上电串口打印信息 无法启动,不知道哪里的问题,好心人解答下
ELF file SHA256: 5b8e7b8cba2a208c E (765) esp_core_dump_flash: Core dump flash config is corrupted! CRC=0x7bd5c66f instead of 0x0 Rebooting... f﨓SP-ROM:esp32s3-20210327 Build:Mar 27 2021 rst:0xc (RTC_SW_CPU_RST),boot:0x2a (SPI_FAST_FLASH_BOOT) Saved PC:0x40376bdc SPIWP:0xee mode:DIO, clock div:1 load:0x3fcd0108,len:0x1654 load:0x403b6000,len:0xed4 load:0x403ba000,len:0x32dc entry 0x403b632c [0;32mI (29) boot: ESP-IDF v4.4.1-405-g6c5fb29c2c 2nd stage bootloader[0m [0;32mI (29) boot: compile time 04:22:20[0m [0;32mI (29) boot: chip revision: 0[0m [0;32mI (32) qio_mode: Enabling default flash chip QIO[0m [0;32mI (38) boot.esp32s3: Boot SPI Speed : 80MHz[0m [0;32mI (42) boot.esp32s3: SPI Mode : QIO[0m [0;32mI (47) boot.esp32s3: SPI Flash Size : 8MB[0m [0;32mI (52) boot: Enabling RNG early entropy source...[0m [0;32mI (57) boot: Partition Table:[0m [0;32mI (61) boot: ## Label Usage Type ST Offset Length[0m [0;32mI (68) boot: 0 nvs WiFi data 01 02 00009000 00005000[0m [0;32mI (75) boot: 1 otadata OTA data 01 00 0000e000 00002000[0m [0;32mI (83) boot: 2 ota_0 OTA app 00 10 00010000 00200000[0m [0;32mI (90) boot: 3 ota_1 OTA app 00 11 00210000 00200000[0m [0;32mI (98) boot: 4 uf2 factory app 00 00 00410000 00040000[0m [0;32mI (105) boot: 5 ffat Unknown data 01 81 00450000 003b0000[0m [0;32mI (113) boot: End of partition table[0m [0;32mI (617) esp_image: segment 0: paddr=00010020 vaddr=3c030020 size=0be9ch ( 48796) map[0m [0;32mI (625) esp_image: segment 1: paddr=0001bec4 vaddr=3fc91100 size=03e9ch ( 16028) load[0m [0;32mI (628) esp_image: segment 2: paddr=0001fd68 vaddr=40374000 size=002b0h ( 688) load[0m [0;32mI (631) esp_image: segment 3: paddr=00020020 vaddr=42000020 size=25f64h (155492) map[0m [0;32mI (663) esp_image: segment 4: paddr=00045f8c vaddr=403742b0 size=0ce48h ( 52808) load[0m [0;32mI (679) boot: Loaded app from partition at offset 0x10000[0m [0;32mI (679) boot: Disabling RNG early entropy source...[0m E (696) spi_flash: Detected size(4096k) smaller than the size in the binary image header(8192k). Probe failed. assert failed: do_core_init startup.c:326 (flash_ret == ESP_OK) Backtrace: 0x40376fce:0x3fceb170 0x40379689:0x3fceb190 0x4037f52d:0x3fceb1b0 0x4200882e:0x3fceb2e0 0x4037693d:0x3fceb310 0x403bb428:0x3fceb340 0x403bb891:0x3fceb380 0x403b63de:0x3fceb4b0 0x40045c01:0x3fceb570 |<-CORRUPTED |
1个回答
从您提供的串口打印信息来看,ESP32-S3上电无法启动的原因可能是由于核心转储(core dump)配置损坏。以下是一些可能的解决方案:
1. **检查烧录文件**:确保您烧录的固件文件是正确的,没有损坏。您可以通过重新下载固件文件并再次烧录来尝试解决这个问题。 2. **检查烧录过程**:确保烧录过程中没有出现错误,例如烧录速度过快或烧录过程中出现中断。您可以尝试降低烧录速度或确保烧录过程中没有干扰。 3. **检查烧录配置**:检查您的烧录配置是否正确,例如烧录地址、烧录模式等。错误的配置可能导致固件烧录不完整或损坏。 4. **检查硬件问题**:如果以上方法都无法解决问题,可能是硬件存在问题。您可以尝试更换烧录器或ESP32-S3模块,以排除硬件故障的可能性。 5. **更新烧录工具**:确保您使用的烧录工具是最新版本,以避免因工具问题导致的烧录失败。 6. **尝试清除Flash**:在某些情况下,清除ESP32-S3的Flash存储器可能有助于解决问题。您可以使用烧录工具提供的擦除功能来尝试清除Flash。 7. **查看官方文档和社区**:如果问题仍然存在,您可以查看ESP32-S3的官方文档,或者在相关社区寻求帮助。可能有其他开发者遇到过类似的问题,并提供了解决方案。 希望这些建议能帮助您解决问题。如果问题仍然存在,请随时提供更多信息,以便我们能够更好地帮助您。 |
只有小组成员才能发言,加入小组>>
945 浏览 0 评论
1672 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5021 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1254浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2338浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2528浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1052浏览 2评论
/9
GMT+8, 2025-12-2 18:02 , Processed in 0.425304 second(s), Total 40, Slave 33 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
732
