口打印 tf卡超时了。 00000000: PMU Major Msg: End of CA training 00000000: PMU Major Msg: End of initialization 00000000: PMU Major Msg: End of read enable training 00000000: PMU Major Msg: End of fine write leveling 00000000: PMU Major Msg: End of read dq deskew training 00000000: PMU Major Msg: End of MPR read delay center optimization 00000000: PMU Major Msg: End of Write leveling coarse delay 00000000: PMU Major Msg: End of write delay center optimization 00000000: PMU Major Msg: End of read delay center optimization 00000000: PMU Major Msg: End of max read latency training 00000000: PMU Major Msg: Firmware run has completed 2667 sdhci_transfer_data: Transfer data timeout image: uboot load to 1000000 compress =1 src 55557aa len=49dd8 U-Boot 2022.10 (Dec 18 2024 - 02:55:58 +0000) CPU: rv64imafdcvsu Model: kendryte k230d canmv bpi zero DRAM: 128 MiB Core: 28 devices, 13 uclasses, devicetree: separate MMC: mmc0@91580000: 0, mmc1@91581000: 1 Loading Environment from MMC... sdhci_transfer_data: Transfer data timeout OK In: serial@91400000 Out: serial@91400000 Err: serial@91400000 Net: No ethernet found. Hit any key to stop autoboot: 0 K230# U-Boot SPL 2022.10 (Dec 18 2024 - 02:55:58 +0000) 00000000: PMU Major Msg: End of CA training 00000000: PMU Major Msg: End of initialization 00000000: PMU Major Msg: End of read enable training 00000000: PMU Major Msg: End of fine write leveling 00000000: PMU Major Msg: End of read dq deskew training 00000000: PMU Major Msg: End of MPR read delay center optimization 00000000: PMU Major Msg: End of Write leveling coarse delay 00000000: PMU Major Msg: End of write delay center optimization 00000000: PMU Major Msg: End of read delay center optimization 00000000: PMU Major Msg: End of max read latency training 00000000: PMU Major Msg: Firmware run has completed 2667 sdhci_transfer_data: Transfer data timeout image: uboot load to 1000000 compress =1 src 55557aa len=49dd8 U-Boot 2022.10 (Dec 18 2024 - 02:55:58 +0000) CPU: rv64imafdcvsu Model: kendryte k230d canmv bpi zero DRAM: 128 MiB Core: 28 devices, 13 uclasses, devicetree: separate MMC: mmc0@91580000: 0, mmc1@91581000: 1 Loading Environment from MMC... sdhci_transfer_data: Transfer data timeout OK In: serial@91400000 Out: serial@91400000 Err: serial@91400000 Net: No ethernet found. Hit any key to stop autoboot: 0 image: rtt load to 0 compress =1 src 55557b2 len=185203 Jump to big hart OpenSBI v1.2.2 heap: [0x004b75c0 - 0x00eb75c0], size 10240 KB page: [0x00eb75c8 - 0x02ffec00], size 34077 KB lwIP-2.1.2 initialized! Can't find sensor on csi0 [I/SDIO] SD card capacity 62367744 KB. Can't find sensor on csi2 vicap_mcm_init[E/drv_touch] touch probe failed. [I/sal.skt] Socket Abstraction Layer initialize success. #############SDK VERSION###################################### SDK : v1.2.2-20241218-025648-runner-fv-az1757-183-0820549 CanMV : v1.2.2-20241218-025648-runner-fv-az1757-183-4b8cae1 nncase: 2.9.0 ############################################################## msh />sdhci_transfer_data_blocking: Transfer data timeout [E/SDIO] mmcsd request blocks error [E/SDIO] -1,0,0, 0x00000002,0x00000000 [I/GPT] status:255 sdhci_transfer_data_blocking: Transfer data timeout [E/SDIO] mmcsd request blocks error [E/SDIO] -1,0,0, 0x00000002,0x00000000 [E/SDIO] read mmcsd first sector failed [I/WLAN.dev] wlan init success [I/WLAN.lwip] eth device init ok name:w0 [I/WLAN.dev] wlan init success [I/WLAN.lwip] eth device init ok name:w1 |
1个回答
问题分析与解决思路:IDE无法识别canmvk230d-zero板子从日志 一、直接解决方法:更换TF卡(90%问题根源)
二、硬件与连接排查(5%概率)
三、镜像与软件层处理(5%概率)
四、备用方案:SPI Flash启动(极特殊情况)若多次更换TF卡仍失败:
关键结论优先更换高质量TF卡并严格按步骤格式化(解决90%问题),其次排查硬件接触与供电。烧录后观察串口输出,正常系统启动需在10秒内打印
只有小组成员才能发言,加入小组>>
AI_cube训练模型得到了npy文件,没有kmodel文件
775 浏览 0 评论
请问K230 V3.0版本烧录固件和使用IDE到底是烧录哪个啊?
741 浏览 0 评论
444浏览 4评论
AI Cube进行yolov8n模型训练,创建项目目标检测时显示数据集目录下存在除标注和图片外的其他目录如何处理?
465浏览 3评论
autodl算力云在.pt转换onnx文件时正常,但onnx转.kmodel文件时报错,为什么?
554浏览 2评论
如何在大核rtt上把kd_mpi_vicap_start_stream三个摄像头各自出的流拼成一个流呢?
172浏览 2评论
573浏览 2评论
/9
GMT+8, 2025-12-4 10:19 , Processed in 0.535202 second(s), Total 46, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
324
