使用ESP32-S3-DevKitC-1开发板,与window 11作业系统,依照入门指南进行软件设置,当连接开发板到电脑并执行到idf.py -p com3 flash monitor程序时,发生以下错误讯息,请问如何解决?
Executing action: flash Running ninja in directory c:espesp-idfexamplesget-startedhello_worldbuild Executing "ninja flash"... [1/4] Performing build step for 'bootloader' ninja: no work to do. [1/2] cmd.exe /C "cd /D C:espesp-idfcomponentsesptool_...:/esp/esp-idf/components/esptool_py/run_serial_tool.cmake" esptool.py esp32 -p com3 -b 460800 --before=default_reset --after=hard_reset write_flash --flash_mode dio --flash_freq 40m --flash_size 2MB 0x8000 partition_table/partition-table.bin 0x1000 bootloader/bootloader.bin 0x10000 hello-world.bin esptool.py v3.1-dev Serial port com3 Connecting........_____....._____....._____....._____....._____....._____....._____ A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header CMake Error at run_serial_tool.cmake:50 (message): C:/esp/tools/.espressif/python_env/idf4.3_py3.8_env/Scripts/python.exe C:/esp/esp-idf/components/esptool_py/esptool/esptool.py --chip esp32 failed FAILED: CMakeFiles/flash cmd.exe /C "cd /D C:espesp-idfcomponentsesptool_py && C:esptools.espressiftoolscmake3.16.4bincmake.exe -D IDF_PATH="C:/esp/esp-idf" -D SERIAL_TOOL="C:/esp/tools/.espressif/python_env/idf4.3_py3.8_env/Scripts/python.exe C:/esp/esp-idf/components/esptool_py/esptool/esptool.py --chip esp32" -D SERIAL_TOOL_ARGS="--before=default_reset --after=hard_reset write_flash @flash_args" -D WORKING_DIRECTORY="C:/esp/esp-idf/examples/get-started/hello_world/build" -P C:/esp/esp-idf/components/esptool_py/run_serial_tool.cmake" ninja: build stopped: subcommand failed. ninja failed with exit code 1 PS C:espesp-idfexamplesget-startedhello_world> |
1个回答
根据您提供的错误信息,这个问题可能是由于以下几个原因导致的:
1. 确保您已经正确安装了所有必要的软件,包括Espressif的IDF工具链、Python、以及适用于Windows的驱动程序。 2. 检查您的开发板是否已经正确连接到电脑,并且COM3端口已经正确识别。您可以在“设备管理器”中查看端口。 3. 确保您使用的idf.py命令是正确的。根据您的描述,您应该使用以下命令: ``` idf.py -p COM3 flash monitor ``` 4. 如果问题仍然存在,您可以尝试以下步骤: a. 打开命令提示符(cmd)或PowerShell,然后导航到您的项目文件夹。 b. 执行以下命令以清除项目构建文件: ``` idf.py fullclean ``` c. 再次执行idf.py命令: ``` idf.py -p COM3 flash monitor ``` |
只有小组成员才能发言,加入小组>>
944 浏览 0 评论
1671 浏览 0 评论
请问一下我想用ESP8685直接替换ESP8266而不用写程序,可以让ESP8685直接通过之前ESP8266的外挂的flash运行程序吗
1330 浏览 1 评论
1233 浏览 1 评论
5015 浏览 2 评论
为blufi_device设置自定义名称,但是无法修改,为什么?
1252浏览 4评论
请问ESP32-S2-WROOM怎么获得ESP32-S2外接FLASH的唯一序列号?
927浏览 3评论
2334浏览 3评论
ESP-IDF的VScode插件的build按钮点击会报错的原因?
2526浏览 3评论
ESP-Jumpstart例程中第5个工程:5_cloud连接报错是哪里的问题?
1051浏览 2评论
/9
GMT+8, 2025-12-2 01:46 , Processed in 0.438220 second(s), Total 42, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
578
