电子发烧友论坛|
我想使用esp_audio_play 来播放SD卡音乐,用回调函数判断播放完成后重新播放,进而实现循环播放功能。
现在的问题是:每次播放完成后都要差不多2秒才能进回调函数。 我的程序初始化是: static esp_audio_handle_t setup_player() { esp_audio_cfg_t cfg = DEFAULT_ESP_AUDIO_CONFIG(); audio_board_handle_t board_handle = audio_board_init(); cfg.vol_handle = board_handle->audio_hal; cfg.vol_set = (audio_volume_set)audio_hal_set_volume; cfg.vol_get = (audio_volume_get)audio_hal_get_volume; cfg.prefer_type = ESP_AUDIO_PREFER_MEM; cfg.resample_rate = 44100; cfg.evt_que = xQueueCreate(3, sizeof(esp_audio_state_t)); cfg.cb_func = audio_service_cb; esp_audio_handle_t player = esp_audio_create(&cfg); audio_hal_ctrl_codec(board_handle->audio_hal, AUDIO_HAL_CODEC_MODE_BOTH, AUDIO_HAL_CTRL_START); a2dp_stream_config_t a2dp_config = { .type = AUDIO_STREAM_READER, .user_callback.user_a2d_cb = user_a2dp_sink_cb, }; audio_element_handle_t bt_stream_reader = a2dp_stream_init(&a2dp_config); esp_audio_input_stream_add(player, bt_stream_reader); ESP_LOGI(TAG, "[4.4] Create fatfs stream to read data from sdcard"); char *url = NULL; sdcard_list_current(sdcard_list_handle, &url); fatfs_stream_cfg_t fatfs_cfg = FATFS_STREAM_CFG_DEFAULT(); fatfs_cfg.type = AUDIO_STREAM_READER; fatfs_stream_reader = fatfs_stream_init(&fatfs_cfg); audio_element_set_uri(fatfs_stream_reader, url); esp_audio_input_stream_add(player, fatfs_stream_reader); ESP_LOGI(TAG, "[2.1] Create tone stream to read data from flash"); tone_stream_cfg_t tone_cfg = TONE_STREAM_CFG_DEFAULT(); tone_cfg.type = AUDIO_STREAM_READER; audio_element_handle_t tone_stream_reader = tone_stream_init(&tone_cfg); esp_audio_input_stream_add(player, tone_stream_reader); // Add decoders and encoders to esp_audio mp3_decoder_cfg_t mp3_dec_cfg = DEFAULT_MP3_DECODER_CONFIG(); wav_decoder_cfg_t wav_dec_cfg = DEFAULT_WAV_DECODER_CONFIG(); pcm_decoder_cfg_t pcm_dec_cfg = DEFAULT_PCM_DECODER_CONFIG(); esp_audio_codec_lib_add(player, AUDIO_CODEC_TYPE_DECODER, mp3_decoder_init(&mp3_dec_cfg)); esp_audio_codec_lib_add(player, AUDIO_CODEC_TYPE_DECODER, wav_decoder_init(&wav_dec_cfg)); esp_audio_codec_lib_add(player, AUDIO_CODEC_TYPE_DECODER, pcm_decoder_init(&pcm_dec_cfg)); // Create writers and add to esp_audio i2s_stream_cfg_t i2s_writer = I2S_STREAM_CFG_DEFAULT(); i2s_writer.i2s_config.sample_rate = 44100; i2s_writer.type = AUDIO_STREAM_WRITER; esp_audio_output_stream_add(player, i2s_stream_init(&i2s_writer)); esp_audio_play_timeout_set(player,500); esp_audio_vol_set(player, 60); AUDIO_MEM_SHOW(TAG); ESP_LOGI(TAG, "esp_audio instance is:%prn", player); return player; } 回调函数是: void audio_service_cb(esp_audio_state_t *audio, void *ctx) { ESP_LOGI(TAG, "Entry audio call back function status is %d",audio->status); ESP_LOGI(TAG, "Entry audio call back function media type is is %d",audio->media_src); esp_audio_state_t state = {0}; esp_audio_state_get(test_handle->player, &state); if(test_handle->work_mode != SD_MODE) return; if(music_repeat == 1){ if((audio->status == AUDIO_STATUS_FINISHED)&&(state.media_src == MEDIA_SRC_TYPE_MUSIC_SD)) { ESP_LOGI(TAG, "repeat play music is %s",music_name); esp_audio_media_type_set(test_handle->player, MEDIA_SRC_TYPE_MUSIC_SD); esp_audio_play(test_handle->player, AUDIO_CODEC_TYPE_DECODER, music_name, 0); test_handle->work_mode = SD_MODE; } } } 播放功能就是正常的函数使用: memcpy(music_name,url,strlen(url)); ESP_LOGI("BS-X001", "play music is %s",url); esp_audio_vol_set(test_handle->player, music_volume); esp_audio_media_type_set(test_handle->player, MEDIA_SRC_TYPE_MUSIC_SD); esp_audio_play(test_handle->player, AUDIO_CODEC_TYPE_DECODER, music_name, 0); int duration = 0; esp_audio_duration_get(test_handle->player, &duration); ESP_LOGI("BS-X001", " music duration time %d ms",duration); music_repeat = raw_datas[3]; |
1个回答
首先,让我们分析一下问题。在使用esp_audio_play播放SD卡音乐时,您希望在播放完成后立即进入回调函数以实现循环播放功能。但是,您发现播放完成后需要等待大约2秒才能进入回调函数。
这个问题可能是由以下几个原因导致的: 1. 回调函数的优先级较低:在ESP32系统中,回调函数的优先级可能较低,导致在其他任务执行时,回调函数被延迟执行。 2. 播放完成后的处理逻辑:在播放完成后,可能有一些额外的处理逻辑需要执行,这会导致一定的延迟。 3. 硬件或软件问题:可能是硬件或软件的问题导致播放完成后的回调函数延迟执行。 为了解决这个问题,您可以尝试以下方法: 1. 检查回调函数的优先级:确保回调函数的优先级足够高,以便在播放完成后立即执行。 2. 优化播放完成后的处理逻辑:检查播放完成后的处理逻辑,看看是否有可以优化的地方,以减少延迟。 3. 更新ESP-ADF:确保您使用的ESP-ADF库是最新版本,因为新版本可能修复了一些已知的问题。 4. 使用其他播放策略:如果问题仍然存在,您可以考虑使用其他播放策略,例如使用一个定时器在播放完成后立即触发回调函数。 关于您的程序初始化部分,您已经使用了DEFAULT_ESP_AUDIO_CONFIG()来初始化esp_audio配置。这是一个正确的方法。但是,如果您发现问题仍然存在,您可以尝试以下步骤: 1. 确保您的音频板初始化是正确的,例如audio_board_init()。 2. 确保您的音量设置函数(如audio_hal_set_volume)是正确的。 3. 在回调函数中添加一些调试信息,以便更好地了解播放完成后的执行流程。 4. 如果可能的话,尝试使用其他音频播放库,看看问题是否仍然存在。 希望这些建议能帮助您解决问题。 |
只有小组成员才能发言,加入小组>>
471 浏览 0 评论
994 浏览 0 评论
1710 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1370 浏览 1 评论
1256 浏览 1 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1289浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
943浏览 3评论
2387浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2579浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1071浏览 2评论
/9
GMT+8, 2025-12-14 20:54 , Processed in 0.608074 second(s), Total 44, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
580
