电子发烧友论坛|
我们在使用TAS5719的时候,发现不同的批次表现不一样,这一个批次的都正常,下一个批次的有过载的问题.
原理图如下PDF文件: TPS5719.pdf 软件设置如下: /* 5719初始化数据 */ {0x1B, 1, {0x00}}, /*Oscillator trim register振荡器调整寄存器*/ {0x1B, 1, {0x00}}, {0x03, 1, {0x80}}, /*System control register 1*/ {0x11, 1, {0x77}}, /*IC delay channel 1*/ {0x12, 1, {0x7F}}, /*IC delay channel 2*/ {0x13, 1, {0x77}}, /*IC delay channel 3*/ {0x14, 1, {0x7F}}, /*IC delay channel 4*/ {0x1C, 1, {0x07}}, /*BKND_ERR register*/ {0x0A, 1, {0x30}}, /*Channel 3 vol*/ {0x0E, 1, {0xF1}}, /*Volume configuration register音量寄存器*/ {0x00, 1, {0x6C}}, /*Clock control register*/ {0x50, 4, {0x0F, 0x70, 0x80, 0x10}}, /*EQ control*/ {0x25, 4, {0x01, 0x02, 0x13, 0x45}}, /*PWM MUX register*/ {0x70, 4, {0x00, 0x80, 0x00, 0x00}}, /*ch1 inline mixer*/ {0x71, 4, {0x00, 0x00, 0x00, 0x00}}, /*inline_DRC_en_mixer_ch1*/ {0x74, 4, {0x00, 0x80, 0x00, 0x00}}, /*ch2 inline mixer*/ {0x75, 4, {0x00, 0x00, 0x00, 0x00}}, /*inline_DRC_en_mixer_ch2*/ //{0x46, 4, {0x00, 0x02, 0x06, 0x23}}, /*DRC control*/ {0x46, 4, {0x00, 0x02, 0x06, 0x20}}, /*DRC control*/ //DRC off {0x05, 1, {0x00}}, /*System control register 2*/ {0x08, 2, {0x00, 0xC0}}, {0x09, 2, {0x00, 0xC0}}, {0x56, 4, {0x00, 0x40, 0x00, 0x00}}, /*Output post-scale*/ {0x57, 4, {0x00, 0x02, 0x00, 0x00}}, /*Output pre-scale*/ {0x07, 2, {0x00, 0x72}}, {0x07, 2, {0x03, 0xFF}}, /*Master volume,关音了*/ //{0x0B, 2, {0x01, 0x80}},/* 耳机音量 -3Db*/ //EQ {0x27, 20, {0x00, 0x7F, 0xAA, 0x6F, 0x0F, 0x80, 0x55, 0x91, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7F, 0x54, 0xDF, 0x00, 0x00, 0x00, 0x00}}, {0x28, 20, {0x00, 0x80, 0x7C, 0x93, 0x0F, 0x01, 0x43, 0x46, 0x00, 0x7E, 0x43, 0x4B, 0x00, 0xFE, 0xBC, 0xBA, 0x0F, 0x81, 0x40, 0x22}}, {0x29, 20, {0x00, 0x77, 0x81, 0xB2, 0x0F, 0x35, 0xE9, 0x9C, 0x00, 0x5A, 0x76, 0xD2, 0x00, 0xCA, 0x16, 0x64, 0x0F, 0xAE, 0x07, 0x7C}}, {0x2A, 20, {0x00, 0xBE, 0x7D, 0x93, 0x0E, 0xE0, 0x31, 0xCA, 0x00, 0x73, 0xFE, 0x1A, 0x00, 0xB2, 0x25, 0x87, 0x0F, 0xBB, 0x2D, 0x02}}, {0x2B |
2个回答
同一电路和配置,下一批次启动过载保护是吗?
在使用TAS5719时,如果发现不同批次的产品表现不一致,这可能是由于多种原因造成的。以下是一些可能的原因和建议:
1. **生产过程中的变异**:不同的生产批次可能会有微小的制造差异,这可能会影响产品的性能。确保所有批次都遵循相同的生产标准和质量控制流程。 2. **存储和运输条件**:产品在存储和运输过程中可能会受到温度、湿度等环境因素的影响,这可能会影响其性能。检查存储和运输条件是否符合产品规格。 3. **老化测试**:不同批次的产品可能在出厂前没有经过相同的老化测试,这可能会导致性能差异。确保所有批次都经过了适当的老化测试。 4. **软件设置**:根据您提供的初始化数据,检查是否有可能存在配置错误。例如,振荡器调整寄存器(0x1B)和系统控制寄存器1(0x03)的设置是否适用于所有批次的产品。 5. **硬件设计**:检查原理图是否在所有批次中都保持一致。有时候,设计上的微小变化可能会影响产品的性能。 6. **电源和负载条件**:过载问题可能是由于电源供应不稳定或负载条件超出规格造成的。确保电源和负载条件符合产品规格。 7. **批次测试**:对每个批次的产品进行测试,以确保它们符合性能标准。这可以帮助识别可能的问题,并在产品发货前进行修正。 8. **与供应商沟通**:如果问题持续存在,与供应商沟通可能的生产问题或批次差异是很重要的。他们可能能提供更多的信息或解决方案。 9. **更新固件或软件**:如果问题与软件设置有关,考虑更新固件或软件以解决兼容性问题。 10. **技术支持**:如果问题无法自行解决,考虑联系TAS5719的制造商或技术支持团队寻求帮助。 请确保在进行任何更改之前备份当前的设置,以便在需要时可以恢复到原始状态。同时,记录所有测试和更改的结果,以便进行故障排除和未来的参考。 |
只有小组成员才能发言,加入小组>>
550 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1514 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1338 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1758浏览 29评论
2785浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1725浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1635浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1646浏览 13评论
/9
GMT+8, 2025-12-2 18:03 , Processed in 0.508288 second(s), Total 45, Slave 38 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
415
