请帮忙, 浏览器显示: Header fields are too long for server to interpret
ets Jun 8 2016 00:22:57 rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:2 load:0x3fff0030,len:6732 ho 0 tail 12 room 4 load:0x40078000,len:14812 load:0x40080400,len:3792 entry 0x40080694 I (29) boot: ESP-IDF v4.4-dev-3540-g4e03a9c34c-dirty 2nd stage bootloader I (29) boot: compile time 08:27:10 I (30) boot: chip revision: 1 I (34) boot_comm: chip revision: 1, min. bootloader chip revision: 0 I (41) boot.esp32: SPI Speed : 40MHz I (45) boot.esp32: SPI Mode : DIO I (50) boot.esp32: SPI Flash Size : 2MB I (54) boot: Enabling RNG early entropy source... I (60) boot: Partition Table: I (63) boot: ## Label Usage Type ST Offset Length I (71) boot: 0 nvs WiFi data 01 02 00009000 00006000 I (78) boot: 1 phy_init RF data 01 01 0000f000 00001000 I (86) boot: 2 factory factory app 00 00 00010000 00100000 I (93) boot: End of partition table I (97) boot_comm: chip revision: 1, min. application chip revision: 0 I (104) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=19f60h (106336) map I (151) esp_image: segment 1: paddr=00029f88 vaddr=3ffb0000 size=03840h ( 14400) load I (157) esp_image: segment 2: paddr=0002d7d0 vaddr=40080000 size=02848h ( 10312) load I (162) esp_image: segment 3: paddr=00030020 vaddr=400d0020 size=88a80h (559744) map I (368) esp_image: segment 4: paddr=000b8aa8 vaddr=40082848 size=11b8ch ( 72588) load I (398) esp_image: segment 5: paddr=000ca63c vaddr=50000000 size=00010h ( 16) load I (409) boot: Loaded app from partition at offset 0x10000 I (409) boot: Disabling RNG early entropy source... I (421) cpu_start: Pro cpu up. I (421) cpu_start: Starting app cpu, entry point is 0x40081168 I (0) cpu_start: App cpu up. I (435) cpu_start: Pro cpu start user code I (435) cpu_start: cpu freq: 160000000 I (435) cpu_start: Application information: I (440) cpu_start: Project name: https_server I (445) cpu_start: App version: 1 I (449) cpu_start: Compile time: Oct 26 2021 09:01:29 I (455) cpu_start: ELF file SHA256: ebcb9a42f7898d12... I (461) cpu_start: ESP-IDF: v4.4-dev-3540-g4e03a9c34c-dirty I (469) heap_init: Initializing. RAM available for dynamic allocation: I (476) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM I (482) heap_init: At 3FFB7670 len 00028990 (162 KiB): DRAM I (488) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM I (494) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM I (501) heap_init: At 400943D4 len 0000BC2C (47 KiB): IRAM I (508) spi_flash: detected chip: generic I (512) spi_flash: flash io: dio W (516) spi_flash: Detected size(4096k) larger than the size in the binary image header(2048k). Using the size in the binary image header. I (530) cpu_start: Starting scheduler on PRO CPU. I (0) cpu_start: Starting scheduler on APP CPU. I (603) wifi:wifi driver task: 3ffbff78, prio:23, stack:6656, core=0 I (603) system_api: Base MAC address is not set I (603) system_api: read default base MAC address from EFUSE I (623) wifi:wifi firmware version: f84e709 I (623) wifi:wifi certification version: v7.0 I (623) wifi:config NVS flash: enabled I (623) wifi:config nano formating: disabled I (623) wifi:Init data frame dynamic rx buffer num: 32 I (633) wifi:Init management frame dynamic rx buffer num: 32 I (633) wifi:Init management short buffer num: 32 I (643) wifi:Init dynamic tx buffer num: 32 I (643) wifi:Init static rx buffer size: 1600 I (643) wifi:Init static rx buffer num: 10 I (653) wifi:Init dynamic rx buffer num: 32 I (653) wifi_init: rx ba win: 6 I (663) wifi_init: tcpip mbox: 32 I (663) wifi_init: udp mbox: 6 I (663) wifi_init: tcp mbox: 6 I (673) wifi_init: tcp tx win: 5744 I (673) wifi_init: tcp rx win: 5744 I (673) wifi_init: tcp mss: 1440 I (683) wifi_init: WiFi IRAM OP enabled I (683) wifi_init: WiFi RX IRAM OP enabled I (693) example_connect: Connecting to settle1... I (693) phy_init: phy_version 4670,719f9f6,Feb 18 2021,17:07:07 I (803) wifi:mode : sta (3c:61:05:3f:60:48) I (803) wifi:enable tsf I (803) example_connect: Waiting for IP(s) I (2853) wifi<9,2>, old:<1,0>, ap:<255,255>, sta:<9,2>, prof:1 I (3593) wifi:state: init -> auth (b0) I (3603) wifi:state: auth -> assoc (0) I (3613) wifi:state: assoc -> run (10) I (3633) wifi:connected with settle1, aid = 2, channel 9, 40D, bssid = 3c:84:6a: 1b:7a:4a I (3633) wifi:security: WPA2-PSK, phy: bgn, rssi: -34 I (3633) wifi:pm start, type: 1 W (3693) wifi:idx:0 (ifx:0, 3c:84:6a:1b:7a:4a), tid:6, ssn:2, winSize:64 I (3713) wifi:AP's beacon interval = 102400 us, DTIM period = 1 I (4583) example: Starting server I (4583) esp_https_server: Starting server I (4583) esp_https_server: Server listening on port 443 I (4583) example: Registering URI handlers I (4593) esp_netif_handlers: example_connect: sta ip: 192.168.68.65, mask: 255.2 55.252.0, gw: 192.168.68.1 I (4603) example_connect: Got IPv4 event: Interface "example_connect: sta" addre ss: 192.168.68.65 I (5583) example_connect: Got IPv6 event: Interface "example_connect: sta" address: fe80:0000:0000:0000:3e61:05ff:fe3f:6048, type: ESP_IP6_ADDR_IS_LINK_LOCAL I (5583) example_connect: Connected to example_connect: sta I (5593) example_connect: - IPv4 address: 192.168.68.65 I (5593) example_connect: - IPv6 address: fe80:0000:0000:0000:3e61:05ff:fe3f:6048, type: ESP_IP6_ADDR_IS_LINK_LOCAL W (12733) wifi:idx:1 (ifx:0, 3c:84:6a:1b:7a:4a), tid:0, ssn:0, winSize:64 I (12843) esp_https_server: performing session handshake E (14533) esp-tls-mbedtls: mbedtls_ssl_handshake returned -0x7780 E (14533) esp_https_server: esp_tls_create_server_session failed W (14543) httpd: httpd_accept_conn: session creation failed W (14543) httpd: httpd_server: error accepting new connection I (14553) esp_https_server: performing session handshake E (16283) esp-tls-mbedtls: mbedtls_ssl_handshake returned -0x7780 E (16283) esp_https_server: esp_tls_create_server_session failed W (16283) httpd: httpd_accept_conn: session creation failed W (16293) httpd: httpd_server: error accepting new connection I (22873) esp_https_server: performing session handshake E (24583) esp-tls-mbedtls: mbedtls_ssl_handshake returned -0x7780 E (24583) esp_https_server: esp_tls_create_server_session failed W (24583) httpd: httpd_accept_conn: session creation failed W (24593) httpd: httpd_server: error accepting new connection I (24603) esp_https_server: performing session handshake E (26333) esp-tls-mbedtls: mbedtls_ssl_handshake returned -0x7780 E (26333) esp_https_server: esp_tls_create_server_session failed W (26343) httpd: httpd_accept_conn: session creation failed W (26343) httpd: httpd_server: error accepting new connection I (26353) esp_https_server: performing session handshake W (28933) httpd_parse: parse_block: request URI/header too long W (28933) httpd_txrx: httpd_resp_send_err: 431 Request Header Fields Too Large - Header fields are too long for server to interpret I (29013) esp_https_server: performing session handshake E (30723) esp-tls-mbedtls: mbedtls_ssl_handshake returned -0x7780 E (30723) esp_https_server: esp_tls_create_server_session failed W (30723) httpd: httpd_accept_conn: session creation failed W (30723) httpd: httpd_server: error accepting new connection I (30733) esp_https_server: performing session handshake W (33343) httpd_parse: parse_block: request URI/header too long W (33343) httpd_txrx: httpd_resp_send_err: 431 Request Header Fields Too Large - Header fields are too long for server to interpret I (64033) esp_https_server: performing session handshake E (65743) esp-tls-mbedtls: mbedtls_ssl_handshake returned -0x7780 E (65743) esp_https_server: esp_tls_create_server_session failed W (65753) httpd: httpd_accept_conn: session creation failed W (65753) httpd: httpd_server: error accepting new connection I (65763) esp_https_server: performing session handshake E (67463) esp-tls-mbedtls: mbedtls_ssl_handshake returned -0x7780 E (67463) esp_https_server: esp_tls_create_server_session failed W (67473) httpd: httpd_accept_conn: session creation failed W (67473) httpd: httpd_server: error accepting new connection I (91483) esp_https_server: performing session handshake E (93193) esp-tls-mbedtls: mbedtls_ssl_handshake returned -0x7780 E (93203) esp_https_server: esp_tls_create_server_session failed W (93203) httpd: httpd_accept_conn: session creation failed W (93203) httpd: httpd_server: error accepting new connection I (93213) esp_https_server: performing session handshake E (94953) esp-tls-mbedtls: mbedtls_ssl_handshake returned -0x7780 E (94953) esp_https_server: esp_tls_create_server_session failed W (94953) httpd: httpd_accept_conn: session creation failed W (94963) httpd: httpd_server: error accepting new connection I (94973) esp_https_server: performing session handshake E (96733) esp-tls-mbedtls: mbedtls_ssl_handshake returned -0x7280 E (96733) esp_https_server: esp_tls_create_server_session failed W (96743) httpd: httpd_accept_conn: session creation failed W (96743) httpd: httpd_server: error accepting new connection I (125893) esp_https_server: performing session handshake W (129233) httpd_parse: parse_block: request URI/header too long W (129233) httpd_txrx: httpd_resp_send_err: 431 Request Header Fields Too Large - Header fields are too long for server to interpret I (129333) esp_https_server: performing session handshake E (131083) esp-tls-mbedtls: mbedtls_ssl_handshake returned -0x7780 E (131083) esp_https_server: esp_tls_create_server_session failed W (131083) httpd: httpd_accept_conn: session creation failed W (131093) httpd: httpd_server: error accepting new connection I (131093) esp_https_server: performing session handshake W (133983) httpd_parse: parse_block: request URI/header too long W (133983) httpd_txrx: httpd_resp_send_err: 431 Request Header Fields Too Large - Header fields are too long for server to interpret I (167783) esp_https_server: performing session handshake E (169493) esp-tls-mbedtls: mbedtls_ssl_handshake returned -0x7780 E (169493) esp_https_server: esp_tls_create_server_session failed W (169503) httpd: httpd_accept_conn: session creation failed W (169503) httpd: httpd_server: error accepting new connection I (169513) esp_https_server: performing session handshake E (171243) esp-tls-mbedtls: mbedtls_ssl_handshake returned -0x7780 E (171243) esp_https_server: esp_tls_create_server_session failed W (171253) httpd: httpd_accept_conn: session creation failed W (171253) httpd: httpd_server: error accepting new connection I (171263) esp_https_server: performing session handshake E (173103) esp-tls-mbedtls: mbedtls_ssl_handshake returned -0x7280 E (173103) esp_https_server: esp_tls_create_server_session failed W (173113) httpd: httpd_accept_conn: session creation failed W (173113) httpd: httpd_server: error accepting new connection I (182933) esp_https_server: performing session handshake W (186013) httpd_parse: parse_block: request URI/header too long W (186023) httpd_txrx: httpd_resp_send_err: 431 Request Header Fields Too Large - Header fields are too long for server to interpret I (186093) esp_https_server: performing session handshake E (187803) esp-tls-mbedtls: mbedtls_ssl_handshake returned -0x7780 E (187803) esp_https_server: esp_tls_create_server_session failed W (187813) httpd: httpd_accept_conn: session creation failed W (187813) httpd: httpd_server: error accepting new connection I (187823) esp_https_server: performing session handshake W (190923) httpd_parse: parse_block: request URI/header too long W (190923) httpd_txrx: httpd_resp_send_err: 431 Request Header Fields Too Large - Header fields are too long for server to interpret I (192863) esp_https_server: performing session handshake E (194583) esp-tls-mbedtls: mbedtls_ssl_handshake returned -0x7780 E (194583) esp_https_server: esp_tls_create_server_session failed W (194593) httpd: httpd_accept_conn: session creation failed W (194593) httpd: httpd_server: error accepting new connection I (194603) esp_https_server: performing session handshake E (196293) esp-tls-mbedtls: mbedtls_ssl_handshake returned -0x7780 E (196293) esp_https_server: esp_tls_create_server_session failed W (196293) httpd: httpd_accept_conn: session creation failed W (196293) httpd: httpd_server: error accepting new connection I (196303) esp_https_server: performing session handshake W (199103) httpd_parse: parse_block: request URI/header too long W (199103) httpd_txrx: httpd_resp_send_err: 431 Request Header Fields Too Large - Header fields are too long for server to interpret I (199143) esp_https_server: performing session handshake E (200863) esp-tls-mbedtls: mbedtls_ssl_handshake returned -0x7780 E (200863) esp_https_server: esp_tls_create_server_session failed W (200873) httpd: httpd_accept_conn: session creation failed W (200873) httpd: httpd_server: error accepting new connection I (200883) esp_https_server: performing session handshake W (203713) httpd_parse: parse_block: request URI/header too long W (203713) httpd_txrx: httpd_resp_send_err: 431 Request Header Fields Too Large - Header fields are too long for server to interpret |
1个回答
尝试一下增加HTTPD_MAX_REQ_HDR_LEN,在menuconfig-> Component config -> HTTP Server -> Max HTTP Request Header Length 中进行设置
只有小组成员才能发言,加入小组>>
1106 浏览 1 评论
574浏览 6评论
477浏览 5评论
有没有办法在不使用混杂模式的情况下实现Wifi驱动程序接收缓冲区访问中断呢?
460浏览 5评论
461浏览 4评论
435浏览 4评论
GMT+8, 2024-12-18 15:23 , Processed in 0.726430 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
