扫一扫,分享给好友
最近仿照网上相关的一些例程,在nios中调试三速以太网,使用的是百兆rgmii接口,但是好多天了一直不能调通,打印信息显示能连上phy,IP地址和MAC地址也能读到,程序运行显示初始化也成功了,但是一直ping 不通 ,现在实在是不知道问题出在哪里了,希望有相关经验的同学出来指导一下,谢谢。
下面是程序运行的过程: nios2-terminal: connected to hardware target using JTAG UART on cable nios2-terminal: "USB-Blaster [USB-0]", device 1, instance 0 nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate) =============== Software License Reminder ================ This software project uses an unlicensed version of the NicheStack TCP/IP Network Stack - Nios II Edition. If you want to ship resulting object code in your product, you must purchase a license for this software from Altera. For information go to: "http://www.altera.com/nichestack" ===================================================== InterNiche Portable TCP/IP, v3.0 Copyright 1996-2003 by InterNiche Technologies. All rights reserved. prep_tse_mac Your Ethernet MAC address is 00:07:ed:ff:8f:11 Static IP Address is 192.168.1.2 prepared 1 interface, initializing... [tse_mac_init] SGDMA desc memory cleared [phyID] 0x12 141 cc2 [netif_tse] found Marvell 88E1111 PHY [triple_speed_ethernet_init] Speed is 100 is 1 Full Duplex is 1 OK, x=0, CMD_CONFIG=0x00000000 MAC post-initialization: CMD_CONFIG=0x0400020b [tse_sgdma_read_init] RX descriptor chain desc (1 depth) created IP address of et1 : 192.168.2.1 Created "Inet main" task (Prio: 2) Created "clock tick" task (Prio: 3) Simple Socket Server starting up [sss_task] Simple Socket Server listening on port 30 Created "simple socket server" task (Prio: 4) |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
NVMe高速传输之摆脱XDMA设计51:主要功能测试结果与分析3 nvmePCIe高速存储 PCIe高速存储
230 浏览 0 评论
NVMe高速传输之摆脱XDMA设计50:主要功能测试结果与分析2 nvmePCIe高速存储
378 浏览 0 评论
NVMe高速传输之摆脱XDMA设计49:主要功能测试结果与分析1
1509 浏览 0 评论
935 浏览 0 评论
876 浏览 0 评论
4430 浏览 63 评论
/9
GMT+8, 2025-12-3 05:06 , Processed in 0.591173 second(s), Total 69, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3583
