电子发烧友论坛|
自建服务器OTA升级时出现error bin file错误。
1 烧录信息 spi:40M spi mode: DIO FlahSize:6 4MB-C1 2 固件编译信息 user1.4096.new.6.bin user2.4096.new.6.bin 注,文件上传至服务器有修改文件名。 3 固件升级信息 system_upgrade_start upgrade_connect 34752 upgrade_connect_cb pusrdata = HTTP/1.1 200 OK Date: Sat, 23 Jun 2018 06:54:59 GMT Server: Apache/2.4.27 (Win64) OpenSSL/1.1.0f PHP/5.6.31 X-Powered-By: PHP/5.6.31 Set-Cookie: PHPSESSID=15novfbebrqgfof8r97c14rgi4; path=/ Expires: Thu, 19 Nov 1981 08:52:00 GMT Cache-Control: no-store, no-cache, must-revalidate, post-check=0, pre-check=0 Pragma: no-cache Content-Ranges: bytes 344116 Content-Length: 344116 Content-Disposition: attachment; filename=ESP8266_v1.5.0_201806231412_userbin2.bin Content-Type: application/octet-stream sumlength = 344116 sec_block 85 .....................................................................................upgrade_get_sum_disconcb 32784 erase sector=129 ok erase sector=130 ok erase sector=131 ok erase sector=132 ok erase sector=133 ok erase sector=134 ok erase sector=135 ok erase sector=136 ok erase sector=137 ok erase sector=138 ok erase sector=139 ok erase sector=140 ok erase sector=141 ok erase sector=142 ok erase sector=143 ok erase sector=144 ok erase sector=145 ok erase sector=146 ok erase sector=147 ok erase sector=148 ok erase sector=149 ok erase sector=150 ok erase sector=151 ok erase sector=152 ok erase sector=153 ok erase sector=154 ok erase sector=155 ok erase sector=156 ok erase sector=157 ok erase sector=158 ok erase sector=159 ok erase sector=160 ok erase sector=161 ok erase sector=162 ok erase sector=163 ok erase sector=164 ok erase sector=165 ok erase sector=166 ok erase sector=167 ok erase sector=168 ok erase sector=169 ok erase sector=170 ok erase sector=171 ok erase sector=172 ok erase sector=173 ok erase sector=174 ok erase sector=175 ok erase sector=176 ok erase sector=177 ok erase sector=178 ok erase sector=179 ok erase sector=180 ok erase sector=181 ok erase sector=182 ok erase sector=183 ok erase sector=184 ok erase sector=185 ok erase sector=186 ok erase sector=187 ok erase sector=188 ok erase sector=189 ok erase sector=190 ok erase sector=191 ok erase sector=192 ok erase sector=193 ok erase sector=194 ok erase sector=195 ok erase sector=196 ok erase sector=197 ok erase sector=198 ok erase sector=199 ok erase sector=200 ok erase sector=201 ok erase sector=202 ok erase sector=203 ok erase sector=204 ok erase sector=205 ok erase sector=206 ok erase sector=207 ok erase sector=208 ok erase sector=209 ok erase sector=210 ok erase sector=211 ok erase sector=212 ok erase sector=213 ok ALL=85 sectors erase ok! upgrade_connect_cb sumlength = 344116 upgrade file download start. error bin file totallen = 2368 upgrade_check user_esp_platform_upgrade_failed 搜索过之前的topic,回复说是Espressif Cloud 正在更新调试。 |
1个回答
在解决自建服务器OTA升级时出现的error bin file错误时,我们可以按照以下步骤进行排查和解决:
1. 确认固件文件格式和命名是否正确:首先,请确保固件文件的格式和命名符合设备的要求。从您提供的信息来看,固件文件名已经进行了修改,但请确保修改后的文件名仍然符合设备的要求。 2. 检查固件文件是否完整:在上传固件文件到服务器之前,请确保文件没有损坏或丢失。您可以通过比较原始文件和上传后的文件的MD5或SHA1哈希值来检查文件的完整性。 3. 检查固件文件大小:请确认固件文件的大小是否符合设备的存储容量要求。从您提供的信息来看,FlahSize为64MB-C1,因此请确保固件文件大小不超过这个限制。 4. 检查烧录信息是否正确:您提供的烧录信息为spi:40M,spi mode: DIO。请确保这些参数与设备的硬件配置相匹配。如果不确定,您可以查阅设备的硬件手册或联系设备制造商以获取正确的参数。 5. 检查OTA升级过程中的网络连接:在OTA升级过程中,请确保设备与服务器之间的网络连接稳定。不稳定的网络连接可能导致固件文件传输不完整,从而引发错误。 6. 检查服务器设置:请确保服务器上的OTA升级服务正常运行,并且配置正确。您可以查看服务器日志以获取更多关于错误的信息。 7. 尝试重新编译固件:如果以上步骤都无法解决问题,您可以尝试重新编译固件。在重新编译过程中,请确保使用正确的编译器设置和参数。 |
只有小组成员才能发言,加入小组>>
386 浏览 0 评论
951 浏览 0 评论
1679 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1337 浏览 1 评论
1235 浏览 1 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1255浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
930浏览 3评论
2345浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2532浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1054浏览 2评论
/9
GMT+8, 2025-12-4 06:57 , Processed in 0.634362 second(s), Total 77, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2298
