电子发烧友论坛|
在esp32开发板上测试blufi例程,发现在ble成功连接后,通过手机发送完ssid和password后,一直循环打印这两条log,wifi无法连接,不知道是什么原因导致?未对例程做任何修改。
E (60049) BT_L2CAP: l2ble_update_att_acl_pkt_num not found p_tcb W (60049) BT_BTC: btc_blufi_send_encap wait to send blufi custom data 下面为开机的log: I (29) boot: ESP-IDF v4.2-dirty 2nd stage bootloader I (29) boot: compile time 15:40:07 I (29) boot: chip revision: 1 I (32) boot_comm: chip revision: 1, min. bootloader chip revision: 0 I (39) boot.esp32: SPI Speed : 40MHz I (44) boot.esp32: SPI Mode : DIO I (48) boot.esp32: SPI Flash Size : 2MB I (53) boot: Enabling RNG early entropy source... I (58) boot: Partition Table: I (62) boot: ## Label Usage Type ST Offset Length I (69) boot: 0 nvs WiFi data 01 02 00009000 00006000 I (76) boot: 1 phy_init RF data 01 01 0000f000 00001000 I (84) boot: 2 factory factory app 00 00 00010000 00100000 I (91) boot: End of partition table I (96) boot_comm: chip revision: 1, min. application chip revision: 0 I (103) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x2453c (148796) map I (168) esp_image: segment 1: paddr=0x00034564 vaddr=0x3ffbdb60 size=0x03f78 ( 16248) load I (175) esp_image: segment 2: paddr=0x000384e4 vaddr=0x40080000 size=0x00404 ( 1028) load 0x40080000: _WindowOverflow4 at C:/Users/liny/Desktop/esp-idf-2/components/freertos/xtensa/xtensa_vectors.S:1730 I (176) esp_image: segment 3: paddr=0x000388f0 vaddr=0x40080404 size=0x07728 ( 30504) load I (198) esp_image: segment 4: paddr=0x00040020 vaddr=0x400d0020 size=0xa9248 (692808) map 0x400d0020: _stext at ??:? I (462) esp_image: segment 5: paddr=0x000e9270 vaddr=0x40087b2c size=0x15e64 ( 89700) load 0x40087b2c: r_lld_pdu_rx_handler at ??:? I (517) boot: Loaded app from partition at offset 0x10000 I (517) boot: Disabling RNG early entropy source... I (518) cpu_start: Pro cpu up. I (521) cpu_start: Application information: I (526) cpu_start: Project name: blufi_demo I (531) cpu_start: App version: v4.2-dirty I (536) cpu_start: Compile time: May 18 2021 10:01:43 I (542) cpu_start: ELF file SHA256: d2501fc46410de51... I (548) cpu_start: ESP-IDF: v4.2-dirty I (554) cpu_start: Starting app cpu, entry point is 0x400818d4 0x400818d4: call_start_cpu1 at C:/Users/liny/Desktop/esp-idf-2/components/esp32/cpu_start.c:287 I (0) cpu_start: App cpu up. I (564) heap_init: Initializing. RAM available for dynamic allocation: I (571) heap_init: At 3FFAFF10 len 000000F0 (0 KiB): DRAM I (577) heap_init: At 3FFB6388 len 00001C78 (7 KiB): DRAM I (583) heap_init: At 3FFB9A20 len 00004108 (16 KiB): DRAM I (589) heap_init: At 3FFCB280 len 00014D80 (83 KiB): DRAM I (595) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (602) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (608) heap_init: At 4009D990 len 00002670 (9 KiB): IRAM I (614) cpu_start: Pro cpu start user code I (633) spi_flash: detected chip: generic I (633) spi_flash: flash io: dio W (633) spi_flash: Detected size(4096k) larger than the size in the binary image header(2048k). Using the size in the binary image header. I (644) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (750) wifi:wifi driver task: 