开发板型号:esp32s3 n16r8
idf版本:ESP-IDF v5.3-dev-2218-g7cf8cc79a1-dirty 问题描述: 无法在使用手动flash加密时,将主机生成的密码bin文件写入esp32。 报错摘要:“espefuse.py burn_key: error: argument block: invalid choice:” 'flash_encryption' 报错反馈: espefuse.py --port /dev/ttyACM0 burn_key flash_encryption my_flash_encryption_key.bin espefuse.py vv4.8.dev1 Connecting.... Detecting chip type... ESP32-S3 usage: espefuse.py burn_key [-h] [--no-write-protect] [--no-read-protect] [--force-write-always] [--show-sensitive-info] {MAC_SPI_8M_0,BLOCK1,BLOCK_SYS_DATA,BLOCK2,BLOCK_USR_DATA,BLOCK3,BLOCK_KEY0,BLOCK4,BLOCK_KEY1,BLOCK5,BLOCK_KEY2,BLOCK6,BLOCK_KEY3,BLOCK7,BLOCK_KEY4,BLOCK8,BLOCK_KEY5,BLOCK9,BLOCK_SYS_DATA2,BLOCK10} keyfile {USER,RESERVED,XTS_AES_256_KEY_1,XTS_AES_256_KEY_2,XTS_AES_128_KEY,HMAC_DOWN_ALL,HMAC_DOWN_JTAG,HMAC_DOWN_DIGITAL_SIGNATURE,HMAC_UP,SECURE_BOOT_DIGEST0,SECURE_BOOT_DIGEST1,SECURE_BOOT_DIGEST2,XTS_AES_256_KEY} [BLOCK] [KEYFILE] [KEYPURPOSE] [BLOCK] [KEYFILE] [KEYPURPOSE] [BLOCK] [KEYFILE] [KEYPURPOSE] [BLOCK] [KEYFILE] [KEYPURPOSE] [BLOCK] [KEYFILE] [KEYPURPOSE] [BLOCK] [KEYFILE] [KEYPURPOSE] [BLOCK] [KEYFILE] [KEYPURPOSE] [BLOCK] [KEYFILE] [KEYPURPOSE] [BLOCK] [KEYFILE] [KEYPURPOSE] [BLOCK] [KEYFILE] [KEYPURPOSE] [BLOCK] [KEYFILE] [KEYPURPOSE] [BLOCK] [KEYFILE] [KEYPURPOSE] [BLOCK] [KEYFILE] [KEYPURPOSE] [BLOCK] [KEYFILE] [KEYPURPOSE] [BLOCK] [KEYFILE] [KEYPURPOSE] [BLOCK] [KEYFILE] [KEYPURPOSE] [BLOCK] [KEYFILE] [KEYPURPOSE] [BLOCK] [KEYFILE] [KEYPURPOSE] [BLOCK] [KEYFILE] [KEYPURPOSE] [BLOCK] [KEYFILE] [KEYPURPOSE] espefuse.py burn_key: error: argument block: invalid choice: 'flash_encryption' (choose from 'MAC_SPI_8M_0', 'BLOCK1', 'BLOCK_SYS_DATA', 'BLOCK2', 'BLOCK_USR_DATA', 'BLOCK3', 'BLOCK_KEY0', 'BLOCK4', 'BLOCK_KEY1', 'BLOCK5', 'BLOCK_KEY2', 'BLOCK6', 'BLOCK_KEY3', 'BLOCK7', 'BLOCK_KEY4', 'BLOCK8', 'BLOCK_KEY5', 'BLOCK9', 'BLOCK_SYS_DATA2', 'BLOCK10') [已解决] 后来发现是官方网站有更新的操作命令,将写入命令改为: espefuse.py --port /dev/ttyACM0 burn_key BLOCK_KEY1 my_n16r8_key.bin XTS_AES_128_KEY 就可以正常写入了。 |
1个回答
这个问题可能是由于以下几个原因导致的:
1. **命令格式错误**:在使用`espefuse.py`工具时,确保你遵循了正确的命令格式。根据你提供的错误信息,看起来命令格式可能有问题。正确的命令格式应该是: ```bash espefuse.py --port /dev/ttyACM0 burn_key flash_encryption my_flash_encryption_key.bin ``` 注意,不要在`flash_encryption`和`my_flash_encryption_key.bin`之间添加空格。 2. **参数错误**:错误信息中提到`invalid choice: 'flash_encryption'`,这可能是因为`burn_key`命令的参数不正确。确保你使用的参数是正确的,并且与你使用的ESP-IDF版本兼容。 3. **ESP-IDF版本问题**:你提到使用的是`ESP-IDF v5.3-dev-2218-g7cf8cc79a1-dirty`版本,这是一个开发版本,可能存在一些不稳定因素。尝试使用一个稳定的ESP-IDF版本,例如v4.4或v5.0,看看问题是否仍然存在。 4. **密钥文件格式问题**:确保你的密钥文件(`my_flash_encryption_key.bin`)是正确的格式。密钥文件应该是一个二进制文件,长度为32字节(256位)。 5. **串口连接问题**:确保你的ESP32开发板与计算机之间的串口连接是正确的,并且`/dev/ttyACM0`是正确的设备路径。你可以通过在终端运行`ls /dev/tty.*`来检查可用的串口设备。 6. **烧录权限问题**:确保你有足够的权限来执行烧录操作。在某些情况下,你可能需要使用`sudo`来运行`espefuse.py`命令。 |
只有小组成员才能发言,加入小组>>
1123 浏览 1 评论
574浏览 6评论
477浏览 5评论
有没有办法在不使用混杂模式的情况下实现Wifi驱动程序接收缓冲区访问中断呢?
461浏览 5评论
462浏览 4评论
435浏览 4评论
GMT+8, 2024-12-20 19:43 , Processed in 0.666270 second(s), Total 80, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
