电子发烧友论坛
烧录到硬件后,esp32运行的时候一直reboot.请教一下,是什么问题,或者排查思路 'C:Usersshiweesp-idftoolsidf.py' '-p' 'COM37'"... --- idf_monitor on COM37 115200 --- --- Quit: Ctrl+] | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H --- ets Jul 29 2019 12:21:46 rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:2 load:0x3fff0030,len:4 load:0x3fff0034,len:6928 ho 0 tail 12 room 4 load:0x40078000,len:13072 load:0x40080400,len:3896 0x40080400: _init at ??:? entry 0x40080688 I (31) boot: ESP-IDF v4.1-dirty 2nd stage bootloader I (31) boot: compile time 18:15:32 I (31) boot: chip revision: 3 I (34) boot_comm: chip revision: 3, min. bootloader chip revision: 0 I (41) boot.esp32: SPI Speed : 40MHz I (46) boot.esp32: SPI Mode : DIO I (51) boot.esp32: SPI Flash Size : 4MB I (55) boot: Enabling RNG early entropy source... I (60) boot: Partition Table: I (64) boot: ## Label Usage Type ST Offset Length I (71) boot: 0 nvs WiFi data 01 02 00009000 00006000 I (79) boot: 1 phy_init RF data 01 01 0000f000 00001000 I (86) boot: 2 factory factory app 00 00 00010000 00100000 I (94) boot: End of partition table I (98) boot_comm: chip revision: 3, min. application chip revision: 0 I (105) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x05250 ( 21072) map I (122) esp_image: segment 1: paddr=0x00015278 vaddr=0x3ffb0000 size=0x02154 ( 8532) load I (126) esp_image: segment 2: paddr=0x000173d4 vaddr=0x40080000 size=0x00404 ( 1028) load 0x40080000: _WindowOverflow4 at C:/Users/shiwe/esp-idf/components/freertos/xtensa_vectors.S:1778 I (132) esp_image: segment 3: paddr=0x000177e0 vaddr=0x40080404 size=0x08838 ( 34872) load I (156) esp_image: segment 4: paddr=0x00020020 vaddr=0x400d0020 size=0x128d4 ( 75988) map 0x400d0020: _stext at ??:? I (185) esp_image: segment 5: paddr=0x000328fc vaddr=0x40088c3c size=0x00e7c ( 3708) load 0x40088c3c: rtc_wdt_set_length_of_reset_signal at C:/Users/shiwe/esp-idf/components/soc/esp32/rtc_wdt.c:136 I (192) boot: Loaded app from partition at offset 0x10000 I (193) boot: Disabling RNG early entropy source... I (195) cpu_start: Pro cpu up. I (198) cpu_start: Application information: I (203) cpu_start: Project name: hello-world I (208) cpu_start: App version: 1 I (213) cpu_start: Compile time: Sep 8 2020 18:15:06 I (219) cpu_start: ELF file SHA256: 7fa99573b4848c3c... I (225) cpu_start: ESP-IDF: v4.1-dirty I (230) cpu_start: Starting app cpu, entry point is 0x40081028 0x40081028: call_start_cpu1 at C:/Users/shiwe/esp-idf/components/esp32/cpu_start.c:271 I (0) cpu_start: App cpu up. I (241) heap_init: Initializing. RAM available for dynamic allocation: I (247) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (253) heap_init: At 3FFB2960 len 0002D6A0 (181 KiB): DRAM I (260) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (266) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (272) heap_init: At 40089AB8 len 00016548 (89 KiB): IRAM I (279) cpu_start: Pro cpu start user code I (297) spi_flash: detected chip: generic I (297) spi_flash: flash io: dio I (298) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. 任务 1 已经执行:1 次 任务 2 已经执行:1 次 Guru Meditation Error: Core 0 panic'ed (InstrFetchProhibited). Exception was unhandled. Core 0 register dump: PC : 0x800d0add PS : 0x00050033 A0 : 0x800d0add A1 : 0x3ffb4770 A2 : 0x00000000 A3 : 0x7fffffff A4 : 0x00000000 A5 : 0x454c4449 A6 : 0x3ffb0031 A7 : 0x00000000 A8 : 0x00000000 A9 : 0x00000400 A10 : 0x00000000 A11 : 0x00000001 A12 : 0x00000000 A13 : 0x800846b0 A14 : 0x3ffb47f0 A15 : 0x00000000 SAR : 0x00000000 EXCCAUSE: 0x00000014 EXCVADDR: 0x800d0adc LBEG : 0x00000000 LEND : 0x00000000 LCOUNT : 0x00000001 ELF file SHA256: 7fa99573b4848c3c Backtrace: 0x400d0ada:0x3ffb4770 0x400d0ada:0x3ffb32ec |<-CORRUPTED 0x400d0ada: main_task at C:/Users/shiwe/esp-idf/components/esp32/cpu_start.c:565 0x400d0ada: main_task at C:/Users/shiwe/esp-idf/components/esp32/cpu_start.c:565 Rebooting... ets Jul 29 2019 12:21:46 rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:2 load:0x3fff0030,len:4 load:0x3fff0034,len:6928 ho 0 tail 12 room 4 load:0x40078000,len:13072 load:0x40080400,len:3896 0x40080400: _init at ??:? entry 0x40080688 I (31) boot: ESP-IDF v4.1-dirty 2nd stage bootloader I (31) boot: compile time 18:15:32 |
1个回答
以下是一些建议和可能的原因:
1. 硬件问题:检查ESP32模块是否连接正确,电源是否稳定,以及是否有任何损坏的元件。 2. 电源问题:确保ESP32的电源电压在规定的范围内(通常为3.3V或5V),过高或过低的电压可能导致系统不稳定。 3. 软件问题:检查代码是否有错误,例如内存泄漏、死循环等。从您提供的代码片段来看,代码不完整,无法确定是否存在问题。请确保代码逻辑正确,没有导致系统崩溃的错误。 4. 配置问题:检查`sdkconfig.h`文件中的配置是否正确,例如时钟设置、内存分配等。错误的配置可能导致系统不稳定。 5. 固件问题:尝试重新烧录固件,确保固件没有损坏或不兼容。 6. 外部干扰:检查周围环境是否有强烈的电磁干扰,这可能影响ESP32的正常工作。 7. 重置按钮问题:如果ESP32模块上的重置按钮卡住或接触不良,可能导致设备不断重启。检查并修复重置按钮。 8. 软件看门狗:如果启用了软件看门狗,但任务没有及时喂狗,可能导致系统重启。检查任务是否正确地喂狗。 |
只有小组成员才能发言,加入小组>>
944 浏览 0 评论
1671 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5015 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1252浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2333浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2526浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1051浏览 2评论
/9
GMT+8, 2025-12-1 23:42 , Processed in 0.440683 second(s), Total 41, Slave 34 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
675