3ffcf6a0, prio:23, stack:6656, core=0 I (750) system_api: Base MAC address is not set I (750) system_api: read default base MAC address from EFUSE I (770) wifi:wifi firmware version: 1865b55 I (770) wifi:wifi certification version: v7.0 I (770) wifi:config NVS flash: enabled I (770) wifi:config nano formating: disabled I (780) wifi:Init data frame dynamic rx buffer num: 32 I (780) wifi:Init management frame dynamic rx buffer num: 32 I (790) wifi:Init management short buffer num: 32 I (790) wifi:Init dynamic tx buffer num: 32 I (800) wifi:Init static rx buffer size: 1600 I (800) wifi:Init static rx buffer num: 10 I (800) wifi:Init dynamic rx buffer num: 32 I (810) wifi_init: rx ba win: 6 I (810) wifi_init: tcpip mbox: 32 I (820) wifi_init: udp mbox: 6 I (820) wifi_init: tcp mbox: 6 I (820) wifi_init: tcp tx win: 5744 I (830) wifi_init: tcp rx win: 5744 I (830) wifi_init: tcp mss: 1440 I (840) wifi_init: WiFi IRAM OP enabled I (840) wifi_init: WiFi RX IRAM OP enabled I (930) phy: phy_version: 4500, 0cd6843, Sep 17 2020, 15:37:07, 0, 0 I (940) wifi:mode : sta (08:3a:f2:ac:1b:e8) I (940) BTDM_INIT: BT controller compile version [3723d5b] I (1280) BLUFI_EXAMPLE: BD ADDR: 08:3a:f2:ac:1b:ea I (1280) BLUFI_EXAMPLE: BLUFI VERSION 0102 I (1280) BLUFI_EXAMPLE: BLUFI init finish I (350810) BLUFI_EXAMPLE: BLUFI ble connect E (354550) BT_L2CAP: l2ble_update_att_acl_pkt_num not found p_tcb W (354550) BT_BTC: btc_blufi_send_encap wait to send blufi custom data E (354560) BT_L2CAP: l2ble_update_att_acl_pkt_num not found p_tcb W (354560) BT_BTC: btc_blufi_send_encap wait to send blufi custom data E (354580) BT_L2CAP: l2ble_update_att_acl_pkt_num not found p_tcb W (354580) BT_BTC: btc_blufi_send_encap wait to send blufi custom data E (354590) BT_L2CAP: l2ble_update_att_acl_pkt_num not found p_tcb W (354590) BT_BTC: btc_blufi_send_encap wait to send blufi custom data E (354600) BT_L2CAP: l2ble_update_att_acl_pkt_num not found p_tcb W (354600) BT_BTC: btc_blufi_send_encap wait to send blufi custom data E (354620) BT_L2CAP: l2ble_update_att_acl_pkt_num not found p_tcb W (354620) BT_BTC: btc_blufi_send_encap wait to send blufi custom data E (354630) BT_L2CAP: l2ble_update_att_acl_pkt_num not found p_tcb W (354630) BT_BTC: btc_blufi_send_encap wait to send blufi custom data E (354650) BT_L2CAP: l2ble_update_att_acl_pkt_num not found p_tcb W (354650) BT_BTC: btc_blufi_send_encap wait to send blufi custom data E (354660) BT_L2CAP: l2ble_update_att_acl_pkt_num not found p_tcb W (354660) BT_BTC: btc_blufi_send_encap wait to send blufi custom data E (354670) BT_L2CAP: l2ble_update_att_acl_pkt_num not found p_tcb W (354670) BT_BTC: btc_blufi_send_encap wait to send blufi custom data E (354690) BT_L2CAP: l2ble_update_att_acl_pkt_num not found p_tcb W (354690) BT_BTC: btc_blufi_send_encap wait to send blufi custom data E (354700) BT_L2CAP: l2ble_update_att_acl_pkt_num not found p_tcb W (354700) BT_BTC: btc_blufi_send_encap wait to send blufi custom data E (354720) BT_L2CAP: l2ble_update_att_acl_pkt_num not found p_tcb W (354720) BT_BTC: btc_blufi_send_encap wait to send blufi custom data E (354730) BT_L2CAP: l2ble_update_att_acl_pkt_num not found p_tcb W (354730) BT_BTC: btc_blufi_send_encap wait to send blufi custom data E (354740) BT_L2CAP: l2ble_update_att_acl_pkt_num not found p_tcb W (354740) BT_BTC: btc_blufi_send_encap wait to send blufi custom data E (354760) BT_L2CAP: l2ble_update_att_acl_pkt_num not found p_tcb W (354760) BT_BTC: btc_blufi_send_encap wait to send blufi custom data E (354770) BT_L2CAP: l2ble_update_att_acl_pkt_num not found p_tcb W (354770) BT_BTC: btc_blufi_send_encap wait to send blufi custom data E (354790) BT_L2CAP: l2ble_update_att_acl_pkt_num not found p_tcb W (354790) BT_BTC: btc_blufi_send_encap wait to send blufi custom data E (354800) BT_L2CAP: l2ble_update_att_acl_pkt_num not found p_tcb W (354800) BT_BTC: btc_blufi_send_encap wait to send blufi custom data E (354820) BT_L2CAP: l2ble_update_att_acl_pkt_num not found p_tcb W (354820) BT_BTC: btc_blufi_send_encap wait to send blufi custom data E (354830) BT_L2CAP: l2ble_update_att_acl_pkt_num not found p_tcb W (354830) BT_BTC: btc_blufi_send_encap wait to send blufi custom data E (354840) BT_L2CAP: l2ble_update_att_acl_pkt_num not found p_tcb W (354840) BT_BTC: btc_blufi_send_encap wait to send blufi custom data E (354860) BT_L2CAP: l2ble_update_att_acl_pkt_num not found p_tcb W (354860) BT_BTC: btc_blufi_send_encap wait to send blufi custom data E (354870) BT_L2CAP: l2ble_update_att_acl_pkt_num not found p_tcb W (354870) BT_BTC: btc_blufi_send_encap wait to send blufi custom data E (354890) BT_L2CAP: l2ble_update_att_acl_pkt_num not found p_tcb W (354890) BT_BTC: btc_blufi_send_encap wait to send blufi custom data E (354900) BT_L2CAP: l2ble_update_att_acl_pkt_num not found p_tcb W (354900) BT_BTC: btc_blufi_send_encap wait to send blufi custom data E (354910) BT_L2CAP: l2ble_update_att_acl_pkt_num not found p_tcb W (354910) BT_BTC: btc_blufi_send_encap wait to send blufi custom data E (354930) BT_L2CAP: l2ble_update_att_acl_pkt_num not found p_tcb W (354930) BT_BTC: btc_blufi_send_encap wait to send blufi custom data |
1个回答
以下是一些建议和可能的原因:
1. 确保您的ESP32开发板固件是最新的。您提到的“ESP-IDF v4.2-dirty”可能表示您的固件不是最新的。请尝试更新到最新的稳定版本。 2. 检查您的ESP32开发板的硬件连接是否正常。确保天线连接正确,没有损坏或松动。 3. 检查您的手机是否支持BLE。确保您的手机蓝牙功能正常,并且支持BLE。 4. 检查您的SSID和密码是否正确。确保您输入的SSID和密码与您的WiFi网络匹配。 5. 检查您的WiFi网络是否允许BLE设备连接。有些WiFi网络可能限制了连接的设备类型。 6. 检查ESP32开发板的电源供应是否稳定。不稳定的电源可能会影响WiFi连接。 7. 尝试使用其他BLE设备或手机进行测试,以排除设备兼容性问题。 8. 如果问题仍然存在,您可以尝试查看ESP32开发板的日志,以获取更多关于问题的信息。您提供的日志信息中,"E (60049) BT_L2CAP: l2ble_update_att_acl_pkt_num not found" 和 "W (60049) BT_BTC: btc_blufi_send_encap wait to send blufi custom data" 可能与BLE连接有关,但不一定与WiFi连接问题直接相关。您可以进一步分析这些日志,以确定问题的根本原因。 |
只有小组成员才能发言,加入小组>>
330 浏览 0 评论
948 浏览 0 评论
1676 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1335 浏览 1 评论
1234 浏览 1 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1254浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
928浏览 3评论
2341浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2529浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1052浏览 2评论
/9
GMT+8, 2025-12-3 15:06 , Processed in 0.978043 second(s), Total 77, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
265
